    ADVICE NEEDED Re: Running SU on PC & Laptop
    12 Posts 9 Posters 2.2k Views 9 Watching
    • GarethG
      Gareth
      Hi Solo,
      Yeh, I saw that suggestion somewhere in an old topic.
      The problem is that I need it to be fully functional so that when I arrive in my office after working at home, the whole thing will happen seamlessly...including setting up layouts etc.
      it's all about making these deadlines which seem to be more plentiful these days...!!
      • DanielD
        Daniel
        The user name, serial number, and authorization code used for the version of SU you have on your desktop computer can be used for installing the same version on your laptop. You can install SU on more than one computer, but can run only one instance of it at a time (unless you have a mutliple seat license).
        My avatar is an anachronism.
        • GarethG
          Gareth
          yes Daniel, i know......but what i dont know is how to get it from my PC to my laptop successfully, and easily.
            dylan
            Just download Pro 6 to your laptop and then add the serial details from your main computer.
            Once trial version is installed go to Help/License and add the required info to validate.
            Download SketchUp Here
            Edit:
            Looking into this a little further, im not sure if this is allowed running on two PC's.
            This is the Google link to be used for all License enquiries.
            http://sketchup.google.com/support/bin/request.py?customer=supro&contact_type=sales
            http://dmdarchitecture.co.uk/
              dudekracked
              hello gareth,
              i agree that you should download the sketchup pro version and just add the authorisation code after.
              while the settings from your main computer can be easily copy paste in the secondary computer using a usb or external harddrive. i usually store the settings on my usb like the components, materials, tools, plugins, and styles so i have a backup incase i have to work in a different place.
              • GarethG
                Gareth
                thanks...i'll try that idea....hopefully it doesn't conflict with the license agreement.
                I have actually asked Admin...but they havn't responded yet
                • GaieusG
                  The whole help centre at sketchup.google.com has been totally re-organised so I cannot find the part now but yes, I specifically remember that you can have SU Pro installed and licensed with your license key on several computers BUT you are not supposed to run them at the same time. It did specifically brought this particular example: your desktop at home (office - wherever) and your laptop to go out to the site.
                  • W
                    wyatt
                    Great advice...I was needing this question answered too.
                    Wyatt
                    • bazB
                      baz
                      I've just got my first laptop too and had no problems authorising su on it with my existing details.
                      What I am trying to figure out however is how to transfer my shortcuts and other preferences.
                      Any ideas?
                      Thanks in advance.
                      baz.
                      ps: its an hp 8610p. 2.5ghz 17"ws, nvidea quadro nvs320, and its a ripper:)
                      • Chris FullmerC
                        Sure, go to Window>Preferences and go to the shortcuts tab. Then click on export and save the .dat file somewhere like on a flash drive or a network location.
                        Then do the same on the laptop, but choose import instead of export. Good luck
                        PS There used to be a bug where commands that already had a shortcut assigned would'nt get updated correctly. I don't know if that was ever fixed or not, but I think it was....
