    How does one taper a triangle?
    12 Posts 4 Posters 902 Views 4 Watching
    • N Offline
      numbers
      I am doing a small project, acutally making a planter. I have decied to do a tapered triangle design, you may have guessed, and I am having trouble figuring this out. Can you help?
        remus
        have you got an example of the sort of shape your after? im having trouble working out what you want to do.
        • N Offline
          numbers
          I want it to get smaller as it goes down if possible.
            remus
            Ok, that shouldnt be too tricky.
            Just select the bottom face (or the top, doesnt really matter) and go to the scale tool (tools->scale.) If you hold down ctrl while grabbing one of the corner handles it will scale the face about the centre point.
            • N Offline
              numbers
              +10 Thank you very much
                remus
                OK, it i a bit trickier than that, because you cant really scale around the centre point.
                It is possible to make the first method work, but its a bit tricky.
                An easier way of doing it would be to get your starting triangular face (before you push/pulled it) offset it and then move the inner triangle up. You will have to then fill in the bottom face, but you'll have your shape.
                • H Offline
                  Hazza
                  No you were right the first time, you just hold the control key and it scales around the centre point.
                  See all of my SketchUp models here.
                    remus
                    Not when i tried it.
                    SU takes the centrepoint as the centre of the scaling handles, not the centre of the geometry your scaling, and on an equilateral triangle they are different.
                    Give it a go.
                    • H Offline
                      Hazza
                      Huh, you are right, and I discovered that SU is even dumber than that!!
                      Draw a triangle using the polygon tool. Draw a line from one point to the mid point of the opposite side. Now try and find the "mid point" of the other 2 sides... they are about 2/3 the way along.
                      I figured out an easy way:
                      1. Draw the bottom triangle,
                      2. Use the "Offset" tool to draw the top triangle,
                      3. Delete the face that is between the smaller and larger triangles,
                      4. Move the larger triangle in the blue direction,
                      5. Join the faces.
                      • H Offline
                        Hazza
                        Actually, forget step 3 and you only need to do the top triangle in step 5.
                          No, Remus' solution is easier:
                          1. draw a triangle
                          2. offset it
                          3. simply move the inner triangle up (or down)
                            The side faces will be created automatically (by the autofold feature).
                          • H Offline
                            Hazza
                            1. draw a triangle
                            1. offset it
                            2. simply move the inner triangle up (or down)
                            Ahh ha ha ha... I missed his offset reply because I went to try the the scaling solution.
