    Select all geometry
    29 Posts 6 Posters 3.6k Views 6 Watching
    • fredo6F
      Which error do you get?
      • N
        N Lindenthal
        @Fredo6
        This is my ruby script »Aar_Select_comp_by_name.rb« in the Plugins folder:
        def select_comp_by_name(comp_name)
           model = Sketchup.active_model
           sel = model.selection
           sel.clear
           compdef = model.definitions[comp_name]
           if compdef  #There is a component
              sel.clear
              sel.add compdef.instances
           else
              UI.beep
        #def select_comp_by_name(comp_name)
        #@sel = Sketchup.active_model.selection
        #@sel.clear
        #@sel.add Sketchup.active_model.definitions[comp_name].instances
        #@sel
        #end
        If I repeat loading by ruby console:
        load "Aar_Select_comp_by_name.rb"
        then come the following notes
        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:6: warning: parenthesize argument(s) for future version
        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:7: warning: parenthesize argument(s) for future version
        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:8: warning: parenthesize argument(s) for future version
        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:10: warning: parenthesize argument(s) for future version
        true
        … but also »true«.
        Now with ruby script line
        Sketchup.active_model.definitions["Stein"]
        I get
        nil
        and with
        > select_comp_by_name("Stein")
        Error: #<NoMethodError: undefined method ` ' for main:Object>
        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:2
        (eval):197
        … nothing is selected.
          Matt666
          Hi !
          Your script works fine here... Be careful with case of the definition name... I found no error in your script...
          Perhaps some parenthesis
          sel.add(compdef.instances)
          and unnecessary duplication
          sel.clear
          Erase the second duplication.
          Frenglish at its best !
          My scripts
          • N
            N Lindenthal
            @Matt666
            Thanks for your corrections.
            When your script runs fine, in the end you have the component "Stein" selected?
              Matt666
              I tried with a component called "essai" created before. I had five components, and they had been all selected in the end.
              Can you upload an example I can test, please ?
              My scripts
              • N
                N Lindenthal
                Matt, here is my model to select a component by name "Stein"
                FahrstuhlF.skp.zip to selcect component by name
                  Matt666
                  Ok I understand your problem...
                  I have made a component called "test". Entity info window looks like this :C.jpg
                  With your component, entity info window looks like this :c1.jpg
                  The script search for component with definition as ["Stein"]. But your component definition is called "<gruppe#4> in the Skecthup database. His NAME is "Stein".
                  3 methods :
                  • Create a component directly, without create a group first. Your first ruby script will work.
                  • Change your ruby script, and don't change your method.
                    Try this in the ruby API :
                  Sketchup.active_model.definitions.each{|d|return d if d.name == "Stein"}
                  This code returns the name of the component definition which called "stein"
                  And the ruby script :
                     sel.clear
                     compdef = Sketchup.active_model.definitions.each{|d|return d if d.name == "Stein"}
                        sel.clear
                     else
                        UI.beep
                  • Add a line in ruby which control name of all component definitions if C definitions not found...
                    Like this :
                  	sel.clear
                  	compdef = Sketchup.active_model.definitions[comp_name]
                  	Sketchup.active_model.definitions.each{|d|return d if d.name == "Stein"} if not compdef
                  	if compdef
                        sel.clear
                     else
                        UI.beep
                  Not tested, but it sould work !
                  Tell me if you want more explanations
                  My scripts
                  • N
                    N Lindenthal
                    @Matt666
                    I did understand you. First changes did not delete my error. Hm? What could it be?
                      Matt666
                      Oops !! 😳 A little bug !!
                      In fact, name is linked to the component, not to the component definition.
                      So you have to search around all the component in the drawing to select component with specific name, if no component definition have this specific name....
                      Like this :
                      	sel.clear
                      	if compdef = Sketchup.active_model.definitions[comp_name]
                      	else
                      		Sketchup.active_model.active_entities.each do |d|
                      			if d.typename == "ComponentInstance"
                      				sel.add d if d.name==comp_name
                      		if sel.count == 0
                      			UI.beep
                      		else
                      			UI.messagebox(sel.count.to_s + " entities found.")
                      My scripts
                      • N
                        N Lindenthal
                        Qui!
                        Now your script runs, Matt666. My component is selected by name/definition. As it is selected, I can »Get Position - X« (Proper_animation.rb from RichW).
                        Matt666, you have my elevator model with arrow buttons. With Links.rb the arrow up buttons will select the elevator and »Get Position - 2«. The arrow down buttons will select the component elevator and then »Get Position - 1«.
                        But my question is, whether I can start a ruby.rb script by clicking a button.
                        • 2 / 2
