    PlayTime_02: Gothic Panel
    52 Posts 22 Posters 57.3k Views 22 Watching
    • simon le bonS
      simon le bon
      Dear all,
      I am particularly touched by your comments that I have learned a lot from almost each of you along those last months
      ;-)slb
      • G
        GreyHead
        Fantastic piece of work, congratulations. I have a lit clos in the sous-sol but it's not as elegant as this.
        Bob
        PS and greeting from the far west of Bretagne !
        • simon le bonS
          simon le bon
          Tips and ruby scripts i've used
          • You want a shape "on the floor" ?: Select it, Cut it (Ctrl+X), or Copy it (Ctrl+C), pickup the Move tool And Glue it (Ctrl+V) where you want: it's on the default floor..
          -in cleaning job it's usefull to show hidden geometry
          -you want a single shape in its 4 directions: put a construction point on it axis, select the shape, use rotate tool inferenced to this point, holding down Ctrl key to copy it,rotate it a quarter, and tape x3 in the VCB(value control box).
          -it's difficult to work on multilevel lines, project them on a face with Didier Bur's Projection tools.
          -use eraser tool to select easily a bunch of lines:
          Quick select edges using the eraser tool!
          -Cleaning is a really hard work, don't forget this technic:
          Searching the better way to split a shape in two.
          And with a very special thanks to our strong rubymakers who made so necessary additionnal tools to SketchUp: Here are the tools i have used in this work:
          Weld v.3.0 by Rick Wilson
          to fixe broken curves and make faces
          Mirror_31.rb by TIG
          Mirrors geometry at plane, line or point.
          Arc Centerpoint by Jim
          Right-click an arc or circle to insert its centerpoint into the model.
          Construction Line Tool by Jim (so handy)
          CurveStitcher v.2.2 by Rick Wilson
          Create edges & faces between two selected curves
          skin Version 2.2 D. Belvin
          A tool that takes selected edges and connects them, weither they are a closed loop or not.
          Dome 1.0 (for the pistil) by Frank Wiesner
          constructs a dome based on a circle (and interior)
          At last but not least: you can't pass over
          Projection tools v6 by Didier Bur
          Joint Push Pull - Visual Edition by Fredo6
          Without forget (!)
          Bezierspline Update 2.0 by Fedo6 (and additional Bezier Segmentor)
          How much it is as an integral tools pack of SketchUp
          What can i say more, just this: Dear SketchUp Community, you are so friendly, i like you.
          Zigmünd the good.
          • simon le bonS
            simon le bon
            Making of
            The Grid
            GP_TheGrid.skpDivShare__GP_TheGrid.skp
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TheGrid.jpg
            The Flower
            DivShare__GP_TheFlower.skp
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thflower.jpg
            Flowers in the Grid
            GP_FlowerIntheGrid.skpDivShare__GP_FlowerIntheGrid.skp
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thFlowerIntheGrid.jpg
            The DoubleEye
            GP_TheDoubleEye.skpDivShare__GP_TheDoubleEye.skp
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdoubleEye.jpg
            The Waread and the boxe
            DivShare__GP_TheWaread.skp
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thsim_2_340_dtl1.jpg
            The Panel
            DivShare__GP_ThePanel.skp
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ththePanel.jpg
            The wooden panel
            DivShare__GP_woodpanel.skp
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thpanneauGothique_f.jpg
            • simon le bonS
              simon le bon
              Additional fun in gothic travel:
              Have found this excellent tut from Jean Lemire on 3D Warehouse:
              Arche gothique par Jean (Johnny) Lemire
              ;-)slb.
              • P
                PKast
                What an awesome tutorial. You really disected this well. Great work!
                • simon le bonS
                  simon le bon
                  Goodmorning sketchy fellows. Jeudi 07 Août 2008
                  I'm on the road again.. for the "Central Panel" summer work.
                  My purpose is trying to deliver here a near of day by day step by step videotut.
                  For today i begin slow with just the challenge presentation: those two pictures.
                  http://i274.photobucket.com/albums/jj245/Spendauballet/BritainKiki/BritKiki_01_thumb.jpg
                  _ _
                  http://i274.photobucket.com/albums/jj245/Spendauballet/BritainKiki/BritKiki_05_thumb.jpg
                  As i was watching it very acurrately, i felt very surprised to discover that this panel certainly belonged to an older (very older?) furniture. Not only the different veining of the wood, but the carved work is more refined craft, and more damaged. We can therefore imagine that the entire buffet was built around this recovered sculpture. This gives it an additional price to my eyes.
                  If someone is tempted by the exercise, here's the needed zip pictures pack.
                  http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/zip.png
                  Britain Kiki.zip
                  Tomorrow (hope to): find the hidden geometry
                  :-)simonlebon
                  • pbacotP
                    oh my.
