    Array along a path
    9 Posts 3 Posters 1.2k Views 3 Watching
      marcosrodrigues
      Is it possible?
      http://static.panoramio.com/photos/original/1838875.jpg
      | menos é mais
        marcosrodrigues
        I found a video that explains a little what I want to say: http://www.mv.com/ipusers/hammond/turbosquid/spacingTool/spacingTool.htm
        | menos é mais
          marcosrodrigues
          I found something... http://www.smustard.com/script/PathCopy . Thank you.
          "PathCopy v.2.1
          by Rick Wilson
          description Copy groups or components along a path, at set spacing or node spacing
          usage Select "Copy Along Path" from the Plugins menu, select a path, then select a group or component to copy.
          Copy to Path Nodes will make a copy of the selected group or component, placing the copies at the vertices of the selected path.
          Copy to Spacing will make a copy at set intervals along the path. You may specify a distance in the VCB.
          The zip file contains pathCopy.rb, vector.flat_angle.rb, and Icons/pathcopy.png"
          But:
          Known issues
          When using the "path nodes" option, items will NOT BE ROTATED 😢 as they are copied. There is a fix planned for this.
          | menos é mais
          • CadFatherC Offline
            CadFather
            glad you found it - the fix has been in planning for quite some time so i wouldn't expect too eagerly : (
            the plugin is great but it would be greater to have more options to copy along paths - some kind of superarray tool 😛
              marcosrodrigues
              tangents on the curved paths... definitely it will be very useful.
              | menos é mais
                CadFather
                yes, and along multiple paths! 😮
                  RickW
                  Yeah, I'm a bit slow lately. 8-month-old baby + overtime at day job = not much ruby time 😞
                  It will get done eventually... 😄
                  RickW
                  [www.smustard.com](http://www.smustard.com)
                    CadFather
                    well well.. congratulations! we can wait for eventually no problem 🎉 😄
                      RickW
                      Thanks! 😄
                      Meanwhile, I am collecting the suggestions...
                      RickW
