    Wards Kerkythea Renders (various buildings)
    16 Posts 6 Posters 4.5k Views 6 Watching
    • H Offline
      HFM
      Heel erg saai stinkie
      Renders zijn goed, modellen misschien ietwat basic maar dat komt vanzelf wel
      water ziet er prachtig uit in de laatste render :duim: is dat een standaard uit kerkythea of 'homemade' ?
      [Good renders, models are somewhat basic but you'll get there
      water effect looks awesome in the last render πŸ‘ is that a standard render option that comes with kerkythea or is it 'zelfgemaakt' ?]
      Hugo
      • StinkieS Offline
        Stinkie
        That's what I said. πŸ˜„ Just wanted to point out there's more to presentation than pretty pictures.
        As fo the pictures, something I forgot to mention: Ward, you may want to check out Kim Frederik's "Getting Started" tutorial and the materials repository over at the KT website.
          remus
          Seems stinkie covered the text pretty well, i'll do the models (dont get too demoralised from all the crits btw. heyre pretty damm good really, but its always good to aim for perfection.)
          First thing, i reckon you need a background for your renders. They look pretty amuteurish with just the gradient background. Either you can use an HDR map for your background (i think kerkythea supports them, need confirmation though) or you could just put the model in to a photo using ps. If you can be bothered to fiddle about with them, id say HDRs are the way to go as they will give you reflections from the environment and generally make your scene look better.
          Second thing id recommend is to put the models in a bit more context. An environment map (the HDR i was talking about before) would probably help with this, but adding a few massed out surroundings cant do any harm.
          Final thing is to go for some more interesting camera angles. Of the things ive mentioned this is definitely the easiest to play around with, so its definitely worth playing around with it. Very generally id say try and go for angles that are either eye level or birds eye view, although this is very sweeping. The bottom line is its best experiment. Oh and dont forget field of view, it can make your shots look a lot more exciting.
          And dont forget to have fun, thats probably the most important part πŸ˜„
          • EddyNLE Offline
            EddyNL
            @ Stinkie
            Thanks for the feedback.
            I didn't really pay a lot of attention to the text. 😳 I just wanted to present my models and give a brief description. I'll put some more time and effort in the text part next time!
            @ HFM
            The water is made using Dielectric glass material in KT.
            Adding a water ripple bumpmap to it and tweaking some settings. I really like the result!
            @ Remus
            Thanks for your comment. I'll get back to you on the usage of skies and backgrounds.
            I'm having some trouble in KT getting them right.
            Anyways... I've only been here a day, but I learned quite a few things. Thanks guys!
            viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
            • StinkieS Offline
              Stinkie
              @eduardonl said:
              @ Stinkie Thanks for the feedback. I didn't really pay a lot of attention to the text.
              No-one ever does, mate! And that's where geeks like me come in. Oh yeah, forgot to mention: I like the sketches. Maybe give 'em a little more prominent place in your presentation?
              Also, don't use the textures that come with SU. They suck. I think I mentioned the KT mats repository. Check out Maxwell's MXM Gallery, too. Useful texture maps in there.
              Using decent textures is very, very important.
              • EddyNLE Offline
                EddyNL
                New render of Sail Appartements. 😎
                http://img259.imageshack.us/img259/6843/newsmallyy1.jpg
                • FrederikF Offline
                  Frederik
                  Of course KT supports HDRI's... πŸ˜‰
                  Cheers
                  Kim Frederik
                  • StinkieS Offline
                    Stinkie
                    ... and it's got a tree library too, if I'm correct. πŸ˜‰
                      remus
                      Frederik, i suspected as much.
                      i like the new render of the sail apartments btw. I think the background helps a lot, although im bound to say that.
                      • N Offline
                        notareal
                        There is some really nice trees in KT model library, look at KT download area and model selection in KT forums.
                        • EddyNLE Offline
                          EddyNL
                          I found those trees allright... took my computer almost 3 mins. to open the model. Rendering takes ages! 😞
                          • FrederikF Offline
                            Frederik
                            Of course the render time will increase when using some of the Xfrog trees available... πŸ˜‰
                            Please remember that it's high poly 3D trees... πŸ˜„
                            What render preset are you using..?? πŸ˜•
                            For an outdoor scene like this you should try preset no. 17 (Path Trasing - Progressive)... πŸ˜‰
                            After about 50 passes, your render should look fairly crisp, and with some instanced Xfrog trees, I would imagine that it should only take about 60 minutes to reach, which IMHO is fair when using such high quality 3D trees... πŸ˜‰
                            Cheers
                            Kim Frederik
                            • EddyNLE Offline
                              EddyNL
                              I need to buy a new computer... πŸ‘Ž
                              I like to make models in SU and render them in Kerkythea, just to see the result. I'm not (yet) aiming for a perfect, crips clean render. (which would take me hours)
                              @ Frederik
                              Setting are on preset no. 6
                              no. 17 takes a bit too long, can you recommend any other settings?
                              • FrederikF Offline
                                Frederik
                                Preset 6 is good, but it all depends on the complexity of your scene... πŸ˜‰
                                Sometimes preset 6 will take much longer...
                                Like I said... For an exterior scene like this, with only the sun to light it up, preset no. 17 is my preferred... πŸ˜‰
                                ❗ Remember...
                                Although it shows 10000 passes before it's finished, you can finish it at any stage and by experience you will learn that the scene usually is crisp and clean after 50-60 passes... πŸ˜„
                                If you insert som instanced Xfrog trees, I'm sure that preset 6 will take much longer compared to preset 17... πŸ˜‰
                                Cheers
                                Kim Frederik
