    IRender nXt - new version
    extensions
    2 Posts 1 Posters 1.2k Views 1 Watching
    • Al HartA Offline
      Al Hart
      New version 7/25/2008
      We have released a new IRender nXt
      This version:
      Uses a new extract logic which should have fewer freezes and bug splats.
      (Since this new logic has not been tested with everything, let us know if you see any problems)
      Added the use of a background image for the rendering.
      You can download the new version from:
      Page not found – Render Plus Software
      (www.renderplus.com)
      Notification:
      If you subscribe to this thread, you will receive a notification whenever a new version is released.
      http://wiki.renderplus.com/images/e/e1/Trophy1.jpg
      Previous Versions
      New version 7/1/2008
      • Creates softer shadows from lights - see Soft Shadows
      • Allows you to save the rendering with a transparent background - See IRender Alpha Images
      • Has new defaults for spotlight field angles, and thick glass. - See Defaults
      Plus numerous bug fixes and small improvements.
      New version 6/04/2008.
      • Has a much improved options tab dialog - making it easy to set the options you need most - Lighting defaults and render paramaters, while still keeping the power of the other options available.
      • Allows you to easily create a new material from our Select Material to Place dialog.
      • Improved the Materal Editor Texture tab functionality, allowing you to set the Color Strength when using AutoBump.
      • Fixed the watermark for Trial mode.
      Older versions:
      • Fixed the daylight portal problem introduced in the last release.
      • Fixed the Glow Type buttons and various other problems in the Material Editor.
      • Has a new Paint function to set materials on faces inside components with just one click.
      • Has an easier to use Material Editor.
      • Adds material properties - Daylight, Thin and Caustic to the Material Wizard
      • Enables the # of reflective and # of refractive bounces on the Special Options setup tab.
      • Add "Daylight Portals" to provide better lighting for interior scenes
      • fixed an error when loading the Light Fixtures dialog, when a point lamp was the last lamp placed.
      • updates the rendering progress message more frequently, and displays scanline number.
      • uses the new AccuRender nXt toolkit, which allows larger files to be processed.
      • lets you add plants and materials directly from the AccuRender libraries
      • make render with or without preview a toolbar icon choice - rather than a setting.
      • Fixes a problem which was causing sun and cloud intensity not to work.
      • Fixes a problem with gemoetry on Layer 0 in groups.
      • Combines lamps and light fixture into a single dialog
      • Uses better default for sharpness for mirrors and reflective objects.
      See: http://wiki.renderplus.com/index.php?title=IRender_nXt for information in IRender nXt
      See: http://wiki.renderplus.com/index.php...Latest_Release for more information on this latest release.
      Trial Version
      IRender nXt has a new 30 day trial version. If you have tried IRender before, you can have a new trial for Version IRender nXt
      IRender nXt runs from inside of SketchUp Version 6.0
      Al Hart
      IRender nXt from Render Plus
      • Al HartA Offline
        Al Hart
        We have uploaded the new version of IRender nXt, HH12a.
        You can download a copy from: http://www.renderplus.com/pdf/download.htm
        This version fixes a bug which prevented models using Object Properties from rendering properly.
        It also fixed some problems with the balance between Ambient Light and Natural Light
        See: Object Properties: http://wiki.renderplus.com/index.php?title=Object_Properties
        See: Ambient Light: http://wiki.renderplus.com/index.php?title=Ambient_Light
        Al Hart
