Broken Link To skp files
For some reason I can no longer download links to the attached skp files in the TUTs. All I get is the file.php and it appears the file id etc is not being correctly picked up. Don't know if I unknowingly made some change, don't think so, or if others have the same problem?
If you have an idea would appreciate hearing from you.
Thanks -
Sorry for wasting your time.
After several hours I finally decided to deleted my Free Download (older ver vs 2.5 present) Manager and this seems to have corrected problem. If re-occurs will re-post -
i did the same once
and after the integration of the Free Download Manager once again , it happened again,i discovered that saying no to the Free first dialog, and once looking like closed the download, it suddenly appears the option of saving normal in Windows.
The question was that the Free Download saves it as php or something, the way to do is to change in the options , the name to : --whatever-- .skp
Then it works ok.
I use both now
