    Mirror
    8 Posts 7 Posters 1.0k Views 7 Watching
      dammerel
      without using a ruby script, how do you mirror a selection
      Thanks Andrew
      • T
        todd burch
        I can answer this!
        With the scale tool.
        Select your stuff you want to mirror. Activate the Scale tool. Grab the middle button on either side of the selection that relates to the axis you want to mirror. Start pulling the object inside out (through itself). Release the mouse button, and type "-1" (no quotes). You're done - a perfect mirrored copy. πŸ˜„
        Todd
        • eevaE
          eeva
          or: select your objects, right click, in the context menu: mirror > blue, red green axis.
          • ChiefwoodworkerC
            Chiefwoodworker
            A minor correction to eeva's response; it context click: Flip Along > blue, red green axis.
            Joe....
            http://www.srww.com
            • cerevellumC
              cerevellum
              Making a symmetric object?
              You can take one half of the model you are creating and make a component of it. Make a copy and scale it to -1 in the correct direction, and as you edit the first half of the model, the other half will follow suit.
              Zach
              • Jean LemireJ
                Jean Lemire
                Hi folks.
                See attached SU files for ideas.
                Mirroring_ideas.skp
                Mirroring_relative_to_a_plane.skp
                  dylan
                  Zach
                  This Video demonstrates Zach's suggestion very well.
                  http://dmdarchitecture.co.uk/
                    dammerel
                    Thanks Guy..great hints Andrew
