    Help me to do this.. "Curved ramp" Please..
    31 Posts 9 Posters 13.3k Views 9 Watching
    • I Offline
      Iglesias
      Thank you Gai, one mistake was "in the bottom" instead "at the bottom" and one "is" by "are" plural.
      It is a shame for me to speak in English, but I am making efforts to help people.
      Best regards to all of you.
        dtrarch
        Hello All
        There is an old ruby called circle slopes that will build a helical ramp.
        [aitop.rb]
        Still works with SU V6
        Here it is
        dtr
        aitop.rb
        • I Offline
          Iglesias
          Hello dtr,
          I have this plug in in my computer, but to make helical with profile and making the revolution with a number of degrees, it is better using screw, you can look the tutorial above.
          To make the ramp like the one in this topic, needs finished the ramp by hand, cuting a slice and so on.
          Thank you for telling here, because this Ruby Script is very useful too.
          • I Offline
            Iglesias
            Hello Gai,
            Is it possible to see it from youtube?
            http://youtube.com/watch?v=W-Ox-xCLdbY
              dtrarch
              Hi Iglesias
              Good call as Screw does do a better job.
              Thx for the heads up.
              Now we need one for non helical curved paths.
              Anti twist mode.
              The rez for me on youTube was not good enough to see the tut but you sound like a good guy in any case.
              Cheers
              dtr
              • I Offline
                Iglesias
                Hi dtr,
                If you want a video with more resolution, download from this link.
                404 Not Found
                (rapidshare.com)
                  dtrarch
                  Iglesias
                  Thx for the link.
                  Very nice tut and good of you to do the work.
                  Back to business.
                  dtr
                  • W Offline
                    witjazz
                    Hi..Iglesias Thanks for your help
                    but i have no plug-in "screw1_5"
                    please give me here or send it to my e-mail
                    spidermanthai111@yahoo.com
                    Thanks in advance
                    Witjazz πŸ‘
                    • I Offline
                      Iglesias
                      Hello Witjazz,
                      In this link you can download the plugin.
                      Regards
                      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm
                      • W Offline
                        witjazz
                        Hello Iglesias
                        Why i can't do like you did
                        when i type 4,16 m and then enter it not appear a window "steps and turns"
                        i just apply the cursor along the azis "z" already
                        • I Offline
                          Iglesias
                          Possibly your SketchUp is different to mine, try to use a point instead of comma.
                          • W Offline
                            witjazz
                            using pc sir
                            am live in Thailand
                            i use SketchUp pro 6
                            i try to type dot already but it not work
                            • I Offline
                              Iglesias
                              Steps to use screw.
                              • Select the profile.
                              • choose plugin.
                              • Select first end, then clic.
                              • Move upwards z direction.
                              • Type the distance, in your case 4,16 and push enter key, then appear the menu "steps and turns"
                              • W Offline
                                witjazz
                                Steps to use screw.
                                • choose plugin.
                                then appear the menu "steps and turns"(not appear the menu in this step for me sir)
                                can you expain what is 4 and 16
                                now! i finish it already sir thank you so much
                                  Simon B
                                  Excellent tutorial! Muchas Gracias! πŸ˜„
                                  • Y Offline
                                    yiannosh
                                    Where can I find this plugin to try it. Thanks
                                      Here:
                                      http://rhin.crai.archi.fr/rld/plugin_details.php?id=357
                                        If you speak of Screw 1.5 : here the link πŸ˜‰
                                        You have also a cool plug for make some ramps
                                        Shape Bender by Chris Fullmer
                                        [flash=420,315:1inxtvds]http://www.youtube.com/v/tGHTIOMm_34[/flash:1inxtvds]
                                        • 2 / 2
