    RAL colors
    85 Posts 40 Posters 57.8k Views 40 Watching
    • K
      kwistenbiebel
      Thanks 😄
      Now I can finally get a realistic RAL9006 in my renderings.
      Great for architects.
      • G
        gamore
        Take a look here
          remus
          care to expand? im not following...
          • W
            watkins
            Dear Remus,
            See
            http://www.multipaneluk.co.uk/alupanel/alupanel_ral_colours.php
            http://www.fischerprofil.com/dbfiles/Farbtonk-Polyester-03-2007-engl-Internet.pdf
            Regards,
            Bob
              remus
              I was refering more to gamore's post, i though there was meant to be a link or something...
              reading ti again it seems like it might be more of 'this is a tasty little collection' sort of comment.
              • C
                CameronVan
                @burkhard said:
                Take a look here in the forum . You'll find Sherwin, Pantone and others, mostly done by Didier. Otherwise...
                Pantone; viewtopic.php?f=41&t=462&st=0&sk=t&sd=a&hilit=pantone
                RAL; viewtopic.php?f=41&t=477&p=3402&hilit=Burkhard#p3402
                Sherwin-Williams; viewtopic.php?f=41&t=461&p=3156&hilit=+colors#p3156
                ILog; viewtopic.php?f=41&t=420&p=2866&hilit=+HKS+colors#p2866
                NBS-IBCC; viewtopic.php?f=41&t=420&p=2866&hilit=+HKS+colors#p2866
                Thank you Burkhard but none of these are clickable links.
                How do you view these posts?
                • BurkhardB
                  Burkhard
                  copy and paste. I just copied the whole text which I made for someone who asked me for coloures.
                  This is the whole link for pantone, change only the viewtopic in your browser
                  404 Not Found
                  (www.sketchucation.com)
                  http://www.ia-plus.de
                  • C
                    CameronVan
                    Thanks again and I see what you mean... cut and paste the links.
                    However the NBS-IBCC link you gave is the same as the ILog and I cannot seem to find NBS-IBCC in the search part of this forum. 😳
                    Here are the others for easy quick link. Don't mean to step on toes but I thought it easier.
                    Pantone
                    RAL
                    Sherwin Williams
                    ILog
                    • BurkhardB
                      Burkhard
                      My fault, never checked it. Try here
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=417&p=2849&hilit=+nbs+colors#p2849
                      You'll find it under colors not colours 😉
                      • C
                        CameronVan
                        Thanks.
                        • C
                          cyan.archnet
                          THANKS A LOT for sharing!
                            Mvanderlande
                            @burkhard said:
                            unpack and copy into the material folder. All are .skm files
                            credits to Holger K
                            Burkhard
                            • MALAISEM
                              MALAISE
                              Danke Burkhard 😄 mehr Farbe lohnt sich.. More colours for a better render.
                              Pierre
                                slowthemuchoil
                                thanks for the ral palette
                                • numbthumbN
                                  numbthumb
                                  Thanks! I just happen to have a model that needs a paint job! Great!
                                  Comfortably numb...
                                  • utilerU
                                    utiler
                                    Just wondering if these RAL colors can be downloaded in English?
                                    Just Curious...
                                    • numbthumbN
                                      numbthumb
                                      As .skm files? Don´t know about that. A kind of workaround that I use is a list of RAL classic colour names in english http://www.ral-digital.de/english/ralclassic_namen.htm?content2.shtml
                                      Comfortably numb...
                                        If you want to 'rename' these skms 'displayed names' you have to edit all of the skms' documentProperties.xml files [it's actually a zip file] - this is a pain for that number of files...
                                        So... you write a script/batch file to process each skm in turn, and extract the d..P...xml file and replace the text from a lookup-table e.g. <dp:title>RAL1000-Gruenbeige</dp:title> e.g. RAL1000-Gruenbeige<==>RAL1000-Green beige
                                        Save it all back as was...
                                        etc etc etc...
                                          Jim
                                          The original .skm file is a text file with a list of colors, so you should be able to translate the names in that single file.
                                          Rename the file to the name of the library as you want it to appear in SketchUp, then copy the file to the Materials folder (or subfolder of.)
                                          The next time you open that materials folder, the library will be created using the filename you gave it.
                                            Exactly where might that be ? 😕
                                            NOT on a PC ?
                                            You can only change the name of the 'collection', but NOT the individual skms themselves - they are embedded in the smk's xml coded file ???
                                            • 2 / 5
