    Select all geometry
    29 Posts 6 Posters 3.6k Views 6 Watching
    • N
      N Lindenthal
      @Fredo6
      This is my ruby script »Aar_Select_comp_by_name.rb« in the Plugins folder:
      def select_comp_by_name(comp_name)
         model = Sketchup.active_model
         sel = model.selection
         sel.clear
         compdef = model.definitions[comp_name]
         if compdef  #There is a component
            sel.clear
            sel.add compdef.instances
         else
            UI.beep
      #def select_comp_by_name(comp_name)
      #@sel = Sketchup.active_model.selection
      #@sel.clear
      #@sel.add Sketchup.active_model.definitions[comp_name].instances
      #@sel
      #end
      If I repeat loading by ruby console:
      load "Aar_Select_comp_by_name.rb"
      then come the following notes
      /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:6: warning: parenthesize argument(s) for future version
      /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:7: warning: parenthesize argument(s) for future version
      /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:8: warning: parenthesize argument(s) for future version
      /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:10: warning: parenthesize argument(s) for future version
      true
      … but also »true«.
      Now with ruby script line
      Sketchup.active_model.definitions["Stein"]
      I get
      nil
      and with
      > select_comp_by_name("Stein")
      Error: #<NoMethodError: undefined method ` ' for main:Object>
      /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:2
      (eval):197
      … nothing is selected.
        Matt666
        Hi !
        Your script works fine here... Be careful with case of the definition name... I found no error in your script...
        Perhaps some parenthesis
        sel.add(compdef.instances)
        and unnecessary duplication
        sel.clear
        Erase the second duplication.
        Frenglish at its best !
        My scripts
        • N
          N Lindenthal
          @Matt666
          Thanks for your corrections.
          When your script runs fine, in the end you have the component "Stein" selected?
            Matt666
            I tried with a component called "essai" created before. I had five components, and they had been all selected in the end.
            Can you upload an example I can test, please ?
            My scripts
            • N
              N Lindenthal
              Matt, here is my model to select a component by name "Stein"
              FahrstuhlF.skp.zip to selcect component by name
                Matt666
                Ok I understand your problem...
                I have made a component called "test". Entity info window looks like this :C.jpg
                With your component, entity info window looks like this :c1.jpg
                The script search for component with definition as ["Stein"]. But your component definition is called "<gruppe#4> in the Skecthup database. His NAME is "Stein".
                3 methods :
                • Create a component directly, without create a group first. Your first ruby script will work.
                • Change your ruby script, and don't change your method.
                  Try this in the ruby API :
                Sketchup.active_model.definitions.each{|d|return d if d.name == "Stein"}
                This code returns the name of the component definition which called "stein"
                And the ruby script :
                   sel.clear
                   compdef = Sketchup.active_model.definitions.each{|d|return d if d.name == "Stein"}
                      sel.clear
                   else
                      UI.beep
                • Add a line in ruby which control name of all component definitions if C definitions not found...
                  Like this :
                	sel.clear
                	compdef = Sketchup.active_model.definitions[comp_name]
                	Sketchup.active_model.definitions.each{|d|return d if d.name == "Stein"} if not compdef
                	if compdef
                      sel.clear
                   else
                      UI.beep
                Not tested, but it sould work !
                Tell me if you want more explanations
                My scripts
                • N
                  N Lindenthal
                  @Matt666
                  I did understand you. First changes did not delete my error. Hm? What could it be?
                    Matt666
                    Oops !! 😳 A little bug !!
                    In fact, name is linked to the component, not to the component definition.
                    So you have to search around all the component in the drawing to select component with specific name, if no component definition have this specific name....
                    Like this :
                    	sel.clear
                    	if compdef = Sketchup.active_model.definitions[comp_name]
                    	else
                    		Sketchup.active_model.active_entities.each do |d|
                    			if d.typename == "ComponentInstance"
                    				sel.add d if d.name==comp_name
                    		if sel.count == 0
                    			UI.beep
                    		else
                    			UI.messagebox(sel.count.to_s + " entities found.")
                    My scripts
                    • N
                      N Lindenthal
                      Qui!
                      Now your script runs, Matt666. My component is selected by name/definition. As it is selected, I can »Get Position - X« (Proper_animation.rb from RichW).
                      Matt666, you have my elevator model with arrow buttons. With Links.rb the arrow up buttons will select the elevator and »Get Position - 2«. The arrow down buttons will select the component elevator and then »Get Position - 1«.
                      But my question is, whether I can start a ruby.rb script by clicking a button.
                      • 2 / 2
