    Microsoft XP SP3 released.
    40 Posts 16 Posters 4.6k Views 16 Watching
    • N Offline
      notareal
      Windows XP SP3 is now released - available from windows update.
      http://support.microsoft.com/kb/936929
      • soloS Offline
        Okay I updated my entire system to SP3 which is a 66MB upgrade, everything is so far so good but can now see where many could have panicked.
        On restart which it automatically does it went dead, it hung on black screen, I was puzzled by this and decided to remove all USB devices (3D connexion controller, Tablet, External drives, etc) and restart. It restarted without problem and I reconnected all USB devices and did another restart (almost like remapping these devices) and everything is A for OK now.
        • jujuJ Offline
          juju
          Hehe, must have been a heart stopping few moments there Pete...
          • soloS Offline
            LOL, oh yeah! especially being my main workstation where all my modeling happens.
            I do suggest that one needs to create a restore point before installation (even though the instal does do a backup)
            • John SayersJ Offline
              John Sayers
              I installed SP3, no problems with install and reboot. Xp does run faster under SP3 and it solved the wakeup from sleep problem I had. It also fixed the problem I had with recognition of USB devices that occured with my digital camera.
              As I understand it the install problems occur with AMD processors and with some HP laptop models.
              • jujuJ Offline
                juju
                I eventually got the courage together to install the downloaded SP3 file (used the one from Coen's link). I created a restore point first, just in case... All went well, but it somehow messed with my Internet connection settings, so I investigated and found the problem. Seeing that I use static IP addresses for the machines I had to enable netBIOS over TCP/IP under the WINS tab to get connectivity back up and running. Strange that the update failed to set the correct settings, but all seem well now.
                  lewiswadsworth
                  I've installed it on four PC's...not a hitch with any of them. As a matter of fact, I think it fixed some problems I had created for myself by tampering with Registry settings and then losing my archived version.
                  ...runs pretty nicely on an Asus Eeepc, too.
                  col sporcar si trova
                    Marlise
                    Can't figure out what was more senseless: downloading SP3 over a dialup connection or staying up all night building an SU house. OK, OK, I know it's the former.
                    Haven't seen a speedup yet, but I'm already having to fix little bits of this and that, including my login here. I restarted myself, so that might have helped with the hanging screen problem.
                    The only good news was that the installation itself did a System Restore at one point during the interminable installation process. It's marked as Software Distribution Service 3.1.
                    Murphy's best law has always been, "Whatever you have to do, you have to do something else first." Microsoft is always good for that. I usually forget what I was supposed to be doing about six levels into it.
                    But SU's fun, and these forums are gems. Thanks for all the advice!
                    --Marlise
                      Marlise
                      For those of you who have installed XP SP3 and need to keep your time and date correct on your files, please note that installing mine changed the time from Daylight Savings to Standard time.
                      It's also causing more and more little problems. MS at its best. . .
                        Buzzer1001
                        Hmmm, after reading this thread I can't see a good reason to install SP3 at all. Can anyone give me one?
                        • N Offline
                          notareal
                          If you have fully patched SP2, I don't know if there really hurry - wait another month and there should be enough SP3 bugs fixed that it can be installed safely. Well... that is what I am doing 😄
                          • bazB Offline
                            baz
                            well its been a few months now and I still have'nt had the cahoolies to install sp3.
                            Anybody tried recently, any problems?
                            baz
                              glenn
                              I went from sp2 to sp3 last week...went fine...I have not noticed any improvements.
                              • jujuJ Offline
                                juju
                                I've been using SP3 for a while now, can't complain what-so-ever.
                                • N Offline
                                  notareal
                                  Seems fine. Used it a while too.
                                  • bazB Offline
                                    baz
                                    installed sp3, no problems, fingers crossed.
                                    baz
                                    • ely862meE Offline
                                      ely862me
                                      I*ve just received an update from microsoft:SP3- I installed it and all is just fine.It seems(for now)to have a faster start and shutdown.
                                      Elisei (sketchupper)
                                      Come and See EliseiDesign
                                      • 2 / 2
