    Graphic bug on large extent drawing
    6 Posts 4 Posters 1.3k Views 4 Watching
      Matt666
      Hi !
      I don't know if that had been signaled before (I hope so !!) :
      On large drawings (3km/3km for example), when trying to zoom in on details, graphic bugs... Sorry I can't explain more because of my poor english πŸ˜„
      Here is an example : Sans titre 5.jpg
      Procedure :
      1 - Draw a rectangle (1000m / 1000m)
      2 - Draw a box (1m / 1m / 1m) on this rectangle (or elsewhere !!)
      3 - Zoom in until you see largely the box (and the bug πŸ˜‰ )
      Frenglish at its best !
      My scripts
      • FrederikF Offline
        Frederik
        Not sure this is a bug... I'd say it's an OpenGL issue/limitation...
        This is also known as the FOV issue and you correct it by changing the FOV distance... πŸ˜‰
        BTW - who would need a 3km x 3km box..?? πŸ˜• πŸ˜„
        Cheers
        Kim Frederik
          remus
          This is a pretty well known issue. Its called clipping.
          If i remember correctly it usually occurs when you have a very large model, or your model is a long way form the origin. If you do a search for 'clipping' you should get a lot of info on it.
            Matt666
            Ok thank you !!
            My scripts
              Yes, see this:
              http://sketchup.google.com/support/bin/answer.py?answer=36261&topic=13710
              • FrederikF Offline
                Frederik
                Like I said... Fix it by adjusting the FOV setting... πŸ˜‰
                Cheers
                Kim Frederik
