Stonehenge Project
To all forum folk who helped me with this project,
After all the good advice re SubSmooth, I've got a first cut at the Stonehenge monument as it is today. I'm at the tweaking/fiddeling stage now and any ideas, advice, critiques whould be welcome. As this model is aimed at GE, I'm particularly concirned about the size of the file: 3.7MB.
Thanks in advance,
Tom
Tom
That looks great, about the file size, well you must understand that organic modeling will always be heavy due to the complexity and sheer number of faces needed to create the shapes, 3,7 Mb is not too bad actually.
You could try poly reducing but it would make the stones angular and spoil the realism.
Tom, from what I can see in these small images ( ) it must look really nice! As for file size; yes, obviously, it may seem to be quite big but if the Google QT realises that this is THE REAL model, I guess they wil be sort of "forgiving" about it (not to speak about the fact that there aren't many other building to be streaming / downloading in the neighbourhood).
Also, how much portion of the file size is the geometry and how much is the image files you used for texturing them? When the textures are heavy, the geometry still downloads easily and the textures apper a bit later. This is not true vice versa however.
Any chance for some bigger images?
Very nice work, Tom.
There is an interesting article in the latest National Geographic magazine about Stonhenge, Durrington Walls and Woodhenge. I'd not heard of the last two before nor of the other artifacts as well as burial remains found in and around Stonehenge.
Here're some bigger versions of the 3 shots.
I used Picasa to shrink all the texture photos before use. The textures average about 8-10KB,but there are a lot of them.
Tom
Now I can see better, thanks Tom. Really great model, I can tell!
This is the inside (though more spectacular) circle. Do you want to model the outside (less spectacular - but older and astronomically more interesting) outside circle as well? Though it wouldn't show too much on GE I presume...
could you upload larger images?
Gaieus,
I chose the part that is inside the ditch because that is what is usually shown in photos and is the most spectacular. Also, it's what people see when they visit the site (my wife and I went there last week to get some aditional photos). When you aspproach the site from the east on the road, your first view of the monument is what is in the model. Also, as I said above, it's pretty big already.
On the subject of geometry vs. texture, I tried 3 ways to do these stones: first, very acurate geometry (high poly) with standard gray stone texture on all of them, second, very simple geometry and rely on the texture images for realism and third, a compromise between the two. The last one is what you saw in the shots above.
Tom
It's an incredible work.
Do you have plans for the original Stonehenge?
The first picture is a plan as its today that appears in several books. This one is from English Heritage Book of Stonehenge, Julian Richards, B.T. Batsford Ltd,1991. On the web I've oonly managed to find very small plans that aren't much use. Also, I haven't yet found any elevations. If anyone knows where they are, I like to know. There must be some academic sites with this kind of info.
I've also attached a plan that I downloaded showing the original layout. There are quite a few models of Stonehenge in 3DW that show a rconstructed view.
Thanks and regards,
Tom
Nice work....congratulations....!
I'd like to see this one rendered in KT.
Looks great Tom and you have modelled the stones nicely.
Look forward to seeing this develop.
Dear Tom,
This might be of interest:
Regards,
Bob -
And this... (I hope):
Very nice work Tom. I would as well like to get up closer amoung the rocks. I don't know if you are into rendering but this would certainly be a great model to play with. Cheers to you!!
Hi Modelhead,
I first went to Stonehenge in the mid-1970s. In those days you could walk all over the site and touch the stones. Now we're kept away from the stones to preserve them.
No, I haven't gotten into rendering. But could somebody else do it with the SU model?
Tom
@twharvey said:
...No, I haven't gotten into rendering. But could somebody else do it with the SU model?
Tom
Oh, I'm sure there are plenty of people who would be more than happy!
I'll have a go if you want, tom. Just PM me the file if you fancy it.
I'd love to give it a try as well...
Archaeologists carrying out an excavation at Stonehenge say they have broken through to a layer that may finally explain why the site was built.
Nice work Tom,
Here is me at Stonehenge.
What elevations do You need ?
