    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.5m Views 667 Watching
    • GaieusG
      Welcome Chang!
      • T
        Tekkybot
        hi. im tekkybot 😄 how do i select more then one item and push pull it? im not doing this right, as im a total newbie 😳 im trying to create a simple cardboard box looking robot. (nothing to too hard as i have to keep it simple at first) i draw a square, then copy, and paste it, so as to form the base of the pair of legs of the robot. the reason i want to pull both blocks at once is so i can keep things symmetrical ❓
        • Chris FullmerC
          Welcome, and one way to do that is to make the one block. THen select it all and turn it into a component. Then copy and paste the component (or I would use the move tool and hold down ctrl (on a PC)). Move+ctrl = move a copy. So this would would move a copy of the component over to where I want it. Then with the copy of the component, I would select it and activate the scale tool and scale it to negative 1 along the same axis I moved it. So if I moved the copy along the red axis, I would then scale the copy to -1 along the red axis too.
          So now I would edit one of the components and it will change both components equally, but mirrored towards eachother, thus giving you the symmetry you need.
          It sounds much more complicated than it actually is. I can put together a quick tutorial if my vague instructions don't help, or there probably is one already in the tutorials section on the forum. At any rate, have fun with SketchUp!
          oh, I forgot to mention that you can not push/pull 2 faces simultaneously in SketchUp, though I think there might be an additional script you can download and install that will give you this functionality. Someone else will have to provide a link to this though.
          • P
            Pout
            Hello all,
            While searching for sketchup info I found this active board, which i hope i can learn from on contribute to.
            To get started i have some questions:
            • Is it possible to create scenes based upon external data?
              ex.
              I have a dbase with in it a list of names.
              For each name i want to autmatically create a scene with that name.
              Can this be done?
              And in the same way: Is it possible to create 1 page for each scene in Layout?
            • Is it possible to display entity info in some sort of window while mousing over an object? Again this info is stored in a dbase.
            • Can colors of an object be different between scenes? Currently it's not in the list of the property-settings that are stored between scenes.
            • Is it possible to display text in the SU window that comes from out of SU? (eg. from a dbase or a txt file)
            I hope these questions make sense and my english is understandable. I'm not looking for a complete script (but if it exsists, why not) but more guidelines on how to do the SU part. I think i already have the communication with the dbase working so now i just need some ruby advise on how to make it work in SU.
            Thx in advance and kind regards,
            Pout
            • GaieusG
              Hi Pout - and welcome to the forums!
              Most of your questions above can only be done with ruby (or other) scripting if they can at all (I myself am not a scripter to be able to tell).
              Therefore you should post your questions in the Ruby forum to get bigger attention.
              As for the LayOut question - yes, under the SU Model tab in the LO Tray (on the right),you can insert an image of the model from any scene.
                robertsonstewartiain
                Hello,
                I'm Stew, and architecture student, who has a reasonable understanding of modelling in SketchUp. The only problem I have is exporting my models.
                I am not 100% convinced with the finish when exporting from purely SketchUp, so I seek advice and guidance of a suitable render package to use.
                I have never used any rendering packages in the past so don't know what to look for. I've read up on Modo, Cheetah3D, Studio Max etc but have no idea on the easiest and best for my needs.
                Any guidance/advice on this matter would be much appreciated.
                SketchUp is such an important tool during my design work, so would like to make more use of the programme, but present it in a more professional manner.
                Kind Regards,
                Stewart
                • soloS
                  Welcome to SCF Stew.
                  What OS are you using?
                  What line of work are you in, or what type of renders are you hoping to do?
                  These questions are in order to best direct you to a renderer that might best suit your needs.
                    jol
                    Been dabbling with sketchup for a few months now (learning mostly) as an aid for pattern creation when making large inflatable objects, namely kite line laundry.
                    So far off the drawing board has been a 2m ground display spider, which wasn't hugely successful, but not bad, a slightly better 2m carrot top - another ground anchored inflatable. Going out for testing this weekend hopefully is a 6m felix the cat, which was pretty well entirely drawn up in sketchup 'cept for his hands and feet.
