    Texture Opacity
    9 Posts 5 Posters 975 Views 5 Watching
    • daleD Offline
      dale
      Does anyone know of a way to adjust the opacity of a texture?
      I was fooling around applying jpeg images of reflections in glass as a texture to a SketchUp image, and liked the potential, but I would really like to adjust the opacity so that it was still translucent. Highlighting and adjusting the slider had no effect and I tried to use edit functions, but to no avail. An example attached,( and by the way that is one of Richards "white people" loitering in front of the store, whose reflection I have to add to the glass still. Thanks Richard)
      • plot-parisP Offline
        plot-paris
        can you check, if the "Enable Transparency" checkbox is activated (styles window > face settings).
        otherwise, could you upload the model?
        cheers,
        Jakob
        • daleD Offline
          dale
          cheers,
          Jakob
          HI plot-paris
          Yes, the enable transparency is on in styles.
          I am uploading a copy of the storefront doors with texture as described. The model was started before I went to SketchUp Basecamp, and has all the trademarks of how to make a model with a huge file size, so I won't try to upload the whole thing. Hopefully this is enough for you to work with. Thanks
          Storefront doors.skp
          • brodieB Offline
            brodie
            cheers,
            Jakob
            HI plot-paris
            I didn't have a problem. In the materials window I selected the eyedropper and picked one of your window materials, went to the Edit tab in the Materials window and adjusted the opacity down to like 62% and it seems to be working fine.
            -Brodie
            Storefront%20doors[1].skp
            • daleD Offline
              dale
              Thanks Brodie, I will retry that. It wasn't originally working, but I give it anther go.
                plot-paris
                I don't have any problem with it either. hope you will work it out... I'll keep my fingers crossed
                • DavidBoulderD Offline
                  DavidBoulder
                  I've found when I make a change to a texture (like transparency or name) I have to tab into another field within that texture or my changes don't stick? maybe that is what is happening to you.
                  I'm on mac
                  David Goldwasser
                  OpenStudio Developer
                  National Renewable Energy Laboratory
                  • brodieB Offline
                    brodie
                    I'm on mac
                    Yeah, that's true for pc's as well
                      Also note that under 70% of opacity, the window will neither cast nor receive shadows so if you want that figurine to cast the shadow onto it, keep it above 70% opacity.
