    Wards Kerkythea Renders (various buildings)
    16 Posts 6 Posters 4.5k Views 6 Watching
    • StinkieS
      Stinkie
      @eduardonl said:
      @ Stinkie Thanks for the feedback. I didn't really pay a lot of attention to the text.
      No-one ever does, mate! And that's where geeks like me come in. Oh yeah, forgot to mention: I like the sketches. Maybe give 'em a little more prominent place in your presentation?
      Also, don't use the textures that come with SU. They suck. I think I mentioned the KT mats repository. Check out Maxwell's MXM Gallery, too. Useful texture maps in there.
      Using decent textures is very, very important.
      • EddyNLE
        EddyNL
        New render of Sail Appartements. 😎
        http://img259.imageshack.us/img259/6843/newsmallyy1.jpg
        viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
        • FrederikF
          Frederik
          @remus said:
          Either you can use an HDR map for your background (i think kerkythea supports them, need confirmation though)
          Of course KT supports HDRI's... πŸ˜‰
          Cheers
          Kim Frederik
          • StinkieS
            Stinkie
            ... and it's got a tree library too, if I'm correct. πŸ˜‰
              remus
              Frederik, i suspected as much.
              i like the new render of the sail apartments btw. I think the background helps a lot, although im bound to say that.
              • N
                notareal
                There is some really nice trees in KT model library, look at KT download area and model selection in KT forums.
                • EddyNLE
                  EddyNL
                  I found those trees allright... took my computer almost 3 mins. to open the model. Rendering takes ages! 😞
                  • FrederikF
                    Frederik
                    Of course the render time will increase when using some of the Xfrog trees available... πŸ˜‰
                    Please remember that it's high poly 3D trees... πŸ˜„
                    What render preset are you using..?? πŸ˜•
                    For an outdoor scene like this you should try preset no. 17 (Path Trasing - Progressive)... πŸ˜‰
                    After about 50 passes, your render should look fairly crisp, and with some instanced Xfrog trees, I would imagine that it should only take about 60 minutes to reach, which IMHO is fair when using such high quality 3D trees... πŸ˜‰
                    Cheers
                    Kim Frederik
                    • EddyNLE
                      EddyNL
                      I need to buy a new computer... πŸ‘Ž
                      I like to make models in SU and render them in Kerkythea, just to see the result. I'm not (yet) aiming for a perfect, crips clean render. (which would take me hours)
                      @ Frederik
                      Setting are on preset no. 6
                      no. 17 takes a bit too long, can you recommend any other settings?
                      • FrederikF
                        Frederik
                        Preset 6 is good, but it all depends on the complexity of your scene... πŸ˜‰
                        Sometimes preset 6 will take much longer...
                        Like I said... For an exterior scene like this, with only the sun to light it up, preset no. 17 is my preferred... πŸ˜‰
                        ❗ Remember...
                        Although it shows 10000 passes before it's finished, you can finish it at any stage and by experience you will learn that the scene usually is crisp and clean after 50-60 passes... πŸ˜„
                        If you insert som instanced Xfrog trees, I'm sure that preset 6 will take much longer compared to preset 17... πŸ˜‰
                        Cheers
                        Kim Frederik
