    Zoom Selection
    36 Posts 10 Posters 5.7k Views 10 Watching
    • CadFatherC Offline
      CadFather
      does anybody else finds that the great Zoom Selection does not work inside of groups?
      • PixeroP Offline
        Pixero
        Mine does.
        JS Zoom Selected at http://www.pixero.com
          CadFather
          even when the entities inside are selected (highlighted)?
          • PixeroP Offline
            Pixero
            It zooms into what ever is selected. As its name says. 🤓
            What do you want it to do? Zoom into the unselected open group?
            • Alan FraserA Offline
              Alan Fraser
              I've got Jim's version, available from this forum, but it does the same thing...zooms to any selected faces in an open group.
              3D Figures
                CadFather
                if i select something inside of a group it does not work - but will fit the contents to screen if nothing is selected. 😎
                all i'm doing is edit geometry inside the group..
                EDIT i take it open group means inside of it - what about comps?
                [can't seem to replicate it now but when modeling complex stuff it always happens]
                • PixeroP Offline
                  Pixero
                  What do you mean with "It doesnt work" ? What do you want it to do?
                  If you are inside a group the group itself isn't selected.
                  My script zooms in to whats selected. Inside group or not.
                    CadFather
                    it happens especially with large models [most of mine are]
                    if i am inside a group and i select an entity, when i press zoom the selected entity is not zoomed to screen. if i deselect then the contents of the group will fit to screen
                    now that is strange right?
                      CadFather
                      ok, this is what happens to the script: if i am inside of a group/component and 'hide rest of model' is on, zoom selection does not work. surely this must happen to everyone?
                        TonyF
                        I've just tried it.
                        When Hide similar components is checked, it works fine.
                        When Hide rest of model is checked, it ignores the selected entity and zooms to the origin.
                        Must be a bug.
                        I guess we just need to select, then zoom, then hide.
                          Matt666
                          Unfortunately, we can't control "hide rest of the model" via ruby....
                          Frenglish at its best !
                          My scripts
                            Matt666
                            Oh !! I have found a script can control this function !! Thank you Jim !
                            Sketchup.active_model.rendering_options["InactiveHidden"] = !Sketchup.active_model.rendering_options["InactiveHidden"]
                            The code is ready guys !
                            Context menu...
                            My scripts
                              CadFather
                              Sir Matt!!! 😍 😄
                              • W Offline
                                watkins
                                Dear Matt,
                                How does your script work?
                                Regards,
                                Bob
                                • N Offline
                                  N Lindenthal
                                  @Matt
                                  Zoom selection works great.
                                  My question is, how it would be possible not to zoom, but to scale. A door would zoom to screen, a door handle would scale.
                                  @watkins
                                  select a group/component/item, right mouse click > »Zoom on selected«. The selected item fills the screen
                                  • W Offline
                                    watkins
                                    Thank you for the instructions.
                                    • N Offline
                                      N Lindenthal
                                      @Matt
                                      Maybe my questions was not understandable.
                                      I would like not to zoom all selected items, but to see them from the near with same distance, so that a door or a door handle is shown with same scale in the middle of the screen. Is that possible with »Zoom Selection«?
                                        Matt666
                                        Hi N Lindenthal !
                                        Ok I see ! I don't know if it's possible. I will see. 😄
                                        My scripts
                                          Matt666
                                          Try this, and tell me what you think about !
                                          Context menu "Zoom sel 2"
                                          My scripts
                                            CadFather
                                            Matt, a couple of bugs i think - when i am inside a group and i select a face, SU zooms to the face but hides all other geometry inside the group (!) - second (even worse) is that after i zoom, i can't do anything: the cursor is the selection tool but it actually doesn't work..it's in some kind no tool suspension. thought you'd be glad to know! 😮 😄
