    Library
    extensions
    16 Posts 6 Posters 2.8k Views 6 Watching
      kakang
      Oh, do you know if the render goes faster if I only render the things in the model that I want. I meen does it go faster if I hide other stuff on the model that I don´t need in my rendering scene? 😕
        remus
        Yes, it should go faster, although the difference it makes is mostly dependant on the size of the scene. If youve got a large scene and your only rendering a small part of it, it's probably worth hiding as much as you can, but if its only a small scene the time saved probably isnt worth the inconvienence of hiding all the geometry.
        • I Offline
          igor
          i dont know. to me, all the flat white walls make it seem kind of soul-less, especialy since this is for "young children". a little bit more "warmth" would bee apreciated. both by me and the future users of the room.
          The genius switch has no "off" position
          Intelegence is natrual, it takes real effort to be ignorant
            mateo soletic
            Looks very nice to me,
            Usually if You place an emiter material on spherical or objects
            like the ceiling lamps You have over there render times increase
            considerably.I dont know what renderer You are using but this
            applies in most cases.
            Try using rectangular emiters whenever You can.
            Cheers,
            Mateo
            [Concept Illustrations](http://concept-illustrations.com/)
              sepo
              Mateo she is using Podium...Not really good idea to use too many LEM as render times increase a lot.
              • I Offline
                igor
                two words (or is it hyphenated?): omni lights
                  sepo
                  Kakang has omnis in the scene I believe. The trick is to have grid of omni with low power to get enough even light to interior.
                  • I Offline
                    igor
                    everyone give sepo a hand!
                      sepo
                      • jujuJ Offline
                        juju
                        Lending a hand!
                        lending a hand
                          sepo
                          haha... is this called SA brutality?
                          • jujuJ Offline
                            juju
                            That is from a foreign national, pwning our jobs... 😮
                            Just toying a bit with the xenophobia that is probably in the news all over the world lately. The image above is actually a simulated severed hand made from who knows what, but it looks real all right!
                            • I Offline
                              igor
                              whats that in the fine print? oh, and we're way off topic
