    'Project Matchbox': 3D Car Modeler
    24 Posts 10 Posters 6.6k Views 10 Watching
      antantantant
      Oops. Did I attach anything? Here you go: MatchboxPlugin.zip
      • PixeroP
        Pixero
        Thanks, interesting. Just tried it and have a few comments.
        First my cars end up with the blue face "backside" outwards.
        Secondly I think it would be great with some more details like wheels and bumpers and such.
        Also some way to have usercontrol over the creation.
        Also I'm very interested in one of the sub scripts Bezier_surf.rb
        Would it be possible to have that also as a standalone script?
        Possible workflow could be to draw four connected beziercurves and a beziersurface would be created.
        Is this possible?
        • G
          geh4evr
          Max, this is a very interesting looking project, I think it's one of the best Ruby Scripts(In my Opinion) I've ever used. A Thing I think would enhance it would be a seed generator, so the Ruby script would output a certain random number for each vehicle it makes, that way if we wanted to make the same vehicle again, we'd just enter the seed.
            antantantant
            Thanks Pixero, πŸŽ‰
            The backside-out thing is my fault, but easy to fix. Also I'm with you about adding bumpers and wheels. However, I don't want to change the wheel design cos this whole thing is focused on the car body. What do you think? I plan to add user-control if the non-controllable interactive genetic algorithm turns out to be not convergent.
            Bezier_surf is from 'Victor Liu' on Google SketchUp group. I attached his standalone plug-in: bez-patch.zip (bez-patch.rb should be the entering point).
            My contribution to it is to make connected Bezier curve/surfaces have smooth tangent/curvature.
            -Max
              A very clever script.
              Suggested tweaks:
              Add a notifier or progress bar if it takes much longer (e.g. when additional tweaking is added)
              Flip the faces so that blue is inside (it's an easy normal swap)
              Make the sub-pieces into components, assemble these into a 'half-car' component and make the whole car a component from a pair of handed components.
              Make the window areas transparent, and add front/back lights, wheels, trim/handles, floor-pan, dash, steeringwheel, seats etc etc
              Add interactivity...
              Well done to date !
              • MarianM
                Marian
                Are you using a separate script for linking together multiple bezier curves? and if so can you release it as a separate ruby, it will also be very usefull for making cars.
                  antantantant
                  I'm sorry for the messed-up code. This is actually my first Ruby code anyway...
                  I link curves/surfs together in a way that they have continuous tangent or curvature. And I would like to release a separate ruby so that people can attach a curve to a existing one and make sure they linked smoothly. But I don't have a schedule for that... πŸ˜•
                    antantantant
                    I hit the button like crazy but nothing happens.
                    Hmmm.... That's weird. You should have one entering file "MatchboxPlugin.rb" and a folder with the same name. Do not move files out of that folder.
                    • MarianM
                      Marian
                      I had this idea of ruby generated cars for months but never uttered a word cause i'm a ruby ignorant πŸ˜› and i thought it would be impossible as there would many variables involved.
                      GOOD JOB antantantant
                      • C
                        Crazy Eyes
                        Great script, I am amazed with the possibilities, but I think it might need a re-write so we can alter the wheel well size. A 700mm wheel well just isn't big enough to fit the wheels nicely.Would it be too difficult to alter the script so the wheel well doesn't factor in the wheelbase?
                        Some people are lovers, some are fighters, if you love to fight, fight for love!
                          antantantant
                          Thanks Crazy Eyes,
                          That is a good question. Several parameters should be further linked with the wheel size. I'll fix them soon. Good observation!
                            Julius
                            wow! cool plugin! also i would suggest to generate the two halves of the car as components.
                            • RayOchoaR
                              RayOchoa
                              What does this plug-in really do?
                              CaR DeSiGnS bY mE
                              http://ray-ochoa.com
                              • ely862meE
                                ely862me
                                As Marian said we will be verry happy if u can put the "My contribution to it is to make connected Bezier curve/surfaces have smooth tangent/curvature." in a plugin.
                                making the contour;for more details more curves added
                                the plugin should do this
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                • majidM
                                  majid
                                  very cool plugin... thanx . i had some problem whit the BEZ plugin ... ( a message showing it doesn't uploaded )
                                  • RayOchoaR
                                    RayOchoa
                                    all it does for me is generate random cars. is that what its supposed to do? Nice plugin although it takes a bit out of using your imagination
                                    CaR DeSiGnS bY mE
                                      antantantant
                                      Thanks Ochoa. I'll say this is an alpha prototype and yes, that's all it does for now. From my opinion, Sketchup is not only a efficient tool to convey ideas MANUALLY, but also a promising way to create things using artificial intelligence, e.g. let SketchUp gradually learn what kind of cars people are looking for and generate them automatically, or build a house that has enough light in it but doesn't cost too much on the windows. What do you think? πŸŽ‰
                                      • RayOchoaR
                                        RayOchoa
                                        Well if you look at it like that i guess your right πŸ˜„ but if you look at my cars (well the recent ones anyway) I make them with mostly only one tool: the line tool and if you use it right it will get you some pretty good results. Oh and when i was using it sometimes it woulsd generate a car with the rear panel stretched out like an airplane so yeah.
                                        CaR DeSiGnS bY mE
                                          antantantant
                                          I checked some on the warehouse. Pretty awesome! But I cannot imagine building surfaces with line tool...how long does that take? I recommend Alias/Catia if you really enjoy building concept vehicles by hand. The current SketchUp will not bring you to the next level.
                                          I noticed that bug...and I hope you enjoy it along with all other bugs. πŸ˜‰
                                          • RayOchoaR
                                            RayOchoa
                                            lol finds a roach and says "BAM I GOT YOU!!!"
                                            Actually no, its not that hard. And its alot easier with blueprints. you just need to align the lines to the points in the drawing. It depends how experienced you are
                                            CaR DeSiGnS bY mE
