    So Frustrated with SU
    43 Posts 15 Posters 6.5k Views 15 Watching
      Rudbeckia
      @chango70 said:
      My model is 42 MB on very similar spec laptop to yours.
      Do you have problems with 42mb?? How can our computers have the same specs and I have problems with 9mb and you can run 42mb??
      Modelhead: what do you mean by "post" the model and I will get better??
      I understand it takes time to become a SU expert, but the models I am working on are simplistic compared to what I will be working on, I am debating about wether to put anymore time into learning SU, several students in my program are debating the same thing, if I can't learn the program on a laptop I have, I need to do something else, I have never had a problem with Cad on my comptuer. The desktops at school dont run SU smoothly either. I have also heard the Architecture students bitching about SU.
        Rudbeckia
        Is there a way to put the model on here so someone can take a look at it and tell me if I am crazy?
        I have tried to upload it twice and I guess I am doing something wrong.
        • Mike LuceyM
          Mike Lucey
          zip it first
            Rudbeckia
            The model is to big even when zipped, here is a photo of it though.
            COTA_1_7.25.08.zip
            • K
              kwistenbiebel
              You didn't make a mistake in learning Sketchup. It still is the fastest modeler around.
              A 9 Mb file shouldn't produce too much of a speed drop. (I sometimes work on SU files +100 Mb)
              Sketchup does have an issue handling larger polycounts (which needs URGENT adressing by Google !), but I think in your case something else is wrong.
              When using a new PC it is very important to search for the latest drivers for your graphical card.
              This can increase performance quite a bit. Best look at the official Nvidia website to download the latest.
              For some laptop graphical cards you will need to go to an 'unofficial' site to get the latest drivers.
              http://www.laptopvideo2go.com/ is a good resource for that.
              If upgrading GPU drivers doesn't help, browse this forum as there are a lot of threads on optimising editing speed.
              There is currently one active here:
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=11590
              I hope this helps.
              Regards,
              Kwistenbiebel
              • K
                kwistenbiebel
                @rudbeckia said:
                I guy in my class just got a brand new $3000 mac and he can not run SU smoothly, and he has the required specs the SU gives.
                I am working on a MacPro octocore as well (Vista).
                After updating the graph card (I really suggest you start with that) Sketchup runs quite well, except for the typical speed drag every SU user experiences on complex files and which can be a pain.
                A 9 Mb should not pose a problem on your laptop though, as long as you respect the workarounds to keep the editing speed up.
                (layering, shadows 'off', textures 'off',using components instead of groups of the same geometry, etc....)
                The largest file I ever worked on was 128 Mb. I managed editing it as long as I turned all the bells and whistles to 'off'. Since I not ever use straight sketchup output (I always run my model trhough a render engine), I hardly ever put on 'shadows' and I only leave materials 'on' when I am texturing.
                  Rudbeckia
                  Why would I need to update the graphics card on a brand new computer? Shouldnt the graphic cards it came with work?
                    Rudbeckia
                    @chango70 said:
                    I use 8600m GT without too much problem. I have the latest graphics driver. the default graphics driver kept crashing. Anyway it is 175.5 it think and its from http://www.laptopvideo2go.com website. You see the driver is actually for desktop and you need to run a mini-crack to install it on your laptop. There are clear instructions on how to do that on the website. Just follow it you should be fine. btw the latest Graphics card on Macbook Pro is also 8600M GT so you really shouldn't have a problem.
                    Chango- I can't find the 175.5 driver at that website, do you know where else I might could find it?
                    • Mike LuceyM
                      Mike Lucey
                      From what I can see of that model, I don't think it should
                      be any larger than a 2-3Mb!
                      Have you selected Use Hadrware Acceleration?
                        Rudbeckia
                        Yes I have done that. What would make the model so much larger than it actually should be?
                        • Mike LuceyM
                          Mike Lucey
                          Rudbeckia,
                          Poor use of components and groups also watch your 'texture' sizes.
                          Mike
                          • Mike LuceyM
                            Mike Lucey
                            .... if you can't figure out what's making the model heavy,
                            break it up into three or four models and see where the Gbs
                            are 👍
                              Rudbeckia
                              Thanks for the help everyone, I know whats making this particular model slow, the plants and the building, I guess where my frustration is, is that the overal all model is not large at all, it is a rooftop , I will soon be working on city parks for school, and I am kinda feeling like unless I want to purchase a $4000 computer, SU isnt going to run right.
                              And another thing, one of my favorite aspects of SU is the "sketchy styles" that you can mix and match, but heaven forbid I use those b/c the whole computer crashes and I have to turn it off.
                              Thanks for letting me vent 😄
                              • K
                                kwistenbiebel
                                The drivers I meant
                                  Rudbeckia
                                  @kwistenbiebel said:
                                  The drivers I meant
                                  Sorry, I guess I am just a computer idiot, but why would the drivers need to be updated on a brand new computer?
                                    remus
                                    A lot of the time the drivers supplied with the computer are pretty old, i guess the manufacturers just dont update their versions very often.
                                      remus
                                      If the models too bug to upload here you can upload it at the 3d warehouse. 10mb limit 👍
                                        jhauswirth
                                        The drivers I meant
                                        Because the drivers MS ships with Windows don't support OpenGL.
                                          Rudbeckia
                                          We can only speculate without the model.
                                          Post(upload) the model....we will look at it and tell you how to improve it...and you will get better.
                                          A picture is not much help.
                                          I had a peek at the picture....if I can see from a picture that there is clean up work to do then the model will have a lot to tell.
                                          Okay it is in th 3d warehouse. Search roof gardens, the title is Soho Terrace. If you, or anyone, could please tell my why you think it is so slow, I would be so thankful!!
                                          http://sketchup.google.com/3dwarehouse/details?mid=f260a33a3e35bc2e35c37fa9135eadf3&prevstart=0
                                          • GaieusG
                                            OK, I had a look at your model (it's actually only a bit less than 5 Mb). The problem is not in the file size since you use a lot of plant components and all - its that there are 600,000 edges and 220,000 faces which all count up to performance issues. I see that you cleverly put the different plants, people and furniture (where you anso have some high poly ones) on different layers. Now why not turn the visibility of these layers off while working on other parts of the model? That's the whole idea actually in using them during modeling!
                                            Apart from updating your video driver to a better one (which everyone here keeps suggesting), note that edges (more exactly geometry generally) is mostly supported by the processor and if you have a fairly decent but definitely not very powerful 2.4 GHz processor, it can slow down considerably even with a seemingly small model. I have a model that is only about 6.7 Mb but has more than twelve million edges and of course my old desktop cannot cope with that so I never turn everything on unless I export either 2D or 3D from it.
                                            • 1 / 3
