    Animation in sketchup
    12 Posts 9 Posters 3.5k Views 9 Watching
      silver_shadow
      hi all sketchup gods!!
      I am want to create just for kicks moving
      cars for my a scene, but not rendered. and wanna know if its
      possible
      Kinda liked the sketchup physics thing, just press
      play and whoala. I want something similar to this,
      or even if physics can do it..cool.. moving cars, almost
      like a gta scene, so you switch it on, cars move from
      one point to another, a helicopter swoosh over, non stop simple animation
      and you can orbit ect while this is happeneing.. I want itmore for a presentation
      idea 🤣 . Any ideas how i can do this? please guys any help would be great!!
      (preferably presenting it in sketchup)
        remus
        Su isnt very good for animation really, but i can be done.
        The basic principle is to make lots of copies of the car and place easch one on a different layer. You then only have one layer visible at a time (controlled using scenes) and cycle thrugh the visible layers. You can then introduce camera movement between the scenes as well. Really id recomend experimenting a bit, you'll probably get the hang of it pretty quickly.
          Mr S
          I have yet to try this software out.
          But it looks as though it can do what you require.
          It claims to work well with SketchUp files.
          Visit: http://www.antics3d.com/
          With regard to cars, you should also take a look here:
          403 Forbidden
          (www.antics3d.com)
          If you try it out please post back your results.
          Regards
          Mr S
          • jujuJ Offline
            juju
            There is also this plugin called SU Animate over at SU Plugins website. $49.00.
              silver_shadow
              i also got sketchup animate but its also working in sheets and not really freely like physics.. hmm i really would like to see what you guys will come up with, lol
                kwistenbiebel
                Hi Ho Silver,
                SU animate indeed works with scenes, but the results aren't too shabby. (not that I used it before).
                I just base it on the youtube footage that is around:
                  KENTUCKY
                  silver_shadow,
                  Here are some sample pure sketchup animations I had laying around from the old google forum.
                  following a car
                  car making a turn
                  a bunch of blocks moving
                    anglaret
                    Mr S
                    I tried Antics, but it is far complicated just to have a car go along a street, or somebody crossing a road.
                    Instead of going to the soft by export, I would prefer the soft to come to SU.
                    In fact we have made the choice of rendering and animating all projects, instead of only big ones, that is why podium is useful for us; one of us is brilliant with another renderer, he failed exporting OBJ with a 80Mo view in full hierarchy. It ended with Podium
                    Marc
                      silver_shadow
                      %(#FF0000)[hi thanx for responding so soon guys, I kinda like kentucky's cars, nice idea. Its actually wierd no one has written a script that could do static scenes with simple animation on it and still be able to work on the drawing while the animation runs. hold thumbs lol.
                      Also maybe because no one is interrested in sketchup animation, like Biebel says...its just too shabby. Sketchup grew tremendiously from what it was made for in the beginning and so many people uses sketchup at them moment, just becasue it just the simplest thing on the world to use. I so hope in the furture pipeline someone,a developer, script writer or even google's guys themself look into this. Maybe Sketchup 7 will be ready for this, if they allow sketchup to work with higher poly models, uses multi processors, these things might do a worlds change in simple or even advanced modelling, and maaaaaaaybe lol............
                      maybe we will get animation going on this super cool application 😄]
                        gcon
                        If you want to animate your SketchUp props then Antics really is the easiest way. Once you get over the fact it's a separate app, it's about as easy as animation can get. Like SketchUp, Antics is also available as a free download. You just import your SketchUp model straight into Antics, then use point and click to direct your model around.
                        Depending upon the model you are importing you may need to do some configuration (e.g. assign a speed to a car model). Then you can click on a point on the floor and the car will move there, or draw a path and have the car follow that. There are tutorials on the Antics forum which take you through the process, as Mr S mentioned. You can then direct your action and render it out as a video.
                        Disclaimer alert - I do work for Antics, but I would still say this even if I didn't!
                        I'm more than happy to answer any questions you may have. Either post up here or PM me.
                        Gary Conway
                        (Antics)
                          kwistenbiebel
                          Cinema4D is your best bet at the moment for what you want.
                          It is made for things like that.
                          I have the same hopes for SU7 to have all the things you mention, but I think that is beating on a dead horse...
                          Unless.... one of the notorious ruby coders could help out.
                          Eiter way, having an animation running while editing the model is way too CPU/GPU demanding.
                          I doubt any other package can manage that, not even Maya, C4D or Max.
                            ScottPara
                            Cinema 4D is a great program that can not only animate quite well, it can also render well too. It is a bit like max but I find it far easier to learn. I have not used it in a while (just have not needed it) but I would say it will work for what you are looking for and give far better results than any of the other recommendations. Granted it is a bit of change but I think in the long run it will be the right choice.
                            Scott
                            Love the fact that some HATE my avatar.....