                    I havn't been able to find any designing software that was affordable and could do what I wanted in one complete package. Using sketchup certainly is affordable costing nothing and once I've drawn something up, it is exported into Pepakura http://www.tamasoft.co.jp/pepakura-en/ to create the fabric pattern. in most cases the whole process goes thru about 4 different programs from go to whoa.
                    While not a perfect solution for what I use it for, as I get better at using sketchup and manipulating it for pattern template making, there is definitely a lot of promise there.
                    cheers
                    JoL
                    • Chris FullmerC
                      Very cool Jol. Glad you're here. Kite line laundry sounds interesting, I don't know of anyone else using SketchUp for that. I just went to the Berkeley kite festival a few weeks ago here in California, USA. And I know that Jean Lemire, another long time SU user flys kites. He does 1 man 3 kite ballet stuff up in Canada I think. Anyhow, good to have you!
                        Solo,
                        Sorry for the delay in replying. Impressive portfolio.
                        I use Mac OS X 10.5.4 or alternatively I have an older version of 10.3.9 on my PowerBook.
                        Being an architecture student I create my buildings in SU the drop them into Photoshop to montage the context in.
                        I'm not looking for anything spectacular at the moment until I grab the basics of rendering packages, just something to take the SU cartoonish appearance, as I see it, away from my models.
                        Thanks again,
                        Stew
                          diabloho
                          Hello
                          Im very new to mixing cad and SU, am I able to bring a surface into SU from Civil 3D. I created a dwg with the surface only, but nothing shows up.
                          Any help is appreciated.
                          Thanks.
                          • soloS
                            Stew.
                            There are many free and or cheap rendering solutions available these days, maybe slightly less available options for the Mac platform but nevertheless there are some available and they are pretty good.
                            I would suggest one of three options:
                            Podium: http://www.suplugins.com/
                            This is the easiest one to learn and will be sufficient for your intentions. As you have noticed a large number of my renders as seen on my site was done with Podium. There is a free version available but has a render size limitation.
                            Kerkythea: http://www.kerkythea.net/joomla/
                            This is totally free and is very powerful, it will take a little time to master but is worth the effort as it is capable of amazing results. All the bells and with the exception of one whistle (displacement) is included, and that last whistle is in the making so I hear.
                            IDX Renditioner: http://www.idx-design.com/IDX/IDXRenditioner/tabid/709/Default.aspx?gclid=CLrT09WjsZUCFRRhnAodHgk0kQ
                            Another easy solution and I believe there is some kind of special available or even a free version, This too is more than adequate for your emmediate needs and pretty simple to learn.
                            Good luck and please post as soon as you have something available.
                              diabloho
                              Solo,
                              Thanks for the quick response! I've tried the Kerkthea & Idx programs now, Idx crashes SU every time I run it and Kerkythea won't open the xml file apparently because it's in 3d. 😒
                              I'll try the plugins for su next, my boss wanted me to research this for a couple of hours.... I've been off the clock for 3hrs now. 🤢
                                diabloho
                                I may have a better idea than bringing in the surface and or the feature lines. I now have the polylines at 0 elevation and am connecting the different elevations in a crisscross design and then using the pull command to give the hill the required height. I’m not sure if this is the best way but it is producing results. 😍
                                • W
                                  wmanning
                                  Diabloho,
                                  Thanks for the heads up that IDX was crashing for you -- I assume that is the free version for PC. A few users have had that problem and we're expecting a fix to be released later today if you're interested.
                                  -- William
                                    Malert
                                    Hi my name is Mikhail, I new to the whole sketchup program as well as this forum and I just wanted to make sure that this was the right place for me to ask future questions about sketchup when I run into problems.
                                    • troyhomeT
                                      troyhome
                                      You bet it is... welcome to Sketchup (crowd cheers)
                                      IOviz.com
                                      SU Pro 2024 PC
                                      • C
                                        CameronVan
                                        Long time SU user.
                                        No longer a lurker here.
                                        Great site!
                                        • Chris FullmerC
                                          Cool, good to have you!
                                          • GaieusG
                                            Welcome, Mikhail and yes, this is the place.
                                            Also, glad you broke the silence, Cameron! 👍
                                            • 72
                                            • 73
                                            • 6 / 73
