    Need help with holes
    12 Posts 7 Posters 963 Views 7 Watching
      dammerel
      Hi guys
      I need some help with punching holes thru a face
      any hints? is there a ruby tool to help
      I seems a bit hit and miss some times
      Andrew
        Hi Andrew,
        What kind of face do you want to cut a whole in? With a "normal" (i.e. single) face it should be pretty easy; just draw the shape of the hole you want to "punch" and delete the inside face.
        With a curved surface you can extrude the shape you want to cut through the surface, select all and right click > intersect with model (or selected). Now deleting unwanted geometry will get you there.
        Note that intersecting always works in the context (i.e. within a group) you are working in.
        • soloS Offline
          Supplying an image for us to understand will make things a lot easier to help you.
            dammerel
            Hi Gaieus
            Yep just a normal face with thickness but real thin 1.6mm sheet metal
            As I said, sometimes its works and sometime not.. I guess its hard to push-pull a "hole"
              dammerel
              example attached
              holes.skp
                dylan
                Andrew I downloaded your example and it does work perfectly.
                If I draw shapes on the surface, push pull works exactly as it should do each time.
                I switched on Color By Axis to check you had coplaner lines and everything is ok.
                There is no reason why this should not work in SU.
                Are you saying sometimes you can push through and other times not?
                If you place the push/pull selection tool on screen against the drawn shape, does it select/highlite the shape drawn ok?
                http://dmdarchitecture.co.uk/
                  dammerel
                  Dylan
                  Have a look at the attached, this is what happens
                  Andrew
                  holes.skp
                    Yeah, what James says. You can PP further but if you stop at the bottom face, it will cut a hole. You can easily inference with the bottom line or any of the endpoints. When one hole is made, you can then double click on the other shapes and they will PP with the exact same amount.
                      dammerel
                      ahh double click..thats the trick thanks
                        remus
                        There was a ruby out there that did this for you, although i lost it when i upgraded my computer. I think it was called hole.rb, but when i tried looking for it under that name i got something different. Anyone else remeber this ruby?
                        • W Offline
                          watkins
                          Dear Remus,
                          It is a Rick Wilson script called holes.rb. I looked for it in the Ruby Library Depot (it is still listed there under Edit), but it is no longer available. This usually means that it has moved to Smustard, but it wasn't there either.
                          Regards,
                          Bob
                            PRSS
                            Hello
                            Here is the holes.rb script. Also I have attached opener.rb which also does the same thing. I think it is from Smustard - I do not remember. But I use this extensively to cut holes.
                            Makes holes
                            This also makes holes
                            Hope this helps
                            With best regards
                            PRSS
