    Lobby render
    19 Posts 10 Posters 1.9k Views 10 Watching
      ScottPara
      I can not pick the customer, money is money, no matter how it comes.
      Love the fact that some HATE my avatar.....
      • boofredlayB Offline
        boofredlay
        Nice Scott.
        I agree with stinkie that the lights are a bit hot.
        I do like the reflection in the glass on the far wall however, it answers the question... "What is behind me?"
          ScottPara
          I do agree with the lights as well. It was one of things that I had X amount of time to get this done so it is what it is. Something I will go back to correct though.
          Scott
            rcossoli
            render good, I agree with stinky, maybe the lights are too strong for such devices, but issues of taste, which surprised me is the rendering time, 25 is not much at all.
            I liked the tank 😄
            THREEDIMENSIONSWEB dot COM
              ScottPara
              Thanks. When it comes to render times, I think some people turn the settings far past what they need to be to get a good image and in turn render times go through the roof. Even the default setting will give great results in Vray. I typically start with the default settings and then just tweak them very little. This in turn will keep render times to a minimum.
              Scott
                ridix
                This was done for a client to show the tank graphic on the wall.
                If that is the case, you need to light the graphic with some type of lighting to highlight it. And turn down the room light a little lower. As the way it is, one is not quite sure if this image is about the room or the graphic on the wall.
                  JuanV.Soler
                  i agree
                  perhaps making a soft frame round the image would help too
                    Durant Hapke
                    Stunning Scottpara,
                    I'm digging this... Jack bird interesting.
                    Here's my deal about it, I would create a troff in front of the graphic that's about six feet wide -- from the base of the tank graphic out into the room -- then fill that with dirt and broken bottles.
                    You might want to propose that your client plant potatoes in said trench, as that would add some interesting textures to the mix.
                    It also might be nice to paint tread marks all over the floor, make them look like the hog just drive through.
                    Durant "fire a rocket at the LSD enemies" Hapke
                      ScottPara
                      Thanks Durante,
                      I love the idea of the trough but I think with the fire exit being right there that the building official would have a real issue with that. Maybe we could do something with the tracks on the floor though. That would be cool.
                      Scott
                      • W Offline
                        wmanning
                        Track marks on the carpet is a great idea. I'd love to see it.
                        -- William
                          JuanV.Soler
                          marck the FIREBOX
                          make it evident for you
                          and then get the answer
                            ScottPara
                            Juan,
                            I am completely lost by your comment.
                            Scott
                              JuanV.Soler
                              sorry Scott,
                              i think i missunderstood the fire exit comment you made.
                                tomsdesk
                                At first look the space seems expansively empty, but counting ceiling tiles I see it is the field of view and understand this shows the mural to best advantage. That said, I think the shadow on the floor and the matching reflection on the far wall pull the image together quite nicely...it might help to push those two items a bit more into prominence.
                                2.5D Trees & Shrubs!
                                  ScottPara
                                  Tom,
                                  Thanks for the nice comments. Yes, the camera angle is quite drastic but I really needed to get the wall into the image in full and add enough other existing detail for the client to really get a good feel as to how this big mural will affect the space. I will be reposting soon as the changed the image they want to use and I have updated the lighting as well. Hopefully I can get the new image done tuesday.
                                  Scott
