    Dimension text
    6 Posts 3 Posters 1.0k Views 3 Watching
      Matt666
      Hi !
      Access to "dimensions" entities informations via scripts seems really hard in Sketchup ... ๐Ÿ˜ž ๐Ÿ˜ž ๐Ÿ˜ž
      How can you access to the dimension text ? Modify it ? Start point of the dimension ? end point ? Line weight ? Arrow ? etc...
      Is it a block ? A group ? Can't explode it...
      Please Help me !!! ๐Ÿ˜ฒ
      Thank you !
      Frenglish at its best !
      My scripts
        Currently you can't insert or edit dimension entities or their settings with Ruby.
        A script work-around is to insert a component [skp file] that is simply a dimension drawn from the origin say 1 unit long in the x (red), with the text-style/arrow-style preset as required, your script then inserts it at picked-point 1, and then the script rotates/scales it in its length etc to suit picked-point 2 etc. The dimension shown updates accordingly.
          Matt666
          ๐Ÿ˜ž ๐Ÿ˜ž ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ข ๐Ÿ˜ข ๐Ÿคข
          Grmbl... Is it a v7 upgrade???
          Thanks for the method !
          I want to make a script that erase all units in texts... Verz easy in lisp language, but not in ruby....
          Thank you TIG !
          My scripts
            Why not just uncheck the box in Window>Model Info>Units?
              Matt666
              ๐Ÿ˜„ ๐Ÿ˜„
              Thank you ! I also wanted to make a script that removed unnecessary zeros (if the dimension result is an integer...)
              225.00 => 225
              225.20 => 225.2
              225.25 => 225.25
              But I think now it's not possible.
              Thank you Dave !
              My scripts
                I no little of Ruby but you are probably right. Dropping the zeroes as needed may not be possible. Perhaps that should be a wish list item for the next version of SU.
                Cheers,
                Dave
