    Hypershot Renders
    38 Posts 15 Posters 9.6k Views 15 Watching
    • ibonI Offline
      ibon
      Alt + Mouse wheel
      • EarthMoverE Offline
        EarthMover
        Actually I figured it out. Alt+ Middle mouse button is just for zoom. Alt+Right Mouse Button (while moving mouse left to right) will change the "dolly" which apparently changes the field of view. I'm testing the HDR light source now. Thanks again!
        Content Creator at Skapeup
        • ibonI Offline
          ibon
          Well, in my pc Alt + mouse wheel is for changing FOV, but i may have different configuration for some reason 😒
          By the way... i'm trying to achieve realistic water, but i can't. Do you know how to get it? many thanks. It's good to have anyone like you with common problems 😄
            EarthMover
            Ibon,
            I did some quick trial and error with the pool water material that is under the "other" section of the material library and got a decent result. I changed the settings as follows:
            Alpha - .05
            Reflectivity - .5
            bumptexture tile s - 0.15
            bumptexture tile t - 0.04
            Oh, and you're right about the mouse wheel. It's confusing at first, but I got it to adjust the perspective. Thanks!
            http://img71.imageshack.us/img71/3489/watertestik5.th.jpg
              geh4evr
              Adam, I must say, You're the reason I've no money to spend on shopping this week! I splashed out and bought Hypershot. And I must say, it's bloody brilliant!
              • H Offline
                Huggkruka
                I'm playing around with the trial, and it looks great. I'm half a gig under the recommended RAM and I'm surfing and listening to music, and it gives me this in under 10 mins:
                http://img225.imageshack.us/img225/3756/mecha1qm6.th.jpg
                Sorry for hi-jacking the thread!
                  princedragoncok
                  This looks like really promising software, would really like to see some more architectural examples though
                    remus
                    Theres a few architectural shots here: http://www.bunkspeed.com/gallery/
                    Nice renders adam, could i ask how easy it is to setup materials?
                    • ibonI Offline
                      ibon
                      Thanks Adam! I didn't see that section 😳
                      Now it's quite easy make water, but it's very strange not to have to deal with IOR when making it... plastics have IOR values, but not bump slots 😞
                        EarthMover
                        Here's a quick Architectural render. Model was taken from 3DWH (VaSt Architecture). I downloaded model...exploded...exported as .obj file....opened in Hypershot.....dropped in a few textures and rendered. (I also added a high pass layer and soft shadow in PS) Total time from start to finish....25 min. Tree was also added in SU and ibon's clipmap suggestions worked well. All in all, not perfectly photoreal, as this is a biased raytrace engine, but it does have a nice look and a soft feel. I'll try out some more architecture later.
                        http://img225.imageshack.us/img225/7759/housetest1copyrl6.th.jpg
                        • pbacotP Offline
                          That's a pretty good architectural render. Better than the ones at the website, given the time. You got more light out of it. So all the shadows in HS are soft? Does it display sun shading?
                            EarthMover
                            @geh4evr - Sorry to hear you spent your shopping money! I think you'll find it was worth it.....eating is overrated anyway. 😄 Which version did you pick up?
                            @Huggkruka - No worries. Good job on the quick render. Perhaps try turning on the studio lighting option or use an HDRI...it will bring your reflections to life
                            @Remus - Materials are very simple to setup. I'm a big VRay and Kerky user, so Hypershot is almost frustratingly simple. But I guess that's the beauty. As Ibon pointed out, some of the options for certain material types seem to defy logic, but in the end, there is no denying the stunning results.
                            @pbacot - Thanks! There is a button to go from soft to sharp shadows. All sun shading is based on a HDRI input, that is separate from the background image. You can easily change the direction of the lighting to match the background image, by holding down the CTRL key and moving left to right with the mouse and left mouse button. What's cool is that you can see the lighting change in real time.
                              EarthMover
                              Here's a quick render of wedding rings I found in the warehouse. Took about 5 minutes. The modeling is a little choppy, but you can see the great job it did on the diamond.
                              http://img221.imageshack.us/img221/794/weddingringsgp2.th.jpg
                              • romboutR Offline
                                rombout
                                hehy nice chopper familiar
                                  tomislavm
                                  Hypershot is the best but unfortunately it is not free!
                                    geh4evr
                                    Adam, I bought the HyperShot HD Version, And by shopping money, it's mainly just the money I was going to use to buy a new bumper for my car, the old ones barely hanging on, but I'll have to Duct Tape it.
                                      EarthMover
                                      Here's a neat render of a nicely modeled desk from the 3DW.
                                      http://img218.imageshack.us/img218/5708/deskchair2zb8.th.jpg
                                      • ibonI Offline
                                        ibon
                                        Hi Adam! i have been on Vacations and i see that you have been using hypershot and have got excellent results! you are becoming an hypershot master 👍
                                        I have been using it again and i've got a BIG problem. I can only get clip map or opacity work when there's no a phisical ground behind models. See:
                                        http://img504.imageshack.us/img504/6043/sombra1pi0.th.jpg
                                        http://img504.imageshack.us/images/thpix.gif
                                        http://img504.imageshack.us/img504/8395/sombra2sd6.th.jpg
                                        If you know how to get it work (shadows) help me please, because i can't use any people or tree in my projects! many many thanks!!!
                                        I don't know if it's the right place to post it, if anyone wants you can move it. Sorry
                                          EarthMover
                                          Hi there Ibon! I wish I could help bro, but I'm having the same issue. I've tried everything I can think of.
                                          See here.
                                          http://img218.imageshack.us/img218/2297/24937671nf5.th.jpg
                                          http://img218.imageshack.us/images/thpix.gif
                                          It's a shame, because I am getting really nice renders otherwise. I just have to pick an HDRI or position it in a way to not display the shadows. Either that, or import the vector shape of my trees into sketchup and add the texture to that so that I get a better shadow. That would be a lot of work with all the plants and trees in my collection! Here's a shot where I had to hide the shadows.
                                          http://img219.imageshack.us/img219/3513/fouldshouse1ry3.th.jpg
                                          http://img219.imageshack.us/images/thpix.gif
                                            EarthMover
                                            Here's a few more Hypershot renders of various warehouse stuff.
                                            http://img507.imageshack.us/img507/6465/49685822na0.th.jpg
                                            http://img507.imageshack.us/images/thpix.gif
                                            http://img215.imageshack.us/img215/3791/53455572tw5.th.jpg
                                            http://img228.imageshack.us/img228/9496/82086826em4.th.jpg
                                            http://img228.imageshack.us/images/thpix.gif
                                            http://img220.imageshack.us/img220/5391/78369401ji8.th.jpg
                                            http://img220.imageshack.us/images/thpix.gif
