    Procedural terrains
    63 Posts 25 Posters 11.3k Views 25 Watching
    • soloS Offline
      Thanks Chris, the above was textured in SU and rendered with Podium (you can see the stretching textures due to SU's limited mapping abilities)
        kwistenbiebel
        @solo said:
        ... the above was textured in SU ...
        I know, that's why I asked about Vue 😄
        (Very nice Podium render by the way)
        • DanielD Offline
          Daniel
          I've found the book "E-on Software's Vue 6 Revealed" to be a good reference source. Changing or tweaking the materials applied in SU in Vue is easy - just click on the material in the browser on the left, and the material editor opens - and you switch between the basic editor and the advanced editor. For the most part, the controls are self explanatory. And you can see the changes real time in the preview window. If a bumbling renderer like me can use it, a pro like you shouldn't have any probs. If I were you, I'd just download the eval version and play with it.
          My avatar is an anachronism.
            kwistenbiebel
            Thank you Daniel. I will have a go with that.
            • soloS Offline
              Okay, my bad. 😳
              I will look out for a few tutorials, I have never used nor seen one yet (havent looked either)
              I am trying something different now (details to follow) using a Google aerial map and converting the image to a 3d mesh.
              I took a piece of scotland as seen below and converted the .jpg to a .skp. The problem i need to overcome is file sizes due to poly limits, but accuracy seems spot on (a few elevation adjustments may be needed and can be achieved using FFD or scale tool).
              I had to reduce the file by 80% 😲 and still the .skp is 47MB
              http://img139.imageshack.us/img139/9012/scotland1dk8.jpg
              GE image.
              http://img228.imageshack.us/img228/4427/scottvn1.jpg
              The SU model with hidden lines on.
              http://img228.imageshack.us/img228/8268/scott1gf0.jpg
              No lines and shadows on.
              • soloS Offline
                LOL@myself.
                look at lower right corner of last image (the google logo is a mountain)
                • DanielD Offline
                  Daniel
                  Solo, how did you convert the GE jpeg to the 3D SU model?
                    kwistenbiebel
                    Indeed 😲 😮 How does one do that? (Zbrush?)
                    • soloS Offline
                      Daniel, I will do a kinda tutorial once I have all the kinks worked out and there are a few. The Google earth image gets changed into an extreme bump or better word a displacement map which is then used as a map on a flat mesh to create a physical relief. I want to see if I can map the actual image as a texture and then use it also as a displacement map in oder to give a better 3d representation.
                      • FrederikF Offline
                        Frederik
                        This is simply AMAZING, Pete..!! 👍 👍 👍
                        Looking forward to learn more about this... 😄
                        Cheers
                        Kim Frederik
                          sepo
                          Fantastic stuff Solo...looking forward to see the way you do it.
                            kwistenbiebel
                            This is a cool progress to watch.
                            I can imagine using the displacement-to-mesh idea for lots of different things as well.
                            • soloS Offline
                              St. Andrews golf course in Scotland.
                              http://img249.imageshack.us/img249/6884/standrewsakv6.jpg
                              http://img443.imageshack.us/img443/9678/standrews1rx9.jpg
                              http://img249.imageshack.us/img249/9766/standrews2aa8.jpg
                              http://img443.imageshack.us/img443/5360/standrews3ka4.jpg
                                sepo
                                Looks good. What happens with buildings. Do they come up accurately?
                                • soloS Offline
                                  http://img443.imageshack.us/img443/9356/terrdwi6.jpg
                                  reduced poly version.
                                  The houses do not raise right due to google image had shadows that screw with the displacement.
                                  fast render (20 seconds due to image being texture)
                                  http://img249.imageshack.us/img249/4042/andrewsrenderqx3.jpg
                                  Still needs tweaking, but this could be a new way of doing terrains, may need a code expert to make this a ruby idea however.
                                    princedragoncok
                                    My god, this is amazing. Still don't understand how this is works though.. 😲
                                    • marked001M Offline
                                      marked001
                                      haha... me neither.. i understand how the bump maps or displacement maps work in the renders.. but how are you achieving that complex sketchup mesh?? awesome stuff.. i just recently saw someting on the maxwell forums where someone had just taken a google earth image and used it as a displacement map.. wasnt accurate at all, but was really cool and simple..
                                      http://www.revision21vis.com
                                      instagram: revi21on
                                        kwistenbiebel
                                        [Off Topic]: I tried texturing a freeform in Vue...and didn't succeed .Seems as Vue doesn't really has real UV-mapping tools (only cilindrical,spherical, etc..which results in distorted soup). Next step: Zbrush?
                                        Sorry for the OT. Now please continue with this nice landscaping process 😄 !
                                        • soloS Offline
                                          I would also believe Z-brush to be the best option. Vue has more mapping tools than SU and others alike but by no means a true solution.
                                          • F Offline
                                            fossa
                                            Just to chime in here and show there is some more interest in this process. We are doing stuff like this more and more and I for one would love to see a tutorial on this process. Time usually doesn't permit us to do the freeform thing and we end steping the contours from survey data or traced images.
                                            I guess my real question is: Are you getting an accurate "dem" image from GE to use as a displacement map or is this more of an "artistic guess" at landscaping. Either way you are certainly on to something here. If someone could build a displacement map routine ruby for sketchup I'm not sure I would need autocad anymore.
                                            • 1 / 4
