    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 26.0k Views 32 Watching
      remus
      Couldnt you just spray the components and then place the sky dome?
      • jujuJ Offline
        juju
        I've moved the surface on which I want to spray above the sky dome, but it is still not working as expected.
        The surface is in a group, the group is active and I am able to select the surface and make changes to it. The spray tool keeps on returning an error about there not being a surface onto which to spray (not so, there is) tried up to 3000 tries.
        Still trying to get the component of choice onto the list to pick from (which component to spray).
        I'm working through the manual again to see if there is anything I missed.
        • Didier BurD Offline
          Didier Bur
          Oh oh,
          It seems that I have missed some particular situations (sky dome).
          I have totweak the script, and implement the layer mask feature.
          Next release coming...today.
          @Juju: you didn't miss anything... me yes.
          DB
          • jujuJ Offline
            juju
            Merci le bureau principal. Vous êtes l'homme !
            (Thank you master Bur. You are the man!) - thanks to Babelfish translation.
            • jujuJ Offline
              juju
              @didier bur said:
              Oh oh,
              Didier, any news on this?
              +++ EDIT +++
              No bother, found the updated script. THANKS!
                Didier Bur
                Hi Juju,
                Did you d/l last version from 04.11.08 ? Perhaps you missed it.
                (2nd post of page 1 of this thread).
                I thought it would work 😒
                DB
                  a4chitect
                  missed that one too! eager to try it out, thanks didier!
                  • jujuJ Offline
                    juju
                    @didier bur said:
                    Hi Juju,
                    +++ EDIT +++
                    Didier, thanks for the follow-up. Yup, found it shortly after posting the comment, thus I edited it as above.
                    I have not tried it again, will do so later on and report back (obviously) if I experience any difficulties.
                      Jorgensen
                      Any plans on creating a toolbar for this nice script ?
                        Didier Bur
                        Why not ? Nice idea.
                        DB
                        • E Offline
                          el.antuan
                          I agree.
                          "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
                          • majidM Offline
                            majid
                            if i was MR GooGle , i would give a nice job to Didier!!! plz accept my special thanx
                              Jorgensen
                              Could it be possible to set % less than 5% ?
                              1%
                              5%
                              Custom ?
                              Jorgensen
                              • StinkieS Offline
                                Stinkie
                                That'll be € 20, mate. A copywriter needs to eat too. 💚
                                As do the nice folks who write all them cool Ruby scripts. I don't have a problem with people selling their scripts through Smustard. I mean, most of them are pretty cheap - and they can sure add a lot to SU's functionality.
                                Look at this way: if a lot of these cool, non-free scripts were incorporated in SU, SU's price would go up. At least now you can choose whether you want to spend more or not.
                                  kwistenbiebel
                                  Oh, I don't have a problem with commercial scripts either and Smustard is a good place to buy them.
                                  From time to time though, a plugin stands out from the rest and feels like it could be part of Sketchup itself.
                                  I can imagine that a native Sketchup plugin written in C++ (or whatever the code language they use) can be streamlined more than a ruby, which works 'on top' of sketchup.
                                  (difference in speed and performance?)
                                  • StinkieS Offline
                                    Stinkie
                                    Good point. The first one, I mean. Dunno 'bout the second one. Mee stoopeed.
                                      kwistenbiebel
                                      Agreed.
                                      This is a plugin that deserves its place in an official Sketchup built.
                                      Sometimes I like my French Fries with ketchup and not mustard, if you get what I mean.
                                      • StinkieS Offline
                                        Stinkie
                                        I'm trying to use this fine plugin to spray some grass clipmaps around. However, I keep getting this message (paraphrasing): 36589 4578 9821 thingies will be created. In short: the numbers are off the chart. Seems to be a file-specific thing. Could this be scale related?
                                          Hi Stinkie,
                                          AFAIK that's "only" a warning about possibly too many polygons. As I remember, Didier wrote somewhere that you can go on - just maybe SU will never finish the job.
                                            remus
                                            As you said it mght be the scale, so check that first.
                                            Other stuff to check: spay density, might be able to lower it down a bit to reduce the number of thingies.
                                            edit: too quick for me gai.
                                            • 2 / 5
