    Library
    extensions
    16 Posts 6 Posters 3.1k Views 6 Watching
      remus
      Yes, it should go faster, although the difference it makes is mostly dependant on the size of the scene. If youve got a large scene and your only rendering a small part of it, it's probably worth hiding as much as you can, but if its only a small scene the time saved probably isnt worth the inconvienence of hiding all the geometry.
      • I
        igor
        i dont know. to me, all the flat white walls make it seem kind of soul-less, especialy since this is for "young children". a little bit more "warmth" would bee apreciated. both by me and the future users of the room.
        The genius switch has no "off" position
        Intelegence is natrual, it takes real effort to be ignorant
          mateo soletic
          Looks very nice to me,
          Usually if You place an emiter material on spherical or objects
          like the ceiling lamps You have over there render times increase
          considerably.I dont know what renderer You are using but this
          applies in most cases.
          Try using rectangular emiters whenever You can.
          Cheers,
          Mateo
          Concept Illustrations
            sepo
            Mateo she is using Podium...Not really good idea to use too many LEM as render times increase a lot.
            • I
              igor
              two words (or is it hyphenated?): omni lights
                sepo
                Kakang has omnis in the scene I believe. The trick is to have grid of omni with low power to get enough even light to interior.
                • I
                  igor
                  everyone give sepo a hand!
                    sepo
                    • jujuJ
                      juju
                      Lending a hand!
                      lending a hand
                        sepo
                        haha... is this called SA brutality?
                        • jujuJ
                          juju
                          That is from a foreign national, pwning our jobs... ๐Ÿ˜ฎ
                          Just toying a bit with the xenophobia that is probably in the news all over the world lately. The image above is actually a simulated severed hand made from who knows what, but it looks real all right!
                          • I
                            igor
                            whats that in the fine print? oh, and we're way off topic
