    Some of my works
    409 Posts 95 Posters 133.8k Views 95 Watching
      russellbeta
      crud, I've just bought SUpodium and ideally would need to make a walkthrough, a 2-3minute one with lots of lighting, detail and possibly moving section cuts.
      its a hugely detailed model of a timber frame house, here, i'll post an image πŸ˜„
      http://img168.imageshack.us/img168/6772/example2ns4.jpg
      I've still to import alot of things I've prepared for it, plasterboard, all the rooftiles, flooring, the plot, pool, foundation layers and reinforcements and so on, oak cladding, wall ties, patio/masonry details,... it goes on and on plus i've quite a few layers like the fireplace, furniture, plumbing/drainage and so on hidden in the model above. in short the model will have pretty much everything apart from the screws/nails/individual electrical cables. I've even prepared a model of myself to put into it for kicks πŸ˜„
      dunno if it is actually feasable to animate something with this kind of complexity because I've never seen a sketchup model so detailed.
      maybe i should make a seperate thread for this topic πŸ˜›
      • orgelfO Offline
        orgelf
        yes may be πŸ˜‰
        but it is amazing that you posted this here because I have exactly the same questions on a project i think about . It 's a building, and, as yours, something "big" with details and I wanted to make a kind of "movie", a camera that flies around it and shows us the outside and the inside .... in the sketchup scene (without colours or textures , just the shadows from the sun), but I didn't know if that is possible so...I don't know ....let's see if we will have an answer here but may be the best for your project (and mine) is that you create a new thread !
        http://www.orgelf.com
          russellbeta
          A movie showing just a sketchup render with the shadows from the sun is really easy,
          here http://www.youtube.com/watch?v=rCNGQX6j7D4 that will teach you how to make the animation.
          just incase it doesnt tell you this info:
          when you've made a scene you can right click on it it and open the page scene manager, which gives you alot of control.
          good luck πŸ˜„
          • orgelfO Offline
            orgelf
            β˜€
            thank you so much for that link !!! πŸ‘
              huhu
              Animation in Sketchup can be made also with many plugs πŸ˜„
              Sketchyphysics2 😲
              Transformer by D Bur β˜€
              and the last more exiting 'in french link)Proper animation by Morisdov who mix animation of objects and animation scene 😲 😲
              • plot-parisP Offline
                plot-paris
                by the way: I am not aware of any render engine that supports SketchUp sections.
                section planes are merely a display featyre in SketchUp and have no effect whatsoever on the geometry therefore they are not exported to a render engine. (please correct me if I am wrong - would love to have a renderer that does sections (SketchUp section export I mean)...
                • orgelfO Offline
                  orgelf
                  thanks for your replies, I think I will use animation for the next one .*
                  this time I would like to show you a strange news item that happened in the Excalibur's church . I was looking at the building
                  http://i36.tinypic.com/2qb9ds5.jpg
                  http://i36.tinypic.com/111ijj4.jpg
                  http://i36.tinypic.com/14kutmg.jpg
                  http://i36.tinypic.com/2jcxxmq.jpg
                  http://i38.tinypic.com/14wyn0g.jpg
                  http://i35.tinypic.com/1zw2owg.jpg
                  http://i36.tinypic.com/k4eao9.jpg
                  the cloyster
                  http://i38.tinypic.com/5b4ciq.jpg
                  http://i36.tinypic.com/egbgoz.jpg
                  http://i36.tinypic.com/esox09.jpg
                  http://i38.tinypic.com/14ayjdd.jpg
                  http://i34.tinypic.com/mhpm39.jpg
                  the Excalibur's pedestal and Excalibur itself
                  http://i33.tinypic.com/e658jm.jpg
                  http://i38.tinypic.com/2vwgqhw.jpg
                  http://i34.tinypic.com/11t3708.jpg
                  When I begin to hear screamings ...
