    Animating Section cut through model
    8 Posts 5 Posters 954 Views 5 Watching
      architeriffic
      I am trying to figure out how to animate a section cut through a building. I have seen this done, so I know it is possible. I have obviously tried to animate the section plane, and also the group it is cutting. I am using SU 6 on a Mac. I have been able to animate the sun's position through the day to create a full sun sweep over the days of the solstices for sun studies.
      • FrederikF
        Frederik
        Since this seem almost too simple to answer, I fear that this is not what you're looking for, but attached please find a test... 😉
        Anim-sectioncut.skp
        Cheers
        Kim Frederik
        • Alan FraserA
          Alan Fraser
          Use 2 section planes...1 down at ground level, 1 just above the highest point. Set up 2 scenes, either from the same viewpoint or different. Then edit and update each scene so that you have the lower section active in scene1 and the upper section active in Scene2. Adjust the transition time to get the effect you want.
          3D Figures
          • Wo3DanW
            Wo3Dan
            architeriffic,
            Following Alans advice you may even want to exclude the 'Camera Location' from being saved in both scenes.
            See the 'Scene Manager' to uncheck 'Camera Location' just before 'saving as a new style'
            This will allow you to see transitions taking place from any angle. You can even orbit during these scene transitions. Although not always with the best results.
            Wo3Dan
              architeriffic
              ok, have the animation, now how do I hide the section planes and keep the animated cuts?
              Thanks so much
              • Alan FraserA
                Alan Fraser
                There's a Section Cut toolbar with an icon for show/hide the planes.
                3D Figures
                  architeriffic
                  The obvious answer was to turn off section planes in the view menu...duh.
                  • GaieusG
                    Either this (View menu) or that (Toolbar - as Alan says) way. If you plan to use section planes/cuts a lot however, activate the toolbar from View > Toolbars so that you don't need to open the menu all the time.
