    No lights when rendering?
    extensions
    5 Posts 3 Posters 1.1k Views 3 Watching
    • N Offline
      NotCourse6
      All,
      I have a basic sketchup model where all surfaces are defined as "matte" material. I want to insert a series of 50W spot lamps in order to do a rough lighting study, but when I tell the plugin to render, the resulting scene shows the interior lit by SU's daylight but no light comes from the lamps. It doesn't look at all like the lighting examples on the wiki, and I don't know where to go next. There is no difference whether I use the "Interior w/ sun" or the "Interior w/o sun" settings. I am not sure what to do to fix this. Any recommendations?
      Thanks,
      -Ricardo-
        JuanV.Soler
        what does that mean ?
        is there interior lights now working inside SketchUp, only for a few little few ?
        or what is it about ? Al
        edit.-:
        sorry everybody , i did not know this was an specific place for Render Plus Systems
        • Al HartA Offline
          Al Hart
          IRender works with most of the light fixtures in the SketchUp components libraries. In addition, it has a wizard to create additional floor lamps and table lamps, based on shade and base choices, and size parameters.
          Also, you can use IRender to create light bulbs or spot lamps which can then be placed directly in the model, or placed in light fixture components.
          Finally, you can define any face, group or component to act as either a light source, or a spot light source. (Spot lights have a beam angle and a field angle and a direction).
          IRender is an add-on for SketchUp and support for IRender is provided here on the SUC Forum, and also on the AccuRender nXt Forum (nXt is the rendering engine used for IRender) ( http://nxt.accurender.com/ )
          Al Hart
          IRender nXt from Render Plus
          • Al HartA Offline
            Al Hart
            @notcourse6 said:
            All,
            Per Al's response on the forums, here is my sketchup model. I've probably missed something essential in rendering; do you all have a user guide prepared, perhaps in a pdf format? Thanks!
            Thanks,
            -Ricardo-
            Model
            The problem with this model is that you had turned the Ambient Light slider to 100%. This should have worked - but didn't. ( We will fix it. ) Slide it back to 50% or 90%. If you want to turn ambient light completely off, use the Ambient light radio box on the Sun/Sky tab.
            Documentation
            All of the documentation is on-line in our Wiki. We hope to create a PDF document sometime so it will be easy to print it out.
            This one talks about lights:
            http://wiki.renderplus.com/index.php?title=IRender_Tutorial_-_Lights
            and the basic tutorial adds some lights to a simple model
            Al Hart
            • Al HartA Offline
              Al Hart
              Send a .SKP model to
              http://wiki.renderplus.com/images/d/d3/Support-email.PNG
              and we will take a look.
              Al Hart
              With your input, this post could be even better šŸ’—
