    Dome
    5 Posts 3 Posters 498 Views 3 Watching
      Tonto
      Hi, I am working on a Dome similar to one by Santiago Calatrava in his design of City of Arts and Sciences.
      http://www.iho-ohi.org/wp-content/the-city-of-arts-and-sciences-valencia-spain.jpg
      On the oval dome structure on the left, there are many frames on it, how would I achieve this look in Sketchup, because I am unable to do this as I cannot use the line tool on the dome I created.
      Also, is there any way to split on dome into two halves? Or is there a way to make a half dome with a semi circle?
      Thanks, any help is appreciated.
        Tonto
        Not going to touch the first part of your question but cutting a dome...just create a cutting plane and slide it into position where you want to slice the dome. Then (right click) intersect with model, then trim away the unneeded.
        Thanks for that, it worked. I recently saw the tutorial on intersecting but I never thought to try it.
        Does anyone have ideas for the frames?
        I'm currently using intersecting which seems to be working but is very time consuming.
        • TaffGochT Offline
          TaffGoch
          Tonto,
          Interesting building.
          I played with 'follow me' and 'push/pull' to create the basic structural shape. I make no claims to accuracy of angles, length/width ratio, etc. This model merely demonstrates a means of construction. (See attached model.) For the rest of the building, similar application of these two tools should satisfy.
          Arts&Sciences.zip
          Arts&Sciences.skp
          "Information is not knowledge." -- Albert Einstein
            Tonto
            @taffgoch said:
            Tonto,
            Thanks for that, its very helpful.
            • TaffGochT Offline
              TaffGoch
              Tonto,
              So you got how to create the hull shape with the 'follow me' tool? If not, those steps can be demonstrated in more detail.
              Taff
