    Fry render v1 released
    36 Posts 12 Posters 6.6k Views 12 Watching
    • K
      kwistenbiebel
      A handy feature from within the material editor is the ability to alter the bitmap textures you assigned to the materials.
      It has a lot of possibilities to change the appearance of the textures. (No need to get back to Photoshop to change things).
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/bitmapeditor.jpg
      Very easy to make a bump map for instance out of the colored texture by desaturating, increasing contrast, clip whites or blacks etc...
      It also lets you add procedural noise, color gradients etc...
      • K
        kwistenbiebel
        To clarify the workflow from within Sketchup I will post some screen caps.
        This is the Fry toolbar within Sketchup:
        http://i140.photobucket.com/albums/r3/kwistenbiebel1/frytoolbar.jpg
        When clicking the icons of that toolbar, following windows will pop up according to which icon you click:
        http://i140.photobucket.com/albums/r3/kwistenbiebel1/frycamera.jpg
        http://i140.photobucket.com/albums/r3/kwistenbiebel1/fryenvironmentsettings.jpg
        http://i140.photobucket.com/albums/r3/kwistenbiebel1/fryrendersettings.jpg
        • K
          kwistenbiebel
          The material editor:
          How it works:
          While having selected the Sketchup material (in the SU material browser), push the 'bucket' icon on the Fry toolbar.
          The 'Fry material editing' window will pop and will make you setup the properties of the material:
          http://i140.photobucket.com/albums/r3/kwistenbiebel1/mateditor-b.jpg
          • K
            kwistenbiebel
            Not in the sense of the Studio in Maxwell.
            But it has its own GUI (a 'mini' Studio if you like) that is launched when you push 'render' in Sketchup.
            It lets you adjust some things if needed (e.g view point, camera settings, material tweaks),but all the mat editing and render settings are actually already done within SU...
            An extended manual will be uploaded this week (according to the developers) on the Fry website.
              remus
              Cheers for the little walkthrough kwist, im tempted to give it a go now, if only i could find some time!
              • K
                kwistenbiebel
                I just tested the new animation feature and I must admit it is a bit buggy on larger sketchup files.
                It seems to have trouble to save a dump file in the temp folder (crashes SU). Hopefully it will be sorted out soon.
                Rendering animation seems to be quite fast though.
                Here's a small tryout which rendered 1 minute per frame, which is actually very speedy.
                Just a displaced box on a surface:
                [flash=480,360:2autdnzb]http://www.youtube.com/v/J1MfQNjGSOw&hl=en&fs=1&ap=%2526fmt%3D18[/flash:2autdnzb]
                • FletchF
                  Fletch
                  Thanks for sharing this great review, Kwist, good work! 👍
                  Fletch
                  • I
                    ilay7k
                    strange, why not to try demo? 😄
                    http://fryrender.com
                    anyway indigo/kerky2008/and little bit luxrender and maxwell are best
                    holywar joke 💚
                    • soloS
                      Chris, I installed Fry and unzipped the SU6 plugings and installed them into the correct folders. I am usng U6 pro and yet I do not see any icons or reference to them in plugins drop down menu.
                      I do have the .fry export facility which opens the Fry consol.
                      • K
                        kwistenbiebel
                        That's strange. Are you sure you have version 1 ?
                        • soloS
                          The latest one off the website (demo)
                          • I
                            ilay7k
                            Try to activate toolbar from plug-ins menu, fry-menu >> show/hide fry toolbar 😉
                            • soloS
                              I do not have the fry-menu option in the plugins drop down menu.
                              • I
                                ilay7k
                                strange, i have
                                http://img389.imageshack.us/img389/3467/fr1gh0.th.jpg
                                Asian bridge by Sean Headrick
                                you install via this?...
                                1. fry_su will only work on the PRO version of SketchUp
                                2. Given the contents of the proper zip (su_5/fry_su.zip or su_6/fry_su.zip, depending on which version you're using):
                                  - copy fry_su.dll file to <SketchUp folder>\Exporters
                                  - copy fry_su_loader_SU#.rbs and Win32API.so files to <SketchUp folder>\plugins
                                3. Start SketchUp, if everything is ok, you should see a FRYRENDER entry under Plugins menu section
                                • K
                                  kwistenbiebel
                                  Solo, I can't give you an answer to your problem, besides checking your folders to see if all was installed well (the .dll files as Ilay said etc...).
                                  Feversoft should open up their forum for the demo users. I asked them before...maybe I should askit again now the final version is out.
                                  • plot-parisP
                                    plot-paris
                                    thank you very much, kwistenbiebel. with that detailed explanation of the worklfow you made me curious. I liked the maxwell interface in principal; but some things were a bit clunky. fry seems to be one step ahead in terms of interface/workflow...
                                    • K
                                      kwistenbiebel
                                      Indeed, the nice thing is that you can open all these panels from within Sketchup.
                                      No need to export your file first to a Studio to do editing there.
                                      By the way, the Fry manual has just been released.
                                        remus
                                        Available form here: http://tutorials.fryrender.com/#manual
                                          silver_shadow
                                          mine is doing the same as solos one. all works fine, when checking it in skp, nothing works.
                                          do you mind sharing those fryrender sketchup plugins. Its no where else to find on any website than one place and it does not really seems to work. I really wanna try this, emailed fryrenders website, no reply, registered to go into fryrenders forums, no permissions to post anything..so im reallly really stuck. please please help 🤓
                                          • H
                                            huyvuvn
                                            anyone have fryrender plugin of Sketchup . Plz share to me , many thanks 😉
                                            happiness on the way, not in the destination.
                                            • 2 / 2
