    Competition project
    22 Posts 11 Posters 3.4k Views 11 Watching
    • EdsonE
      Edson
      thanks, tina. i shall post more when the results come out.
      http://www.mahfuz.arq.br
      • Chris FullmerC
        Those louvres look like you're getting in touch with your inner Richard Neutra.
        • marked001M
          marked001
          cant wait to see the rest of the images...love the geometry of the louvers and the composition of the image.. (yes, definiltey work on the texturing of that exist'g building... )
          http://www.revision21vis.com
          instagram: revi21on
          • EdsonE
            Edson
            chris and jason,
            you soon will see that those louvers are at the same time sun breakers AND part of the structural system. instead of having columns every Xm i have many thin elements made of steel: the whole outer limit is load bearing. the idea was to create a sort of steel baloon frame. to be continued...
            • marked001M
              marked001
              gotcha.. kind of like the world trade center exterior columns? very cool....columns suck!
              instagram: revi21on
              • EdsonE
                Edson
                sort of, but hopefully not the same fate...
                • marked001M
                  marked001
                  well that's a given... i coudlnt think of any other 'known' buildings that used exterior columns besides one here in philly....so i had to use it.. haha.
                  instagram: revi21on
                  • DanielD
                    Daniel
                    An elegant design and beautiful image; good luck on the competition.
                    My only crit would be to add some people.
                    When I click on the image and see it at a larger size, the tiling of the pink brick(?) material on the left is not as obvious to me.
                    My avatar is an anachronism.
                    • EdsonE
                      Edson
                      well, now that the competition has ended (and i did not get anything) i can post some other picts here. more to come soon.
                      • T
                        tomsdesk
                        Edson, you design such comfortable large spaces: my hat's off!
                        2.5D Trees & Shrubs!
                        • T
                          tomsdesk
                          Bump...'cause it appears Friday's stuff isn't showing up in "New Posts".
                          • 2 / 2
