    Render #22 (animation test bottom page 8)
    120 Posts 30 Posters 13.8k Views 30 Watching
      sepo
      love the form 😎 ...could you tell us was it difficult to extrude window frames on curved surfaces. I guess surface tools and new JV push -pull was used.
      • FrederikF Offline
        Frederik
        I assume that you're right, Sepo...
        But the texture job is really good as well..!! 👍
        Care to share how you did this, Chris..?? 😉
        Cheers
        Kim Frederik
          kwistenbiebel
          Thank you guys 😄
          Indeed, the "surface tools" and "joint-push-pull" tools were used here to make those windows.
          And off course 'subsmooth' (though I think it should have had one iteration more).
          @Frederick,
          I just used the 'projected' method. It stretches the texture but it was not so disturbing this time. It depends from which angle you project the texture I guess.
            kwistenbiebel
            A quickie (noisy) using only background light (white):
            http://i140.photobucket.com/albums/r3/kwistenbiebel1/project22bis.jpg
            • I Offline
              igor
              how did you get such beautiful wood paneling? i mean in terms of projecting it onto the building (a really good building btw). did you project it at an angle (set up a face at a 45 degree angle instead of flat front or back)? like this:
              ../ __________
              ./ |.building.|
              / .|________|
              the three slashes on the left = face from witch the texture is projected
              box = you guessed it, is the building.
              little tiny dots = nothing, just ignore them.
              am i right?
              The genius switch has no "off" position
              Intelegence is natrual, it takes real effort to be ignorant
              • N Offline
                nomeradona
                hey kwist, this is another fabulous render and concept. is this Biebel's ark or tower of Biebel? 😄
                  kwistenbiebel
                  Thanks Nomer ...An Ark, didn't think about that 😄
                  I re-rendered the last view using Physical sky. (Indigo render)
                  The subtle glare is added 'internally' in the Violet tonemapper.
                  The glass should have had a little less roughness...
                  To view full size: (Firefox:right click- view image) (IExplorer:right click - image save as)
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/project22-view3.jpg
                    kwistenbiebel
                    Thank you Fred and Igor.
                    @Igor: You are correct. I projected the image almost perpendicular to the 'corner' of the building (as in your scheme).
                    I must admit the projecting is view dependant. Choose another viewpoint and the projecting needs to be redone.
                    • FrederikF Offline
                      Frederik
                      Thanks for the answer regarding the texturing, Chris..!! 😉
                      It looks as 3D trees... Xfrog..?? 😎
                      And the people in the scene... 😲
                      These are for sure some really excellent reders..!! 👍
                      Cheers
                      Kim Frederik
                        kwistenbiebel
                        Gracias senor Frederico 😄
                        The trees are Xfrog, the people Axyz as they look ok seen from a distance.
                        When in close-up, the Axyz guys look a bit like melted E.T.'s though 😆
                        • F Offline
                          fbartels
                          Chris, Nice work. I like where these seem to be heading. Zaha watch out indeed. Fred
                            kwistenbiebel
                            Some more:
                            Ouch....distorted texture alert 😄
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/render22view4.jpg
                              Is it for the fun or for real or hypothetic project ❓
                              Is it the new Noe's Arche? ☀
                                kwistenbiebel
                                Well this one is for sport ...
                                I was thinking that modeling something realistic (I know it is not though ) was a good way to get to know the new organic rubies and to practice them.
                                Besides, I consider it also a bit as portfolio filling ...Play becomes work becomes play 😉
                                • tinanneT Offline
                                  tinanne
                                  Wonderful work Chris, as usual. I really enjoyed "exploring" from you different views!
                                  Executive Director : American Society of Architectural Illustrators
                                  AIP 30 Competition opens soon. ASAI.org
                                  Architectural Rendering
                                    mateo soletic
                                    Chris, Great work, thanks for sharing. 👍
                                    Concept Illustrations
                                      remus
                                      That last one looks like a giant 70s spaceship just landed in someones back garen during a bbq (and no one noticed.)
                                        kwistenbiebel
                                        Thank you Tinanne and Mateo,
                                        Let me finish with the same view but different material use. Quite a different appeal:
                                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/metal-facade.jpg
                                        • I Offline
                                          igor
                                            kwistenbiebel
                                            This is how the RAW Indigo output looked like as a reference, before I unleashed the postprocessing artillery...
                                            It had a cooler tonality...maybe better than the post processed one?
                                            What do you guys think? (some .jpeg artifacts because of web compression)
                                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/view3metal-RAW.jpg
                                            • 2 / 6
