    [Plugin] HouseBuilder metric 1.2
    79 Posts 42 Posters 111.9k Views 42 Watching
    • Didier BurD Offline
      Didier Bur
      TIG is right, and as I said at the top of this thread: "this must-have developed by Steve Hurlbutt (and me for the toolbar, estimates, metric versions)".
      That's why it has been developed in feets first.
      In France most houses use bricks, dont they?
      Yes and no, it depends where the house is: bricks in the North, natural stone almost everywhere, concrete and concrete blocks in suburban areas, wood in the south-west and in all mountainous areas.
      Regards,
      DB
        AcesHigh
        thanks.
        Living in Brazil, where woodframe is almost non-existant, I use only the roof function of it, since many roofs from brick/concrete houses are done with wood frame/trussers, whatever 😄
        [AcesHigh]
        • aadbuildA Offline
          aadbuild
          Hi all, I have been following the thread with house builder and I am having problems loading house builder as well. I am using a P.C and I have dropped house builder in the plugins folder and when I start Sketchup I come up with the following message:
          No such file to load -- HouseBuilder/HouseBuilderTool.rbError Loading File HouseBuilder_extension.rb
          (eval):36:in `readlines': No such file or directory - C:/Program Files/Google/Sketchup 6/Plugins\HouseBuilder\housebuilder_sections.txt
          I have tried sevral variations but I have had no luck. Is there any one who could steer me in the right direction. I am looking forward to see what house builder can do. Your help will be much appreciated. 😄
          Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
          https://www.plusspec.com
            Didier Bur
            if you have correctly unzipped the package in your Plugins folder, there should'nt be any problem.
            Check that you have:
            • HouseBuilder_extension.rb in your Plugins folder
            • a sub-folder named "HouseBuilder" with 2 other .rb files in it and a lot of png's and gif's as well. A .txt file is also there, with the wood sections listed in it.
            Read the readme.txt file for further details.
            DB
              abumail
              Dera Didier,
              Your Script is very useful and funny,
              I have a doubt about the timber (beam) on top of the windows and door.
              If i put door or windows it's result vertical, Shouldn't be horizontal?
              Thank you in advance for your kind attention,
              Giovanni
              • AnssiA Offline
                Anssi
                Giovanni,
                I think it is a matter of both local convention and structural strength. When I was taught about framing (half a zillion years ago) I was told to put the beam vertically. So from my point of view this should be correct.
                Anssi
                  Didier Bur
                  I agree with Anssi.
                  But I want also say that it is NOT my script. The original was coded by S. Hurlbutt, I only tweaked it to metric units and parametric sections...
                  DB
                    dayakar78mac.com
                    @didier bur said:
                    Hi Didier,
                    I have unzipped HouseBuilder_metric_12.zip in the Plugins folder. The HouseBuilder_extension.rb and sub-folder "HouseBuilder" are there as described by you. When I launch SketchUp, I still get the following error.
                    "Error Loading File HouseBuilder_extension.rb private method split called for nil:NilClass"
                    Could you please advice me to resolve this issue.
                    I am using SketchUp Pro v6.0 on iMac, Mac os x 10.5.4.
                    Thanks,
                    Dayakar
                    Error Loading file
                      Didier Bur
                      I'm puzzled because the "split" method is called several dozens of times in the code so I can't localize exactly where there's something wrong at startup. Maybe it's a Mac issue. Do you have a file "housebuilder_sections.txt in the HouseBuilder folder ? I guess yes...
                      Give me some time to search...But take a look at the top of this thread, other people on Mac have the same issue as yours.
                      DB
                        pav_3j
                        wow, thank you very much! this is awesome
                        pav
                        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                          dayakar78mac.com
                          @didier bur said:
                          Hi Didier,
                          Thank you for the response. Yes, I do have have housebuilder_sections.txt in the HouseBuilder subfolder. This script is very useful, I saw the demo of this script at http://sites.google.com/site/3dbasecamp2008/all-sessions-2008/maxing-out-your-productivity-with-ruby-scripts.
                          Regards,
                          Dayakar
                            thinkbuild
                            Greetings to all.
                            Didier, just a quick note - I just wanted you to know that I am also having the same issues with my mac.
                            private method `split' called for nil:NilClass"
                            Any ideas?
                            I tried to look for the "offending line" in the script but I quickly became confused. Is it "HouseBuilder_extension.rb", (which is not scrambled)
                            or "HouseBuilder.rb", or "HouseBuilderTool.rb" (both of which are scrambled)?
                            Please advise. I'm sure many of us in the Mac community would be very appreciative if we could get this to work!
                            cheers from Berlin,
                            Jason
                              Didier Bur
                              It is probably in "HouseBuilder_extension.rb" there.
                              I suspect this line is the offending one:
                              su_path = Sketchup.find_support_file("Sketchup.exe").split("Sketchup.exe")[0]
                              because there's no exe files on Mac, and they are located elsewhere. So su_path variable is nil, and when the script tries to locate the txt sections files, the su_path is splitted starting from a nil value, which raises error. (hope i'm clear 😳 )
                              I'll take a look at this asap, but I'm very busy these days... Here is my todo list, apart from corporate devs:
                              Terrain reshaper
                              Housebuilder for Mac
                              Transformer keys positions
                              Align tool -> copy option
                              Extrudelinesalongpath (follow me for lines)
                              SU2STL & Heightfield_gen : binary tests
                              Instancing brush for compo spray
                              SU2POV mat editor sliders
                              DB
                                thinkbuild
                                bonjour didier ...
                                ok, i will see what i can do to make it work. note i am a total non-programmer, but maybe i'll have some luck and you can strike it off your list! i'll report back when i know if i have any success or not 😉
                                a bientôt!
                                jason
                                  thinkbuild
                                  Cher Didier,
                                  Bonjour! Alors, here's the report: I can't find the line you are talking about in the script. Pas trouve! It must be in one of the two scrambled files. Je regrete! Please advise if there is another way I can help!
                                  best wishes from Berlin,
                                  Jason
                                  • H Offline
                                    Hazza
                                    Is it possible to change this so that the wall (or whatever) you just created is undone in one go?
                                    See all of my SketchUp models here.
                                      MrPlanet
                                      Hi! i want to delete housebuilder from my computer but it says it is being used by another person when sketchup is closed,can someone tell me what's happening?,thanks
                                      I reject your reality and substitute my own.
                                      • F Offline
                                        flo
                                        I got here when I was looking for the answer to the post How do I print ti scale in SketchUp? I didn't find the answer but I found u guys talking about housebuilder. What is that?
                                          linea
                                          Thanks for the new script!
                                            rodericx
                                            its possible to translate ? i mean i dont know much about ruby (nothing actually), then this interesting plugin i wanted to use in spanish... then i see in the file : HouseBuilder_extention.rb some calls... like
                                            # Floor tool
                                              cmd3 = UI;;Command.new(("Floor tool")) { Sketchup.active_model.select_tool HouseBuilder;;FloorTool.new }
                                              cmd3.small_icon = "HouseBuilder/hb_floortool_S.png"
                                              cmd3.large_icon = "HouseBuilder/hb_floortool_L.png"
                                              cmd3.tooltip = "Creates a floor."
                                              hb_tb.add_item(cmd3)
                                            then i want to know if i can replace the texts between "" without affect the plugin?. 😎
                                            • 2 / 4