                  [img:2hy6crr3]http://i33.tinypic.com/2rw3wgp.jpg[/img:2hy6crr3]
                  [img:2hy6crr3]http://i36.tinypic.com/f1l4bk.jpg[/img:2hy6crr3]
                  [img:2hy6crr3]http://i35.tinypic.com/35n5xyv.jpg[/img:2hy6crr3]
                  a kind of giant fly appeared in the middle of the tourists !!!
                  [img:2hy6crr3]http://i38.tinypic.com/2rr1jih.jpg[/img:2hy6crr3]
                  [img:2hy6crr3]http://i38.tinypic.com/30uady1.jpg[/img:2hy6crr3]
                  and ...I...can see something in the sky ....
                  [img:2hy6crr3]http://i34.tinypic.com/33ma4hw.jpg[/img:2hy6crr3]
                  is it a bird ??? is it a plane ???
                  [img:2hy6crr3]http://i37.tinypic.com/1o80p4.jpg[/img:2hy6crr3]
                  NO !! IT'S SUPERMAN !!!!!!!!
                  [img:2hy6crr3]http://i38.tinypic.com/2rvzcdh.jpg[/img:2hy6crr3]
                  πŸ’š
                    plot-paris
                    what a wonderful story, orgelf!
                    only thing to change: in some images shadows obscure parts of your model. try to lift the whole model up until it's lowest part is at the hight of the origin. thus you can prevent parts of the model being below SketchUp's ground plane (because shadows stop at this level).
                      The new Sagrada Familia πŸ˜‰ 😎
                      • orgelfO Offline
                        orgelf
                        @plot-paris yes I saw that 😒 .I always forget to check the shadow on the ground ... Next time I will be carefull πŸ˜‰ .
                        thanks
                        the "batcave"
                        http://i34.tinypic.com/nmnqiw.jpg
                        http://i33.tinypic.com/5amknq.jpg
                        http://i38.tinypic.com/6jprmt.jpg
                        http://i38.tinypic.com/30mr0v7.jpg
                        http://i33.tinypic.com/11c8d9c.jpg
                        http://i34.tinypic.com/2dbuykz.jpg
                        http://i34.tinypic.com/10ym8t4.jpg
                        http://i37.tinypic.com/10r0qo5.jpg
                        http://i38.tinypic.com/2coque8.jpg
                        http://i37.tinypic.com/16ih5xl.jpg
                        http://i34.tinypic.com/vrrarc.jpg
                        http://i36.tinypic.com/1zpr775.jpg
                          princedragoncok
                          Fantastic, nice detail, great imagination. Looking forward to seeing your animation!
                          • orgelfO Offline
                            orgelf
                            thanks princedragoncok πŸ˜„ for my next one , I will try to do a "meca", I am not sure of the name in english . it's a kind of war robot .
                            and to make an animation with it πŸ˜‰
                            but for today I made the fight between spider amazon and spiderman .
                            the story:
                            spider amazon arrived on earth with her carousel (yes I know πŸ’š )to destroy her ennemy, spiderman . she made a giant web in the city and captured an innocent victim (me actually, that's my avatar I made with sketchup, but you can see it entirely at my website http://www.jphurel.com/). she asked her cross-bow robots to slow spiderman with their arrows while she , as a sniper , shoot him .
                            the "buildings" and the "spider amazon" are 2 works I did few weeks ago . I did the carousel and all the "little stuff" for this story .
                            once upon a time in a forest ...
                            mmh no πŸŽ‰
                            http://i35.tinypic.com/15i9anq.jpg
                            global views
                            http://i38.tinypic.com/2s5z6dd.jpg
                            http://i33.tinypic.com/2v0h5p4.jpg
                            http://i33.tinypic.com/bf2hxd.jpg
                            http://i38.tinypic.com/egwm4g.jpg
                            something is wrong in the city ...
                            http://i33.tinypic.com/2mcg8dg.jpg
                            http://i33.tinypic.com/29ndugh.jpg
                            http://i37.tinypic.com/24bjcqt.jpg
                            http://i35.tinypic.com/mjwsx4.jpg
                            http://i35.tinypic.com/2603247.jpg
                            http://i36.tinypic.com/sy19gk.jpg
                            spiderman ...
