    Roller Coaster Thrill Ride [For Solo]
    16 Posts 11 Posters 1.9k Views 11 Watching
      kwistenbiebel
      @solo said:
      Weeee!!
      That was pretty cool actually, effective too.
      The only observation I have that would make that perfect is if you had the blur option between frames which would make the ride smoother and avoid the patterning of the support bars.
      Otherwise it's awesome. (music works too0
      Thanks. Making the animation smoother by using a 'point blur' frame blending causes strange artefacts in this case because of the fast motion changes.
      Best solution would be to render it at a higher frame rate but I couldn't find the patience.This one rendered over night (335 frames).
        AndriyG81
        very nice looking video. It could benefit from more frames. I always wanted to make one of those roller coaster videos but never got around to it. I was hoping to see a big sudden drop 😉
        Thank you for sharing.
        http://andriyg.com
        • pbacotP Offline
          Great video, especially for SU. I guess you can't vary the speed, as discussed. Some stalling, swooping, and lurching would add drama. Cool intro. Now what are we going to dare him to do?
            rv1974
            After watching this:
            http://vimeo.com/1654340?oct-39
            you'll understand there's a lot room for improvement)
            NB! Action begins on 2.30 min.
            • StinkieS Offline
              Stinkie
              lol. That's neat. 💚
                kwistenbiebel
                👍 😎 These guys are nuts.
                  kwistenbiebel
                  Sketchyphysics could take care of natural slowdowns and speed ups by gravity....If only ...
                    bubbalove
                    I would think that the camera would be a little higher since the wheels connect to those 2 side posts, right? Then you might not get those "strange artifacts" as much... I don't know! Cool ass video though...
                    "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                      princedragoncok
                      Considering this is sketchup it really is cool. Thumbs up 👍
                      • FrederikF Offline
                        Frederik
                        Can't add anything to what already have been said... 😉
                        Well done, Chris..!! 👍
                        Cheers
                        Kim Frederik
                          kwistenbiebel
                          Thanks guys.
                          I am sure this can be taken to a higher level: better camera path,higher framerate,some extra props on the scene etc..
                          For me this was more about "can I do a roller coaster?" than making a perfect animation.
                          It's fun to try things you haven't seen done by others using a Sketchup/render engine combo and it's a great way to learn new things.
                            Aernoud
                            Looks really good!! Love the way trough nature.. nice background 😉
                            Currently SU project:
                            • Metroid Prime large leviathan (own design)
                            • Metroid prime plasma turret (own design)
                            • Metroid prime Armour clubber (own design)
                            • The Minas Tirith project
                            • Mobile phone (own design)
                            • romboutR Offline
                              rombout
                              perhaps if you use depth of field in your render app you could get a bit of motion speed... in which app is this made? if the render app spits out seperate images you could also try and run it through a batch in photoshop with motion blur applied
                              • romboutR Offline
                                rombout
                                here i made an example... it wasnt motion but radial blur i used 10%. you can make a batch where you can deside how much the blur will be. will take a lot of time but i think the sequence will look a bit more realistic
