    Some of my works
    409 Posts 95 Posters 167.3k Views 95 Watching
    • I Offline
      igor
      WOAH... thats insane!!!! i wish i could model with that much detail. your models absolutely blew me away. keep going!!!
      279
      The genius switch has no "off" position
      Intelegence is natrual, it takes real effort to be ignorant
      • orgelfO Offline
        orgelf
        thanks for your comments β˜€
        @Igor spend time your models and you will find the "details". It is really just a question of work πŸ˜‰
        what is very cool with Sketchup is that it is really simple to use .....not a lot of tools to use(draw then push/pull) .Then let your imagination be your engine !
        me, I usually work with a picture, first I try to do what I see, and then I change my model as I feel it .
        http://www.orgelf.com
        • tinanneT Offline
          tinanne
          Good Heavens! Do you sleep?
          These are great!!
          Executive Director : American Society of Architectural Illustrators
          AIP 30 Competition opens soon. ASAI.org
          Architectural Rendering
          • orgelfO Offline
            orgelf
            πŸ˜„
            yes I sleep and I have a job πŸ˜‰
            3 others renders I did with one matcap of Zbrush (a white one) and photoshop
            http://i32.tinypic.com/16hqbfo.jpg
            http://i25.tinypic.com/2hdvcex.jpg
            http://i27.tinypic.com/2j51m9w.jpg
            http://i27.tinypic.com/deohz4.jpg
            http://i30.tinypic.com/35mk6kh.jpg
            http://i32.tinypic.com/2bqgc9.jpg
            ps click on the link under the image , and then click on the image appeared to enlarge it .
            • F Offline
              fewdavid
              amazing sketchup πŸ‘ πŸ‘ πŸ‘
              http://img60.imageshack.us/img60/8853/bandly860aq0.jpg
              • F Offline
                fewdavid
                I want to be your fanclub πŸ‘
                • orgelfO Offline
                  orgelf
                  @fewdavid thanks for your comments πŸ˜„ ok for the fanclub 😎
                  here a picture I made with a matcap and PSP, it is not my favourite, I will try to do another one with the same "style"
                  http://i38.tinypic.com/2hnrmtg.jpg
                  http://i35.tinypic.com/2lizzf4.jpg
                  • orgelfO Offline
                    orgelf
                    another one in black and white ...
                    http://i34.tinypic.com/2kjyn6.jpg
                    http://i38.tinypic.com/20jl9o3.jpg
                      russellbeta
                      Some inspiring stuff there.
                      Keep it up, looks like you are going places πŸ˜„
                      a few tips for sketchup:
                      the lines you get out of "makehuman" are hard lines.
                      to make the human parts look smoother select those hard lines in sketchup, right click and then select "smooth edges"
                      the edges will be invisible at that point but you can view/edit them by clicking "view"->"show hidden geometry"
                      A problem I would see with that approach is in your renders as you are using an 3rd party renderer so I'm not sure if your edges would still be smooth after
                      your export or import.
                      A Rendering plugin for sketchup that I would recommend is SUpodium
                      quote from webby: "The free version will not expire. The free version is exactly the same as the commercial version EXCEPT it only outputs to 230 X 120 and 500 X 500 image resolution sizes."
                      You can get it here after giving your email adress: http://www.suplugins.com/index.php?p=page&page_id=Download
                      another thing I think you would like after seeing your work is the bezierspline rubyscript which gives you more freedom in drawing curves
                      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_edi_page.htm (scroll down to Bezierspline.zip, a PDF is in the zip file with instructions):
                      rubyscripts add functionality to sketchup, they have the extention .rb and need to be placed in the plugins folder to work.
                      If you would like instant feedback on photoshop or sketchup you may add me on msn. my adress is russellbeta -"at"- hotma...
                      I can answer most questions off the bat on both topics in exchange for me asking some questions about Zbrush πŸ˜„
                      PS: the spiderlegs are brilliant πŸ˜„
                        russellbeta
                        yep that email adress is right, will you delete it from your post though?
                        because bots actively surf the web looking for them and the more copies of my email adress are posted on the web, the more spam i will get πŸ˜•
                        kerkythea, I'm guessing you've done some research; does it work in making animations?
                        • orgelfO Offline
                          orgelf
                          thanks russelbeta for your comment !
                          for the "hardlines" of makehuman, I wanted to keep them for these pictures because I want these "creatures" to look like "robots" and not like robot with human part . But thanks for the "smooth edges" , I keep it πŸ˜„ .
                          for the moment, my approach for rendering is to apply differents matcaps in Zbrush to my volume, then to exports these pictures in PSP and put them together to have a nice picture . πŸ˜„
                          I don't use a rendering motor yet, but I will soon . I heard about Podium and the limits of the size of its rendering for the free version ...That's why I think that I will use Kertkythea instead of it . It seems to be a good one and no limit for size rendering .
                          and you are right,bezier seems to be usefull, I downloaded it and will use it πŸ˜‰
                          • FrederikF Offline
                            Frederik
                            Of course KT can render an animation... πŸ˜‰
                            Although the Walkthrough Animation Step-by-Step tutorial was made for KT2007, all basics remain identical with KT2008... πŸ˜‰
                            However, if you by "animations" mean that the model would be animated and then rendered, the answer is no... 😐 And I haven't seen any render application capable of doing this with SU models... 😐
                            Cheers
                            Kim Frederik
                            • orgelfO Offline
                              orgelf
                              @russelbeta no i did no research on Kerkythea, it is just that I need a free photorealist engine with no limits of size and a friend told me about Kerkythea. I have just been on the website and I like the gallery πŸ˜„
                                russellbeta
                                crud, I've just bought SUpodium and ideally would need to make a walkthrough, a 2-3minute one with lots of lighting, detail and possibly moving section cuts.
