    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 29.4k Views 32 Watching
      kwistenbiebel
      Even when that message pops up, clicking 'ok' will work.
      It will drop a handful objects and immediately the same message will pop up.
      Click ok again will drop a lot more objects....Again the message... now click cancel as with that next iteration it WILL drop the millions and your rig will explode ๐Ÿ˜„.
      • StinkieS Offline
        Stinkie
        Thanks, lads. "Spray density", that's "pressure", right?
        • soloS Offline
          This brings me to a question I was asked over google talk the other day and never had an answer for, maybe someone here has one.
          What is the poly limit, or how many faces/ polygons have you been able to reach before SU said enough is enough?
          • StinkieS Offline
            Stinkie
            Hmm, as far as I can remember, I haven't had any "poly overkill" splats just yet. Slow downs, yes. Splats, no.
              Well, Pete, that's really machine dependent. At the old forums there was a file to test this with scenes and with more and more (face me) components in it. As people advanced along the scenes, their computers were dying respectively but of course it was not the same for everyone.
              If there is an "absolute" limit - well, I don't know...
                remus
                Youve probably got it already pete, but heres the crowd test. Just keep going through the scenes untill SU stops.
                just as a reference, i got to scene 10 with some minor stuttering, scene 11 was very slow...
                Id guess this is gettign a bit old now, we need an update up to 20 scenes i reckon.
                Crowd_Test.skp
                • StinkieS Offline
                  Stinkie
                  Hello, youngsters!
                  I got me another problem. I'm trying to spray rectangles with a grass mat on a mesh. Everything's fine as far as the "horizontal" part of the mesh is concerned, but when I spray the comps on the sloping part, they end up beneath the mesh.
                  Here's some screenies:
                  http://img337.imageshack.us/img337/4354/berm1xy3.th.jpg
                  http://img337.imageshack.us/img337/8491/berm2qe6.th.jpg
                  http://img93.imageshack.us/img93/842/berm3uv3.th.jpg
                    Autokidd
                    Maybe im missing something, but it is sayin i dont have the permissions to download the file you have posted, it sounds like an interesting tool and i woul dlike to access it, any suggestions?
                      Autokidd
                      Just kidding now that i posted that i suddenly have the permissions
                        GhossbGood
                        Thank's for this plugin...it's very helpfull
                        ๐Ÿ˜
                        ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                        • jujuJ Offline
                          juju
                          @rv1974 said:
                          Hi Didier!
                          May be it was discussed earlier ..
                          1.There are 2 bugs: the plug-in limits drop-down list of components (for example 290 in model is reduced to 10 in dialog).
                          2.drop-down list is not stable: drop-down list of components is visible only if down arrow
                          is continually pressed.
                          Thanks for attention.
                          For the some or other reason the grass component I want isn't showing up in the drop-down list for components to spray. I've renamed the component so the name starts with a "#" as well as with a "01" in an attempt to get it to surface to the top of the list, but it still isn't showing up.
                          Does anybody have any idea how to get components onto the list that isn't showing up?
                          Didier, I'm still having trouble with components not showing up. I have 30+ components in a model, yet the plugin only recognises 5, excluding the component I want to use to spray!
                          • R Do not disturb
                            rv1974
                            Workaround:
                            Take the host surface and cut&paste to a new blank file and complete your dirty deeds there.
                            There's other problem- the script is highly buggy (of course may be my hands simply are growing from the @ss)
                            1/In most cases I can't complete circle\rectangle input.Simply can't.
                            2/Even if I have luck it tries to spray 809234803924789789798 components (with lowest pressure and normal radius).
                            The only reason I didn't throw it away is the point mode.It's pretty predictable and stable.
                            • Didier BurD Offline
                              Didier Bur
                              What's the difference between the 2 kinds ? (imports, DXF/DWG, own library vs SU library, etc ?)
                              Check out the surface of your components. If it's a grass sprig, you're likely to get millions of them...
                              Of course.
                              DB
                              • jujuJ Offline
                                juju
                                @didier bur said:
                                Hi Didier, maybe I didn't express myself clearly. It shows only 5 of the 30+ components, did not mean SU version 5 components. In the meantime, I'm using the workaround suggested.
                                  Didier Bur
                                  Hi Juju,
                                  yes , I've understand that. Could you send me the file with the components, so I can see which one is shown and which one is'nt, because there MUST be a difference between such compos.
                                  Regards,
                                  DB
                                  • jujuJ Offline
                                    juju
                                    The file seem to be 10MB large already. I could try to shave some stuff off to leave you with the basics... Let me have a look. I'll send you a PM.
                                    • R Do not disturb
                                      rv1974
                                      @didier bur said:
                                      Of course.
                                      I'd be happy if you Didier could help me straighten my hands a little )
                                      Here's spray.skp
                                      http://www.mediafire.com/?ozzdmv9cplx
                                      I can't spray component#2 at all.
                                      With component#3 I get notice about zillion iterations.
                                      What do I wrong?
                                      P.S. After posting I finally understood ๐Ÿ˜› The plug simply doesn't work with 2d stuff (no matter linework or faces)- 3d only. Could it be fixed? 2d dummy components are good for keeping the file size light in modeling stage.
                                      • plot-parisP Offline
                                        plot-paris
                                        it happened to me several times too, that the script only allowed you to select some of the components in the model.
                                        when I made the components unique, these new comps where shown in the component spray window.
                                        ps: didier, have you seen this? ๐Ÿ˜‰
                                          Didier Bur
                                          Sure: density is based on bounds calculations, and 2D components have a depth of zero and a height of zero. This give either a floating domain error (when dividing by zero) or zillions of instances to drop.
                                          This can be fixed. Next release will accept 2d components.
                                          I'm still searching why some components don't appear in the dropdown lists. I cannot reproduce the error for now.
                                          And for the "too-big-list-of-50+-components-that-goes beyond-the-screen", there's no slider options for such lists. We need to ask for sliders for version 7 ( ๐Ÿ˜• ) of the API, OR use webdialogs.
                                          @plot-paris: interesting, this is what Majid asked for.
                                          DB
                                          • jujuJ Offline
                                            juju
                                            Hear ya' on the sliders request Didier. How abbout if we could be able to type in the name of the component if it doesn't appear on the list. Currently that functionality isn't supported, but could be another workaround... Just trying to think a little laterally.
                                            • 3 / 5