                            http://i36.tinypic.com/2r4mrmo.jpg
                            http://i34.tinypic.com/mk8494.jpg
                            http://i37.tinypic.com/23l00zo.jpg
                            the bad guys :
                            the carousel
                            http://i33.tinypic.com/j12cdk.jpg
                            [img:1557wzsf]http://i36.tinypic.com/294tqw9.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i38.tinypic.com/18hezq.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i38.tinypic.com/14m5ohv.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i35.tinypic.com/2vb3rcy.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i33.tinypic.com/m9op47.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i38.tinypic.com/wj6hye.jpg[/img:1557wzsf]
                            the croosbow robots
                            [img:1557wzsf]http://i33.tinypic.com/65nzsz.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i35.tinypic.com/1z4hbpv.jpg[/img:1557wzsf]
                            the spider amazon
                            [img:1557wzsf]http://i38.tinypic.com/2laps2g.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i36.tinypic.com/eb8t3b.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i33.tinypic.com/4pxuzs.jpg[/img:1557wzsf]
                            [img:1557wzsf]http://i36.tinypic.com/2wdygdv.jpg[/img:1557wzsf]
                            • MALAISEM Offline
                              MALAISE
                              Quite impressive drawing SciFi androides ! πŸ‘ πŸ‘
                              How long did it taken for such a work?
                              MALAISE
                              La Connaissance n'a de valeur que partagΓ©e
                              • orgelfO Offline
                                orgelf
                                thanks πŸ˜„
                                the buildings and the spider amazon are works I did 1 month ago . But for the all scene,including buildings and spider ama , it takes about 36 hours .
                                • orgelfO Offline
                                  orgelf
                                  I just wanted to put some volumes made with "Topmod" (the tree and the sun)in a little scene .
                                  and as I won't make a render for this one, I drew some lines , the peacok's tail and the stairs .
                                  http://i37.tinypic.com/2eknhwy.jpg
                                  http://i36.tinypic.com/16ljmhc.jpg
                                  http://i38.tinypic.com/5nr6dh.jpg
                                  http://i38.tinypic.com/s30m6g.jpg
                                  http://i36.tinypic.com/30jr4w4.jpg
                                  http://i33.tinypic.com/2ir5j7s.jpg
                                  http://i35.tinypic.com/5fovn4.jpg
                                  • orgelfO Offline
                                    orgelf
                                    made with sketchup and makehuman
                                    it's a kind of divine entity ...
                                    http://i35.tinypic.com/35mfxw5.jpg
                                    http://i36.tinypic.com/2sba24l.jpg
                                    http://i36.tinypic.com/2uiir1j.jpg
                                    http://i36.tinypic.com/dnkm5c.jpg
                                    http://i36.tinypic.com/2yvnbd0.jpg
                                    and a rendering made with the matcaps of zbrush and photoshop
                                    http://i34.tinypic.com/2l8j96r.jpg
                                    http://i38.tinypic.com/nznhb7.jpg
                                    thanks for your comments πŸ˜„
                                    • orgelfO Offline
                                      orgelf
                                      mmh not exactly the kind of comments I expected ... Can anybody erase that
                                        bubbalove
                                        I'm sure one of the moderators will take care of it once they see it!
                                        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                        • orgelfO Offline
                                          orgelf
                                          thanks James πŸ˜„
                                          • orgelfO Offline
                                            orgelf
                                            hello everybody
                                            something Imade with the sketchup that I posted few days ago .It's now a part of a magic weapon .
                                            the sculpture is made with zbrush, makehuman, topmod and sketchup .
                                            rendering with matcaps and PSP .
                                            http://i35.tinypic.com/1z1tilw.jpg
                                            http://i35.tinypic.com/rm41ll.jpg
                                            • 20
                                            • 21
                                            • 3 / 21