                                its a hugely detailed model of a timber frame house, here, i'll post an image πŸ˜„
                                http://img168.imageshack.us/img168/6772/example2ns4.jpg
                                I've still to import alot of things I've prepared for it, plasterboard, all the rooftiles, flooring, the plot, pool, foundation layers and reinforcements and so on, oak cladding, wall ties, patio/masonry details,... it goes on and on plus i've quite a few layers like the fireplace, furniture, plumbing/drainage and so on hidden in the model above. in short the model will have pretty much everything apart from the screws/nails/individual electrical cables. I've even prepared a model of myself to put into it for kicks πŸ˜„
                                dunno if it is actually feasable to animate something with this kind of complexity because I've never seen a sketchup model so detailed.
                                maybe i should make a seperate thread for this topic πŸ˜›
                                • orgelfO Offline
                                  orgelf
                                  yes may be πŸ˜‰
                                  but it is amazing that you posted this here because I have exactly the same questions on a project i think about . It 's a building, and, as yours, something "big" with details and I wanted to make a kind of "movie", a camera that flies around it and shows us the outside and the inside .... in the sketchup scene (without colours or textures , just the shadows from the sun), but I didn't know if that is possible so...I don't know ....let's see if we will have an answer here but may be the best for your project (and mine) is that you create a new thread !
                                    russellbeta
                                    A movie showing just a sketchup render with the shadows from the sun is really easy,
                                    here http://www.youtube.com/watch?v=rCNGQX6j7D4 that will teach you how to make the animation.
                                    just incase it doesnt tell you this info:
                                    when you've made a scene you can right click on it it and open the page scene manager, which gives you alot of control.
                                    good luck πŸ˜„
                                    • orgelfO Offline
                                      orgelf
                                      β˜€
                                      thank you so much for that link !!! πŸ‘
                                        huhu
                                        Animation in Sketchup can be made also with many plugs πŸ˜„
                                        Sketchyphysics2 😲
                                        Transformer by D Bur β˜€
                                        and the last more exiting 'in french link)Proper animation by Morisdov who mix animation of objects and animation scene 😲 😲
                                        • plot-parisP Offline
                                          plot-paris
                                          by the way: I am not aware of any render engine that supports SketchUp sections.
                                          section planes are merely a display featyre in SketchUp and have no effect whatsoever on the geometry therefore they are not exported to a render engine. (please correct me if I am wrong - would love to have a renderer that does sections (SketchUp section export I mean)...
                                          • orgelfO Offline
                                            orgelf
                                            thanks for your replies, I think I will use animation for the next one .*
                                            this time I would like to show you a strange news item that happened in the Excalibur's church . I was looking at the building
                                            http://i36.tinypic.com/2qb9ds5.jpg
                                            http://i36.tinypic.com/111ijj4.jpg
                                            http://i36.tinypic.com/14kutmg.jpg
                                            http://i36.tinypic.com/2jcxxmq.jpg
                                            http://i38.tinypic.com/14wyn0g.jpg
                                            http://i35.tinypic.com/1zw2owg.jpg
                                            http://i36.tinypic.com/k4eao9.jpg
                                            the cloyster
                                            http://i38.tinypic.com/5b4ciq.jpg
                                            http://i36.tinypic.com/egbgoz.jpg
                                            http://i36.tinypic.com/esox09.jpg
                                            http://i38.tinypic.com/14ayjdd.jpg
                                            http://i34.tinypic.com/mhpm39.jpg
                                            the Excalibur's pedestal and Excalibur itself
                                            http://i33.tinypic.com/e658jm.jpg
                                            http://i38.tinypic.com/2vwgqhw.jpg
                                            http://i34.tinypic.com/11t3708.jpg
                                            When I begin to hear screamings ...
                                            [img:2hy6crr3]http://i33.tinypic.com/2rw3wgp.jpg[/img:2hy6crr3]
                                            [img:2hy6crr3]http://i36.tinypic.com/f1l4bk.jpg[/img:2hy6crr3]
                                            [img:2hy6crr3]http://i35.tinypic.com/35n5xyv.jpg[/img:2hy6crr3]
                                            a kind of giant fly appeared in the middle of the tourists !!!
                                            [img:2hy6crr3]http://i38.tinypic.com/2rr1jih.jpg[/img:2hy6crr3]
                                            [img:2hy6crr3]http://i38.tinypic.com/30uady1.jpg[/img:2hy6crr3]
                                            and ...I...can see something in the sky ....
                                            [img:2hy6crr3]http://i34.tinypic.com/33ma4hw.jpg[/img:2hy6crr3]
                                            is it a bird ??? is it a plane ???
                                            [img:2hy6crr3]http://i37.tinypic.com/1o80p4.jpg[/img:2hy6crr3]
                                            NO !! IT'S SUPERMAN !!!!!!!!
                                            [img:2hy6crr3]http://i38.tinypic.com/2rvzcdh.jpg[/img:2hy6crr3]
                                            πŸ’š
                                            • 20
                                            • 21
                                            • 3 / 21
