    Home Generator+ 100kW 180A@ 400V - Off the Grid
    41 Posts 11 Posters 2.6k Views 11 Watching
      Ross Macintosh
      OT: Looks like Thinkpath has had a rough time on the market. Down to a penny a share now. ๐Ÿ˜ž
      Modelhead I hope your life-savings weren't invested in it.
      --- Ross
        tomasz
        @goon of doom said:
        ecologically speaking batteries are not good. As for the Zero point topic Data can be misleading. If you factor the sum total of its parts vs the projected service life what most fail to acknowledge is the agrigate total after the manufacturing process in some cases is way worse than the supposed gains.
        I will explain how I understand principles of SURGE TECHNOLOGY motor. All parts are assembled this way that they minimise friction due to usage of a magnetic field to separate moving parts. The only force required to run this motor forever (ok, say 25+ years ๐Ÿ˜„ ) is the force to spin the rotor fast enough to allow magnetic field keeping it spinning for a loooong period. Please note there is NO friction between parts. Everyone knows it well that you require very little power to keep something in motion.
        Goon, you have mentioned batteries. They are not necessary. Please check video USA2. The inventor is spinning it just with his finger, then he uses the additional motor powered by low voltage battery to accelerate it to a required speed. It can be accelerated using same mechanism say like in a bicycle. It doesn't matter - even if electricity is required it can come from renewable source. ONCE ENGINE IS SPINNING IT WILL RUN FOR A LOOONG TIME. I am amazed - it would mean that the car Troy Reed is running on this motor can travel continuously along whole USA without charging!!! ๐Ÿ˜ฒ
        I can still hardly believe it is a truth, but there are too many samples of similar devices. I probably build my own one - so simple as in USA sample, just to verify it (I like physics ๐Ÿ˜„ ).
        Tomasz
          tomasz
          EDITED: Gathered all important samples together + one above.
          USA
          http://youtube.com/watch?v=qaCk0jK--8s
          USA - 2nd example
          http://youtube.com/watch?v=jt5z8L4LBJE
          Hungary\Canada
          http://youtube.com/watch?v=vDeXTXYFKAY
          This is also worth seeing.
          FAST ELECTRIC HEATER - Efficency = 170% ??!!
          http://youtube.com/watch?v=yh_-DUKQ4Uw&feature=related
          http://youtube.com/watch?v=V0M2GnQluJk&feature=related
            gaganraj
            unless it is in a vacuum it is impossible to have a system with no friction, there is always some... however minimal.
              tomasz
              You are right. Friction is minimised. Like in a levitron:
              http://www.youtube.com/watch?v=iv8msBamA3M
                tomasz
                It is definitely better to buy one off then to let him die in 'mysterious circumstances'.
                  Rodentpete
                  A side matter, but do you have any idea how many people would lose their jobs if this were to be mass produced? We're talking about the people on the oil platforms, pump station personnel, etc. It would mean a total nightmare for the economy. And this comes from a guy (me) that would like to see this invention be used as well. But the fact remains, many will lose their jobs. And who wants that?
                  I imagine that the amout of oil used for fuel is quite a small proportion of total use in manufacturing/Chemical plants, lubricants, plastics and the like - there will always be a demand for oil.
                    tomasz
                    I closely watch samples of companies and individuals who develop technologies based on permanent magnets.
                    There are too many of them claiming same achievement.
                    This is a company which wanted to develop a system helping to power CCTV cameras and they have come to same scientifically unexplained results.
                    They have challenged scientist to test the company's findings.
                      tim
                      Not even then. If you use 'magnetic bearings' then there will be magnetic drag. In the ultimate there will be gravitic frame dragging! It's really simple - you can't extract work from a system for long without something replenishing it. If you take any of these perpetual motion machines and extract any energy at all from them they will run down and stop.
                      And that by the way includes tidal power since it requires energy that is extracted from the earth/moon system. So far that energy extraction has increased the size of the moon's orbit very dramatically (it's currently figured at about 3.8 cm a year) and slowed the Earth's rotation (by about 20uSec/year). Humans building tidal barrages will accelerate that process.
                        tomasz
                        CANADA
                        Xogen - oxyhydrogen generators from the tap water with low electric power
                        and wast water treatment systems.
                        It can be powered from photovoltaic cells.
                        http://www.youtube.com/watch?v=pXo7CVFI5Sk
                        http://www.xogentechnologies.ca/
                        EUROPE
                        The Perendev company has started to sell the magnetic motors!
                        100Kw 180.63 amps@ 400 volt 3 phase
                        PRICE: 24 700 Euro ex tax and Delivery ...
                        ๐Ÿ˜’
                        It is more then sufficient to run more then a single dwelling!
                        ๐Ÿ˜ฎ
                        http://www.perendev-power.com/
                        They has presented oxyhydrogen generation at the level sufficient for a small car requiring 12V 10A electricity drawn from a car battery.
                        http://www.youtube.com/watch?v=FGR9JNH90_4
                        We are witnessing the birth of new energy sources. ๐Ÿ‘
                        It is highly encouraging. โ˜€
                        • 3 / 3
