    Small House 80m2 , WIP
    26 Posts 10 Posters 4.8k Views 10 Watching
      ridix
      Nice work. Every thing in small space needs to have multi function. The stairway in your concept is really taking up lots of space. Speaking of solar panel here is good link to get some ideas: http://www.solardecathlon.org/scores_standings.html#first
        Julius
        @ridix said:
        Nice work. Every thing in small space needs to have multi function. The stairway in your concept is really taking up lots of space. [/url]
        what do you suggest? a spiral staircase?
        • EddyNLE Offline
          EddyNL
          Thanks for the comments guys! πŸ‘
          The Kerky render is made using Section Pane in SU, first time I actually used it.
          Nice tool.
          I'll have to close those gaps in the walls, I'll keep that in mind.
          I know this type of staircase takes up a lot of space. I'd rather use a spiral staircase but I've tried creating one in SU but they alway end up crooked etc.
          How can I create a nice spiral staircase?
          Regards, Ward
          viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
          • utilerU Offline
            utiler
            nice start EduardoNL. You might check the head room on the 7th step though... might need a bit more head height about there...
            Just Curious...
              Do you mean Kerky (or rather the su2kt plugin) now supports section cuts? I didn't know that! I'll have to try it! πŸ‘
              Have a look at TIG's SectionCutFace plugin - it's a great tool to do this.
              Here are a couple of tutorials at the WareHouse:
              http://sketchup.google.com/3dwarehouse/search?q=spiral+staircase+tutorial&btnG=Search&styp=m
              • EddyNLE Offline
                EddyNL
                Thanks for the links Gaieus! I'll take a look.
                Concerning the render.
                I've made a section cut using the Section Pane in SU. Then exported the model to Kerky.
                  Hm. Interesting. I linked your render post in this topic and Frederik (of the KT Team) responded that you shouldn't be able to do this. 😲
                  • EddyNLE Offline
                    EddyNL
                    Ok, let me explain my method.
                    First I use section pane to cut out a part of the house.
                    Select everything still visible and make a group, hide this group and delete the section pane.
                    The only thing still visible is now "the cut" part, delete this and unhide the group.
                    That is how I got the model for the render.
                    Nothing fancy, just some grouping, hiding en deleting. πŸ˜‰
                    Regards,
                    Ward
                      Ah, OK, I now understand that it's not a "real" section plane. Thanks for making it clear.
                        dmatho
                        Section CutFace, as good as it is, doesn't work as well, for instance in the case of super-nested objects.
                        So, what to do? My advice is, color in the back faces with black. It works all the time πŸ˜‰
                        Cheers,
                        • d -
                        • RichardR Offline
                          Richard
                          I actually designed an 80sq,m (8x5 living / 8x5 bedrooms / and garage under 8x5) modular terrace house once and must say as others have pointed out the stairwell became an interesting imposition to the limited space. However the resulting spacial layout using some very space saving design became quite large.
                          It is interesting how you can get some very sizable rooms out of such a small space. The first we did of these (block of 6) were so popular to the market we searched for a allotments to site more. 6+7+6+22+7
                          [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                          • EddyNLE Offline
                            EddyNL
                            @Dmatho
                            Thanks for your tip.
                            That's pretty easy!
                            @Richard,
                            Do you have some renders maybe? I'd like to see your 80m2 house!
                            Got some new renders :
                            Walls in the section cut are now closed, or "thick".
                            Added a spiral staircase (found this one in the 3d warehouse)
                            And got some new furniture.
                            Larger image:http://img362.imageshack.us/img362/9748/15grootrf0.jpg
                            http://img300.imageshack.us/img300/9642/14ur4.jpg
                            http://img296.imageshack.us/img296/1655/17it2.jpg
                            http://img300.imageshack.us/img300/7349/16nm4.jpg
                            Any comments?
                              bubbalove
                              Yea... you need better textures... more segments on your models closer to the camera...softer shadows... and i hope you don't have any over weight friends cause I'm positive they would break those kitchen chairs in a heart beat! Not to be nit picking or anything πŸ˜‰
                              "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                              • EddyNLE Offline
                                EddyNL
                                Ok, I know where to get some better looking textures.
                                Can you tell me how to get some softer shadows?
                                As for the chairs... I don't have any overweight friends. 🀣
                                Family maybe... they will have to bring their own chairs!
                                  bubbalove
                                  If you are using kerkythea... change the radius dial and see what happens (i usually set mine around 20 for exterior renders)... you'll have to experiment to see what works best for you... make sure you have soft shadow checked too!... you may have to wait longer for clearer shadows but it is well worth it!
                                  Make sure you are in the sun setting tab!
                                  • utilerU Offline
                                    utiler
                                    pics, richard? would be interestd to see the outcome.... πŸ‘
                                    Just Curious...
                                    • utilerU Offline
                                      utiler
                                      cool, is the second photo a paint job of the original brickwork? Seemed there was a double order of teal green...
                                      Just Curious...
                                      • RichardR Offline
                                        Richard
                                        No rendering just some old photos. One of the brick ones were set up as a showroom and the agents sold the 22 off it in 2 weekends! Quite a success! They were designed about 12 years ago and the styling aimed at a slightly modern interpretation of an old Sydney Terrace House. Bit out of date now!!
                                        I'll try and dig out my old hand drawn plans and post all as a seperate thread.
                                        http://img528.imageshack.us/img528/6746/the61zh2.jpg
                                        http://img262.imageshack.us/img262/8053/the142smallbt8.jpg
                                        Couldn't find the old plans easily so here it is from memory.
                                        http://img529.imageshack.us/img529/9191/80m2townhousesmallwy4.jpg
                                        • RichardR Offline
                                          Richard
                                          Too right the developers very bad choice of colours! But doesn't look so bad in real life!
                                          • EddyNLE Offline
                                            EddyNL
                                            @Bubbalove
                                            Thanks for the tip, I'll try getting some softer shadows.
                                            There has to be storage somewhere. Could you not use the dead-space created by the stairs for this?
                                            Otherwise...interesting/appealing concept.
                                            Yep, going to create some storage near the stairs and on the first floor.
                                            Thanks for your comment.
                                            @Richard, interesting plan. Thanks for sharing.
                                            Can I use it for another 80m2 house?
