    Major bug?
    14 Posts 10 Posters 3.2k Views 10 Watching
    • P
      pichuneke
      I Believe that Matrix has broken and you are the only one that can see it, the choosen one.
      Masta, take the blue pill. Have a happy life and don't fight with the Agent Smith.
      (I hope you can fix your problem)...
      Forgive my spanglish...
      • T
        tomsdesk
        Have you checked the scale of your textures...looks like something I get sometimes (with some textures) when I'm trying to fake a ground texture for a DWC by bumping up the scale for a mottled look...?
        2.5D Trees & Shrubs!
          Masta Squidge
          When i said major bug I meant that its a major bug with my setup lol, not for everyone.
          Here goes.
          1: Im using the built in textures of SU. They all turn into multicolored, almost pixel looking stuff.
          2: There are NO plugins installed.
          3: It does this with EVERY model and EVERY texture, but the exact same file renders perfectly fine on my grandfathers PC (finally let me build him one, and I got him into SU)
          4: Fresh install of SU. I deleted everything relating to SU and saved my plugins on the desktop.
          This obviously means its not a problem with SU right? I didnt get a chance to check my drivers the other day when I posted this, so I am upgrading them right now. Hopefully that will fix it.
          • G
            gata
            Drivers also need to play well with the OS. An OS update may be the cause.
            If an updated GPU driver dosen't work, try older drivers.
              Masta Squidge
              There have been no new updates to anything since this worked last time, so idk whats causing it.
              Im off to restart the PC and check the new drivers.
                sliner
                I recently had a same problem with SU, I too reinstall the program and suspected LightUp, but when has checked up in Rhino and Modo there were same problems with textures. Has rearranged the driver of a videocard on older and all has passed (NV GF 7600 GT)...So check up others 3D programs
                http://fancyquest.ru/albums/yucca/
                  sliner
                  Such was with all raster textures...
                  Thanks for the invitation, Coen, but in English I basically read, to write difficultly though I shall try whenever possible:-)
                    Masta Squidge
                    Well, redoing all of the drivers didnt fix it...and it does it with ALL textures, just not the solid colors. So im at a bit of a loss. But I know its something to do with the video card on the software side because im having problems with hard reboots. My computer will just up and die when i load some games, but only rarely. Im not sure whats causing it yet, and every time it happens ai try to make a note of everything thats running... but its never really the same thing twice.
                    Oh well... such is life. Ill be buying a new computer eventually. Im waiting on the core 2 quads to drop in price again and ill be picking one up and over clocking it to about 3ghz. 220 bucks is still a bit more than id like to spend at the moment.
                    • K
                      krash88
                      Sounds to me like a video card (hardware) issue. Check that if the card has a fan, it is still spinning. Could be bad ram on the card or just over-heating in general. The fact that some games crash leads me to believe that this could be the issue. Just my 2 cents...
                      • AnssiA
                        Anssi
                        Something like this happened to me too before something in my laptop died, most probably the graphics card, as it still works but the screen is garbled, and displays the same if I connect an external monitor.
                        Anssi
                        • T
                          toan76
                          Wow... I am having the exact problem. Do you by any chances have Windows XP SP3 installed
                          on your machine?
                          Update: I updated the Nvidia video card driver and the problem went away. So the previous driver may be broken.
