๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Plotting PDF - textures missing
8 Posts 4 Posters 1.2k Views 4 Watching
    Jorgensen
    I need some drawings in scale and I usely use 'print to PDF' - CutePDF.
    Now I have the problem that the textures are missing ๐Ÿ˜ž
    Does anyone know what the problem can be ?
    Jorgensen
      Well, I don't use CutePDF so don't know about its specs but I have never had any problems with PDFCreator (it can also "print" into different image formats).
        Jorgensen
        Hi Gaieus
        Thanks for your input. I just found PDF995, and it seems to do the job ๐Ÿ˜„
        Do know the differences of PDF995 and PDFCreator ? I might give it a try.
        Jorgensen
          juju
          I've also never had problems using PDF995, works like a charm!
            No, prior to this I only used PrimoPDF. There are a bunch of PDF printers out there but some prints an info line (mostly to their pay versions) while others cannot print our special, Hungarian characters like ล and ลฐ so I haven't looked for anything different since I found this. It even allows you to set certain security settings (password protection, copy/print permissions etc.)
              Jorgensen
              Strange that Adobe PDF is slow and is having problems printing textures ?
                Anssi
                Also, check that you don't have the "Use high-quality HLR" ticked in the print dialog box. The setting switches printing to a vector-only mode: no textures or shadows. The setting should really have something intelligible printed next to it.
                Anssi
                  Jorgensen
                  Yes, I know that one ๐Ÿ˜„
