    Fry render v1 released
    36 Posts 12 Posters 6.6k Views 12 Watching
    • K
      kwistenbiebel
      Personally I would go for Fry.
      As a user you get to be closer to the developers than you are when buying Maxwell.
      You can actually get things done and they really listen do your needs (as long as you remain polite 😄 ).
      When comparing quality, that is difficult to answer.
      I think they are similar and I can't really decide which is better.
      I personally love the workflow more in Fry, definitely when seeing the latest improvements they did on the SU plugin.
      • StinkieS
        Stinkie
        Keep in mind that Maxwell's Studio provides you with a good way to add, say, high poly 3D trees to your scene.
        I gotta try Fry, though. 💚
        • K
          kwistenbiebel
          Fry is fast at setup, slow at rendering( unbiased...you know).
          Some people say it renders faster than Maxwell, but I haven't done a comparative test.
          When you already have Maxwell I would stick to it, but when you have to make a new purchase I would consider Fry..
          I don't know if the demo of version 1 is already up for download but yes, trying the demo is definitely the best way to make your choice.
          • K
            kwistenbiebel
            Fry does proxy/instancing from within Sketchup, which works similar to the 'dummy' approach of Skindigo.
            It allows you to place low poly 'dummy' trees in your scene, which will be automatically replaced by the high poly 3D trees when rendering...
              remus
              Is there a studio in for fry as well? i got the impression form your first post that there as...
              • K
                kwistenbiebel
                A handy feature from within the material editor is the ability to alter the bitmap textures you assigned to the materials.
                It has a lot of possibilities to change the appearance of the textures. (No need to get back to Photoshop to change things).
                http://i140.photobucket.com/albums/r3/kwistenbiebel1/bitmapeditor.jpg
                Very easy to make a bump map for instance out of the colored texture by desaturating, increasing contrast, clip whites or blacks etc...
                It also lets you add procedural noise, color gradients etc...
                • K
                  kwistenbiebel
                  To clarify the workflow from within Sketchup I will post some screen caps.
                  This is the Fry toolbar within Sketchup:
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/frytoolbar.jpg
                  When clicking the icons of that toolbar, following windows will pop up according to which icon you click:
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/frycamera.jpg
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/fryenvironmentsettings.jpg
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/fryrendersettings.jpg
                  • K
                    kwistenbiebel
                    The material editor:
                    How it works:
                    While having selected the Sketchup material (in the SU material browser), push the 'bucket' icon on the Fry toolbar.
                    The 'Fry material editing' window will pop and will make you setup the properties of the material:
                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/mateditor-b.jpg
                    • K
                      kwistenbiebel
                      Not in the sense of the Studio in Maxwell.
                      But it has its own GUI (a 'mini' Studio if you like) that is launched when you push 'render' in Sketchup.
                      It lets you adjust some things if needed (e.g view point, camera settings, material tweaks),but all the mat editing and render settings are actually already done within SU...
                      An extended manual will be uploaded this week (according to the developers) on the Fry website.
                        remus
                        Cheers for the little walkthrough kwist, im tempted to give it a go now, if only i could find some time!
                        • K
                          kwistenbiebel
                          I just tested the new animation feature and I must admit it is a bit buggy on larger sketchup files.
                          It seems to have trouble to save a dump file in the temp folder (crashes SU). Hopefully it will be sorted out soon.
                          Rendering animation seems to be quite fast though.
                          Here's a small tryout which rendered 1 minute per frame, which is actually very speedy.
                          Just a displaced box on a surface:
                          [flash=480,360:2autdnzb]http://www.youtube.com/v/J1MfQNjGSOw&hl=en&fs=1&ap=%2526fmt%3D18[/flash:2autdnzb]
                          • FletchF
                            Fletch
                            Thanks for sharing this great review, Kwist, good work! 👍
                            Fletch
                            • I
                              ilay7k
                              strange, why not to try demo? 😄
                              http://fryrender.com
                              anyway indigo/kerky2008/and little bit luxrender and maxwell are best
                              holywar joke 💚
                              • soloS
                                Chris, I installed Fry and unzipped the SU6 plugings and installed them into the correct folders. I am usng U6 pro and yet I do not see any icons or reference to them in plugins drop down menu.
                                I do have the .fry export facility which opens the Fry consol.
                                • K
                                  kwistenbiebel
                                  That's strange. Are you sure you have version 1 ?
                                  • soloS
                                    The latest one off the website (demo)
                                    • I
                                      ilay7k
                                      Try to activate toolbar from plug-ins menu, fry-menu >> show/hide fry toolbar 😉
                                      • soloS
                                        I do not have the fry-menu option in the plugins drop down menu.
                                        • I
                                          ilay7k
                                          strange, i have
                                          http://img389.imageshack.us/img389/3467/fr1gh0.th.jpg
                                          Asian bridge by Sean Headrick
                                          you install via this?...
                                          1. fry_su will only work on the PRO version of SketchUp
                                          2. Given the contents of the proper zip (su_5/fry_su.zip or su_6/fry_su.zip, depending on which version you're using):
                                            - copy fry_su.dll file to <SketchUp folder>\Exporters
                                            - copy fry_su_loader_SU#.rbs and Win32API.so files to <SketchUp folder>\plugins
                                          3. Start SketchUp, if everything is ok, you should see a FRYRENDER entry under Plugins menu section
                                          • K
                                            kwistenbiebel
                                            Solo, I can't give you an answer to your problem, besides checking your folders to see if all was installed well (the .dll files as Ilay said etc...).
                                            Feversoft should open up their forum for the demo users. I asked them before...maybe I should askit again now the final version is out.
