    Zoom Selection
    36 Posts 10 Posters 8.0k Views 10 Watching
    • PixeroP
      Pixero
      Mine does.
      JS Zoom Selected at http://www.pixero.com
      • CadFatherC
        CadFather
        even when the entities inside are selected (highlighted)?
        • PixeroP
          Pixero
          It zooms into what ever is selected. As its name says. 🤓
          What do you want it to do? Zoom into the unselected open group?
          • Alan FraserA
            Alan Fraser
            I've got Jim's version, available from this forum, but it does the same thing...zooms to any selected faces in an open group.
            3D Figures
            • CadFatherC
              CadFather
              if i select something inside of a group it does not work - but will fit the contents to screen if nothing is selected. 😎
              all i'm doing is edit geometry inside the group..
              EDIT i take it open group means inside of it - what about comps?
              [can't seem to replicate it now but when modeling complex stuff it always happens]
              • PixeroP
                Pixero
                What do you mean with "It doesnt work" ? What do you want it to do?
                If you are inside a group the group itself isn't selected.
                My script zooms in to whats selected. Inside group or not.
                • CadFatherC
                  CadFather
                  it happens especially with large models [most of mine are]
                  if i am inside a group and i select an entity, when i press zoom the selected entity is not zoomed to screen. if i deselect then the contents of the group will fit to screen
                  now that is strange right?
                  • CadFatherC
                    CadFather
                    ok, this is what happens to the script: if i am inside of a group/component and 'hide rest of model' is on, zoom selection does not work. surely this must happen to everyone?
                    • T
                      TonyF
                      I've just tried it.
                      When Hide similar components is checked, it works fine.
                      When Hide rest of model is checked, it ignores the selected entity and zooms to the origin.
                      Must be a bug.
                      I guess we just need to select, then zoom, then hide.
                        Matt666
                        Unfortunately, we can't control "hide rest of the model" via ruby....
                        Frenglish at its best !
                        My scripts
                          Matt666
                          Oh !! I have found a script can control this function !! Thank you Jim !
                          Sketchup.active_model.rendering_options["InactiveHidden"] = !Sketchup.active_model.rendering_options["InactiveHidden"]
                          The code is ready guys !
                          Context menu...
                          My scripts
                          • CadFatherC
                            CadFather
                            Sir Matt!!! 😍 😄
                            • W
                              watkins
                              Dear Matt,
                              How does your script work?
                              Regards,
                              Bob
                              • N
                                N Lindenthal
                                @Matt
                                Zoom selection works great.
                                My question is, how it would be possible not to zoom, but to scale. A door would zoom to screen, a door handle would scale.
                                @watkins
                                select a group/component/item, right mouse click > »Zoom on selected«. The selected item fills the screen
                                • W
                                  watkins
                                  Thank you for the instructions.
                                  • N
                                    N Lindenthal
                                    @Matt
                                    Maybe my questions was not understandable.
                                    I would like not to zoom all selected items, but to see them from the near with same distance, so that a door or a door handle is shown with same scale in the middle of the screen. Is that possible with »Zoom Selection«?
                                      Matt666
                                      Hi N Lindenthal !
                                      Ok I see ! I don't know if it's possible. I will see. 😄
                                      My scripts
                                        Matt666
                                        Try this, and tell me what you think about !
                                        Context menu "Zoom sel 2"
                                        My scripts
                                        • CadFatherC
                                          CadFather
                                          Matt, a couple of bugs i think - when i am inside a group and i select a face, SU zooms to the face but hides all other geometry inside the group (!) - second (even worse) is that after i zoom, i can't do anything: the cursor is the selection tool but it actually doesn't work..it's in some kind no tool suspension. thought you'd be glad to know! 😮 😄
                                          • N
                                            N Lindenthal
                                            @CadFather
                                            Your list of mistakes I could verify. But with right mouse click I could leave the marked object.
                                            @Matt
                                            Is there a difference to zsel.rb?
                                            I look to your Zoom Selection, because I look for a way to find objects in my SU-model by name by dragging them in the middle of screen with even same distance. Looking distance for example even 200 cm. This way, all found objects are shown with same scale.