                    Impressive. Can't wait to go through the tutorial. thanks!
                    • GaieusG
                      Hi Simon,
                      Yes, it is fun and interesting! Looking forward to seeing how you advance.
                      • GaieusG
                        Nice one, Simon! I see that you weren't a perfectionist while cleaning up the geometry but it gives the idea nicely. 👍
                        • simon le bonS
                          simon le bon
                          Dear Gaieus,
                          I made this way, with a basic circle as a group and simple lines to refer on tools craftsmen were using in those times: ruler, T-square and compass, but no measuring instruments.
                          I made this way in mind to walk through there footprints. And i've drawn the canvas, just close to, to shaw with fun the idea was right.
                          I'm going right now to be extremely accurate to made the entire carved as shown in my avatar picture...
                          http://i274.photobucket.com/albums/jj245/Spendauballet/BritainKiki/CentralPanel_0_thumb.jpg
                          Going now to work on the next video, Simon.
                          • GaieusG
                            @simon le bon said:
                            ...With hope this long work has brought some fun and learn to some,
                            I definitely enjoyed it, Simon! Thanks! 👍
                            • simon le bonS
                              simon le bon
                              Thanks Gaieus, nice comment, 😉simon
                              • simon le bonS
                                simon le bon
                                And to close this "Summer Work", maybe it will be finding in this vast assembly some of our talented artists interested in making their way a smart rendering of it..
                                (something that neither I nor my poor PC are able to do.)
                                http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/grenou6.gif
                                :-)simonlebon
                                • simon le bonS
                                  simon le bon
                                  T-square and the compass
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Euclide.jpg
                                  Euclid 300 BC: The Euclidean geometry is the geometry of lines and circles. The Euclid intuition was that any number could be built with the help of these two instruments.
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/180px-Architectesmedievaux.png
                                  T-square and the compass were the only tools for architecs along more than 1500 years. very few measuring tools was available: rope knots and what else along those times.Elsewhere, units was varying greatly from one region to another. So construct a drawing was consisting, not report measurments but in dividing lines in segments, and reports segments with compass.
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Perpendicular_bisector.gif
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Bisection_construction.gif
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/equerre_compas2.jpg
                                  The compass was, during this infinite laps of time, the mystic instrument throwing up a bridge between human being and the divine. It knowledge was kept jalously and its secrets only learned from master to disciple..
                                  %(#800000)[But today, Everybody (if he want to with just some strong will 😉) can get this knowledge relatively simply.]
                                  Ruler and Compass Constructions by Ken Brakke
                                  I believe that: one time the first grid was drawn, in matter to define the elemental unit of the drawing,in fact the radius of the elemental circle, the compas was fixed for the all work. And everything was drawn with this value. This way was very opérative for the construction itself because each point could be report with a rope knots as real radius measurement decided at the begining.
                                  I believe also that secret construction points was left in the construction in order to let workers follows themselves in time. A cathedral construction was during easily 100years...
                                  (Sorry for DivShare too much advertising, but it's for better sharing)
                                  DivShare_searching for the GothicPanel Geometry_1.skp
                                  Or on our SCF[attachment=0:1pyo0qjz]<!-- ia0 -->fingGeometry_1.skp]<!-- ia0 -->[/attachment:1pyo0qjz]
                                  • EarthMoverE
                                    EarthMover
                                    First time seeing this......
                                    Wow, what a gem this tutorial is! Thanks for all the work you put into this Simon. I learned a lot! 👍 👍
                                    Content Creator at Skapeup
                                      d12dozr
                                      Ditto that, Adam...makes me wonder how many other treasures are buried here, many I'm sure ☀
                                      Excellent tuts, Simon!
                                      http://goo.gl/f7ooYh
                                      • ely862meE
                                        ely862me
                                        Elisei (sketchupper)
                                        Come and See EliseiDesign
                                        • EscapeArtistE
                                          EscapeArtist
                                          Beautiful work and a great tutorial. I'm a big fan of Gothic/Medieval architecture, stone- and woodwork. I'll definitely be putting this to use.
                                          Thank you!
                                          • simon le bonS
                                            simon le bon
                                            Hi EarthMover, D12DozR, Ely862Me, EscapeArtist, 😄
                                            You make me happy 😉
                                            You simply brought this former work out of the grave where I was thinking it was resting in peace! (It had been surely a very important work for myself.)
                                            Since time have passed I think a bunch of fantastic new tools should be used today to simplify the accomplishment of this work..
                                            But the quest of the hidden drawing may stay still actual..
                                            (have you drop an eye on this discreet link into the second post? but shhht! this is destined to the few)
                                            I'm sad to not find enough cool time to draw and to post actually. Also because I'm trying to learn rendering... 😕
                                            But I still read the forums and watch for individual works 👍
                                            With my sympathy, ++simon.
                                            • 1 / 3
