    [Re-quest]
    16 Posts 5 Posters 2.0k Views 5 Watching
    • CadFatherC
      CadFather
      Thanks Jim... i will try not to move from the chair.. πŸŽ‰
        Jim
        CadFather,
        I sent you the plugin via a PM. I don't want to distribute it to the public in it's current state.
        I can shine it up if you or anyone thinks it is worthwhile.
          Daniel S
          @jim said:
          It should be easy to modify to use a timer instead of an event.
          Do you think that can work with SketchyPhysics? I mean.. create something like 25 scenes per second?
          Daniel S
            Jim
            @cadfather said:
            is it possible to automatically save a scene every second?
            Hehe, I totally misunderstood the request! CadFather wants to add a scene to the model at a timed interval. I wrote the plugin to save an image of the view at a timed interval.
            It's no problem - just need to change one, maybe 2 lines...
              Jim
              Daniel S
              It can be made to function like that, but I can't say if it would work. I can only just run SketchUp, let alone SP on this old computer.
              Did you mean for it to save images, or add scenes?
                Daniel S
                The idea will be that the plugin add scenes, so maybe we can use the sketchup output to export the scenes as animation.
                And this can make possible to render every scene and have a photoreal sketchyphysics animation.
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=61&t=8582&p=51274
                Daniel S
                • CadFatherC
                  CadFather
                  Jim, it does works like a charm - fantastic - Thank You! πŸ˜„
                  EDIT: ok, it seems to suspend 'while using' the space navigator: when you fly, the pages are not saved, as you stop flying, they start saving again..
                    Jim
                    I'm not sure if there's anything I can do about that. 😞
                    It works for me when using the Walk and Look tools. On a small, simple model at least.
                    • CadFatherC
                      CadFather
                      Jim yes, works just great πŸ˜› without the space navigator 😒
                      but that means half of my wish has already been granted! πŸ˜„
                      Edit: [now i just wait for sketchup 7 inbuilt flight simulator. after all google earth has it..]
                      • K
                        kwistenbiebel
                        Would it be possible to make this ruby available for public.
                        That would be great !
                        • CadFatherC
                          CadFather
                          i second the idea of automatic camera recording (if it works with space nav).
                          and if all the created cameras can be joined by a polyline, even if their number exceeds sanity - the polyline can be tweaked with the bezier tools and scenes recreated with flightpath
