    Unfold.rb script: useful for UV-mapping?
    61 Posts 23 Posters 17.5k Views 23 Watching
    • FrederikF Offline
      Frederik
      Oohhh... I am goosey all over... 😄
      This sure looks like an awesome feature..!! 👍
      Would LOVE to have this in SU...!!!
      Cheers
      Kim Frederik
        Jim
        I have been following, but I don't know the first thing about UV mapping.
        http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/newuv_tb.jpg
        I'm not sure I understand how this image was created. I don't think it is a simple unfolding. Has there been some deformation of faces in order to close gaps?
          kwistenbiebel
          That image derives from (soft) selecting parts of a 3D human body model.
          The different selected groups (hands, head, etc...) are unfolded on their own so for each item a different texture can be made/edited in Photoshop. So the splitting up thing is user based. The smallest parts you see are finger joints, as they need refined Pshop maps applied etc...
          This example off course is the most complex one, where different parts of the model get unfolded seperately.
          Solos sphere demonstration (see his images)or Howardshongs apple are somewhat closer to daily use in SU I guess, but the principle remains the same.
          The '3D Pin method' earlier described would even make it much more WYSIWYG, as you can directly see the effect of moving a pin on the 3D surface.
          Stuff to think about 😉....
          • RichardR Offline
            Richard
            I think the two mapping techniques being discussed here are different or should be! the rewrapping versus pinned deformation!
            This function of wrapping and rewrapping is quite common to other modelling and texturing apps. Maybe someone with one of these could show example!
            BUILTBRAND.COM.AU
            • plot-parisP Offline
              plot-paris
              I think the multi-pin-method should be used throughout the whole texturin process (so that you can apply complicated distortions even to a simple rectangle shape).
              I like the idea to select the "2D Mapping" tool from the standart context menu for manipulating textures.
              if you simply select the 2D Mapping option and an unfolded copy of the object is shown, on which you can position your texture - when you are done, press enter and the only thing that remains is the perfectly textured 3D model (no manually unfolding and refolding geometry - very fast and easy workflow!) 😛
                sorgesu
                Because I just recently became interested in this subject, I found this on a search and I'm resurrecting.
                Further to the above speculations, I was thinking it would be great to be able to substitute a whole group of textures that are mapped to the subcomponents of a model,such as a person or a car for instance. That way, instead of providing the person or car in various colour verisons as an skp, all you need to do is substitute a material library on an existing model. If one must create a new skp for the same model, in a different colour, or maybe with some different detailing, when you create the variations you would have to go through mapping all the compoenets one by one again on the same model. Having a swap feature for the material "set" would be great.
                Susan Sorger
                Former Seller Hand Rendered Entourage
                Former Canadian Authorized Training Centre, SketchUp
                  sorgesu
                  okay, I found a ruby script on Didier's site: Global material changer.
                  It is almost doing exactly what I want. It replaces any one or "ALL" of a the materials on an model/component. But your choices for replacing are only with a single default material or something from the existing list. So how difficult to modify this so that you can replace with a material set that has some built in- one to one relationship to the existing materials? Maybe same name with a numeric modifier?
                  Susan Sorger
                    kwistenbiebel
                    Swapping is already possible, even with uv-sets in place (as long as the new bitmap has the same image size as the old one.)
                    Write down the dimensions of the existing texture (the dimensions specified in the material editor).
                    Then do the substitution from within the 'Entity layer' (NOT from material editor).
                    Next thing to do is going to the material editor and change the dimensions to the ones you wrote down.
                    It's tedious but it works.
                      sorgesu
                      NO swapping is not currently passible for ane entire "group" of materials all at once, which is what I was requsting.
                      Say I have a car component and it has 17 materials assigned to different portions of the car. I want those 17 materials defined as a "set" and I want another set containing a different 17 to be swapped in in one go.
                      Susan Sorger
                        kwistenbiebel
                        Indeed: No for groups of materials, Yes for ungrouped meshes containing 1 material.
                          RickW
                          Susan,
                          I'm working on it. 😄
                          RickW
                          www.smustard.com
                            sorgesu
                            OMG that's amazing. Thanl's a heap!!!
                            Susan Sorger
                              Phil Rader AIA
                              Rick can you get your 4 month old to help out with ruby coding and expedite the process..
                              http://www.philrader.com
                              • jujuJ Offline
                                juju
                                Now now Phil, all good things come to those who wait.
                                  linea
                                  Very interesting thread!!! I have some physical models I need to build for an exhibition, so this would be very useful but I can't get the unfold script to work on Vista, any ideas?
                                  Blender has the capability you are requesting, KB. Neatest part is where you can actually use painting tools on the unfolded map and then see them applied in the rendered viewport.
                                  I haven't used it in a while, but now that I've been given a little project with a certain degree carte blanche I was planning on testing all kinds of integrations with SU, Blender, and more obscure programs.
                                  Lewis,
                                  Please could you let us know how this goes, I have generally found Blender to work very well with SU imports/exports.
                                  • RichardR Offline
                                    Richard
                                    mate youi could do a search on the net for paper arch models. I know once there was a thread on the PPB about these and there was a link to an application that could output a flat plan unfold to produce a paper model from digital models....
                                    BUILTBRAND.COM.AU
                                    • jenujacobJ Offline
                                      jenujacob
                                      that would be Pepakura i suppose???
                                      http://www.tamasoft.co.jp/pepakura-en/
                                      • RichardR Offline
                                        Richard
                                        Thats the one mate!!!!
                                        BUILTBRAND.COM.AU
                                          linea
                                          Yes I have the free version of Pepakura and it's not bad, I made a fairly good Gherkin model with it("gherkin" is the nickname of a building in London called St Mary's Axe). But on more complicated geometry it doesn't do as well.
                                          • romboutR Offline
                                            rombout
                                            @solo said:
                                            Make a cone shape and then project the texture attached below to the cone from above view, notice it will map the shape of the cone perfectly without distortion.
                                            How did you do this trick, with PS think but how did came up with the idea.
                                            Ive got this mapping problem with this mesh. also trying to learn blender right know so i can use the UVmapping abbility
                                            • 3 / 4
