    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 540.4k Views 153 Watching
    • C
      CPhillips
      @remus said:
      This is a bit of a long shot (aka a feature request) but would it be possible to make it so that grouped geometry (within the group to be FFDd) could be moved by the control points but not deformed. In an ideal world the edges that were 'shared' between the group and the geometry outside the group would also remain unaffected.
      I was just thinking that if this worked you could use FFD a a very basic method for manipulating rigged meshes, perhaps in combination with monsterzeros rigging hack.
      I dont think I follow. Can you post a picture?
      • C
        CPhillips
        @svetik said:
        Thanks man-it is really inportant emproovement for SU. Google is too poor to do it πŸ˜ƒ
        BUT! it does not work for my favorit 3D soft- AtLast Sketch Up 5 😒 Why?
        I think it should. But I dont have SU5. Can you open the ruby console try it and see if it prints any errors?
        • T
          topmanblue
          thank YOU sir!!!
            remus
            Imagine we start with this mesh:
            http://farm4.static.flickr.com/3027/2597462070_0a40f6c0ed.jpg
            The box is a group within the group to which FFD has been applied.
            Currently deforming this mesh does this:
            http://farm4.static.flickr.com/3169/2596629893_ca8137cce1.jpg?v=0
            What i was suggesting is to get it to do this instead:
            http://farm4.static.flickr.com/3260/2596629957_31560b8f49.jpg?v=0
            • C
              CPhillips
              I don't follow. If you want to bend the boxes like that why dont you do them separatly.
                remus
                The two bits that have been affeced arent important. What im trying to describe is the way FFD treats groups within groups.
                If you look at the box, notice it is left behind in the first instance, but affected in the second. thats what im trying to suggest.
                • C
                  CPhillips
                  Ah. Dealing with subgroups gets a bit tricky, but I will see what I can do.
                    remus
                    I look forward to seeing what you come up with πŸ‘
                    • plot-parisP
                      plot-paris
                      a very interesting idea, remus.
                      but what happens, if the deformation is a bit more complicated?
                      imagine you want to alter the shape of the first object (on the left hand side of the image). the red plane is a group within the group of the green bowl.
                      http://img95.imageshack.us/img95/3213/groupedfddpu6.jpg
                      if FFD behaves like in your sample, it would look like the second form - the bowl is deformed and the red plane has to decide, where to stick to the connecting geometry.
                      or should the group within the deformation object be deformated where it is necessary in order to keep contact to the connecting geometry at every common edge?
                      but would that make any difference to simply enabeling FFD to alter nested groups no matter how deep the tree structure goes?
                      it probably would, because the group's content would only be changed, when absolutely necessary.
                      I am confused now... πŸ˜•
                        remus
                        I was thinking of it mainly in the context of using it to rig models, so i didnt really think about situations such as the one you mentioned.
                        Basically ive got no idea how it would behave in those sort of situations, i suppose thats up to chris' discretion, if the idea works at all.
                        • RayOchoaR
                          RayOchoa
                          If what ur saying is that the group should be deformed too but still remain a group den im with that πŸ‘ πŸ‘
                          CaR DeSiGnS bY mE
                          http://ray-ochoa.com
                          • C
                            cyan.archnet
                            simply awesome!, it's sure a big help!, thanks a lot!
                              svetik
                              Thank you for reply! This is console message:
                              Error: #<NoMethodError: undefined method add_observer' for #<Sketchup::ConstructionPoint:0x6cab320>> C:\Program Files\@Last Software\SketchUp 5\Plugins/SketchyFFD.rb:377:in createControlLattice'
                              C:\Program Files@Last Software\SketchUp 5\Plugins/SketchyFFD.rb:369:in each' C:\Program Files\@Last Software\SketchUp 5\Plugins/SketchyFFD.rb:369:in createControlLattice'
                              C:\Program Files@Last Software\SketchUp 5\Plugins/SketchyFFD.rb:147:in startFFD' C:\Program Files\@Last Software\SketchUp 5\Plugins/SketchyFFD.rb:13 C:\Program Files\@Last Software\SketchUp 5\Plugins/SketchyFFD.rb:13:in call'
                              • BurkhardB
                                Burkhard
                                To my knowledge WebDialogs and observers are not working with SU5
                                http://www.ia-plus.de
                                  rshah
                                  Hi..
                                  I am trying this ruby but doesnt work. I create a simple circle and pull it to give it a height. i then select everything and create group. I then select group and right click and it lets me do 3x3 etc point cloud. When i go into points group and move some points and close group and then right click on geometry group then i dont see update FFD tool. Can someone please help?
                                  I am using sketchup 6 pro
                                  thansk in anticipation.
                                  • jujuJ
                                    juju
                                    The ruby works as advertised. I think you need to revisit your steps and have a careful look at how to use the ruby again. Make sure it has subdivided geometry to work with though.
                                    • T
                                      tourniquetmaster
                                      My deformations are not auto updating themselves. Would anyone happen to know why?
                                        remus
                                        It might just be taking a while to work out whats meant to be happeneing or SU might be taking a while to display the deformed geometry.
                                          shnash
                                          I have downloaded your program sketchy FFD and have put it in the plugins folder. I see it in sketchup when i right click but when i apply it to a group i do not see the update ffd option. can u please tell me wot I'm doing wrong? thanks
                                            remus
                                            If youve got the latest version you shouldnt need the update option, it should do it automatically.
                                            • 20
                                            • 21
                                            • 8 / 21
